Upcycle It
  • Upcycle It
Upcycle It
Blog [Upcycle It] Interactive Race Car Driver - Hotrodding the Edison
  • Author Author: Workshopshed
  • Date Created: 11 May 2017 8:24 AM Date Created
  • Views 3704 views
  • Likes 8 likes
  • Comments 21 comments
  • upcycled_interactiveracecardriver
Workshopshed
Workshopshed
11 May 2017
The observant amongst you will have spotted that there was an item in the  [Upcycle It] Interactive Race Car Driver - 3D Printed Parts article that did not relate to any of the things I was printing. That was because I did not know if it was going to print ok or not. The part is some "exhaust pipes" to add to the Edison to turn my "engine" into a hotrod.
Because I was concerned about the exhausts wobbling about when printing I added some 1mm horizontal supports to the model which were then cut off using a knife following the print. The print went well until layer 165 of 168 at which point it came detached from the print bed. As I was printing at 100% fill this did not actually matter and I've gone with fractionally shorter pipes by 0.9mm. If I was going to print it again I'd likely use a brim around the base to give it a bit more grip.
You can find all the models at https://github.com/Workshopshed/UpcyclingDesignChallenge/tree/master/3DModels
I don't think my modification will make any difference to the Edison's performance but I do think it looks cool. Hopefully, I'll have time to give it a coat of silver paint so it looks more like exhaust pipes.
Previous Posts
Upcycle It Blogs tagged with upcycled_interactiveracecardriver
    mcb1 over 9 years ago in reply to mcb1 +4
    dougw over 9 years ago +3
    Superb - those pipes are absolutely iconic. Of course if you printed a "blower" for the air intake it would be spectacular if you could squeeze in a real fan. Not trying to mess up your already impressive…
    balearicdynamics over 9 years ago in reply to mcb1 +2
    Mark, it seems there is not sufficient space to fit the Edison Enrico
    This project is on the twilight zone between a great making upcycle and a car model building. When I was child I built a lot of car models and as I see your progress I regret not to have a 3D printer and some electronic knowledge to make my models smart image I can't wait you finish this build. To be honest I hope you make a long and detailed video testing the finished car in the last episode.
    Enrico
    Enrico
  • Workshopshed
    Workshopshed over 9 years ago in reply to balearicdynamics
    Hi Enrico, videos take time to do and I'm very aware of how many weeks we have left. I can produce long written explainations because they don't need to be done in "one take" and can be written on my commute to and from work by tube.
    Hopefully there will be a demo but it is unlikely to be a long one.
    My plan is to give the car to my daughter after the challenge so there will be an opportunity for further videos later.
    balearicdynamics over 9 years ago in reply to Workshopshed
    Hi Andy, I think that your daughter is the best road tester for this toy image Looking forward the progress of this great project and then the testing...
    Enrico
