Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Helping eyes for soldering
  • Subscribers 43 subscribers
  • Views 606 views
  • Accessibility
I love electronics and programming. The other day I bought an arduino compatible board and it needs headers solder onto it. I have the tools, the solder, everything, even helping hands with a magnifying glass. There's one problem, I'm legally blind and soldering is not within the grasp of my vision at 20/125. So, I'm thinking, I have a 32 inch flat screen hooked to my computer and Raspberry pi, what could we do with this to make a blind guy soldering station?
  • makerkaren
    makerkaren over 10 years ago +1
    I don't know how much bigger you need to be able to make the image, but I've watched someone solder using one of these homemade smartphone microscopes. http://www.instructables.com/id/10-Smartphone-to…
    DAB over 10 years ago
    I take it from your description that you want to use the RPi camera to enlarge the area that you want to do soldering on?
    Given your vision issues, you can probably use just about any web-cam plus some directed lights to give you enough contrast and magnification to do an adequate job.
    It may take you some time to adjust your movements to account for the magnification, but I don't think that there should be any wrong with making a setup to do what you want.
    Please keep us informed on your build and experiences so we can continue to provide suggestions.
    You will also want to pick up some third hand devices to firmly hold the items in place while you try to solder them.
    jw0752 over 10 years ago
    Hi Leroy,
    Are you able to work through a regular lighted magnifier? If this provides enough magnification it might be easier to get accustomed to than watching a monitor and working remotely. I hope you find a good solution and can continue with yuor project.
  • makerkaren
    http://www.instructables.com/id/10-Smartphone-to-digital-microscope-conversion/
    Obviously the design would need to be modified to allow enough room for the circuit board and your hands, but if a smartphone screen is large enough for you, this might be an inexpensive solution. You can use whatever magnification you need to be able to see and this would keep the viewer between you and the project, making it less necessary to modify your movements vs what you see.
    shabaz over 10 years ago
    Hi!
    Not a complete answer, but you may get some ideas/avenues to pursue from some suggestions here, several methods were covered: Building a Digital PCB Inspection Microscope with the Gizmo 2
