Smart Home & Healthcare Challenge
  • Smart Home & Healthcare Challenge
Forum VitaRF - Part 8 - Assembling the PCB with Stencil, Paste and a Hot Plate
  • News
  • Projects
  • Details
  • DC
Join Smart Home & Healthcare Challenge to participate - click to join for free!
  • Replies 8 replies
  • Subscribers 20 subscribers
  • Views 236 views
  • design challenge
  • e14-smart home & healthcare
  • pcb-assembly
  • nrf52
  • smart home & healthcare
arvindsa
arvindsa 27 days ago
Recap: I am building a wireless vitals sensor node (heart rate, SpO₂, temperature) that reports over BLE into Home Assistant as a smart way to keep watch over our loved ones, built up in three phases — DK bring-up, a custom miniaturized nRF52832 PCB, then a Matter over Thread proof of concept.
Past Posts
  1. VitaRF - Part 1 - The Plan
  2. VitaRF - Part 2 - Interface MAX30102 on NRF52
  3. VitaRF - Part 3 - Interfacing MAX30208 on NRF52
  4. VitaRF - Part 4 - Sending Sensor Data to Home Assistant via BLE on NRF52
  5. VitaRF - Part 5 - Matter over Thread on nRF54L15 with Home Assistant
  6. VitaRF - Part 6 - An nRF52-Based Heart-Rate & Temperature Wearable PCB for Home Assistant
  7. VitaRF - Part 7 - Adding a Philips WiZ Smart Bulb to Home Assistant
Paste, place, reflow
This is the whole process in one video: applying the paste through the stencil, placing the components, and the reflow on the MHP50.
Music by Dmitrii Spis from Pixabay
I will explain the drivers and the final integration code in the upcoming post.
Final Notes
Assembling multiple boards tests your patience, and it is a good way to practice staying calm and making precise movements. The PCB design came out flawlessly, with no mistakes identified yet. Stay tuned for the next post. The Video is made using EffectCraft and FilmCraft. It's not adobe. But again, I have no need to spend on adobe when Open source works well. Thanks to Jorat for the reminder.
  • arvindsa
    arvindsa 26 days ago in reply to Qbit +1
    Thank you so much. It is most of the time calming to place components.. Until you realize one of an critical component is missing. (I misplace things a lot :D )
  • mihaita802003
    mihaita802003 27 days ago
    Nice PCB. What software do you used for this?
  • arvindsa
    arvindsa 27 days ago in reply to mihaita802003
    Kicad. Been a very humble fan of Kicad. Not Kicad 10 though (Memory hogging)
    shabaz 27 days ago in reply to arvindsa
    Hi! It might be worth giving KiCad 10 another go at some point if you wish.. you're right, version 10 was a memory hog, but from memory that was because they decided to preload more things (libraries perhaps) but from all the negative feedback, I believe they backtracked in a later dot-release. I can't recall the detail.
    Also, another memory-saving thing, is to remove all the libraries you're definitely not interested in; for instance, I have no intention to use high-pin-density BGA parts, so I removed some of the FPGA and SoC libraries, etc. Then it's not possible for them to be loaded into memory.
  • Qbit
    Qbit 26 days ago
    Amazing SMD soldering skills! great to see entire workflow coming down to the single pcb.
  • BigG
    BigG 26 days ago
    Clearly not a coffee drinker Grinning Those were very steady component placements in the video. Impressed.
  • arvindsa
    arvindsa 26 days ago in reply to shabaz
    shabaz  I am still on Kicad 10. I was using my desktop which had 32Gigs of RAM and there, I could run Kicad without a problem, The trouble began when i used my 8GB ram laptop while traveling to edit the PCB. Crashes. Since Kicad is not backward compatible, I am forced to use it. and yes, I will update the Kicad and remove unnecessary libraries.  Wait, I remember you posting a blog about it. Adding it to my reading list.
  • arvindsa
  • arvindsa
    arvindsa 26 days ago in reply to BigG
    Take a Time Machine, Go to 2018. You'll find me as a Coffee addict, with heavy jitters. Took me an year to detox properly. Smiley.
