Project Videos
  • Project Videos
Project Videos
Documents A Noise-Free DIY Switching Power Supply - How Hard Can It Be? -- Episode 542
  • Date Created: 10 Mar 2022 5:22 PM Date Created
  • Last Updated Last Updated: 18 Mar 2022 8:24 AM
  • Views 13405 views
  • Likes 12 likes
  • Comments 14 comments
Switch Mode Power Supplies (SMPS) need a printed circuit board (PCB). To see why check out this video. We look at how hard could it be to get a PCB design right! Hint: You need copper zones to get a low-noise SMPS design.
Supplemental Content:
  • Free Routing
  • Workbench Wednesdays Measuring SMPS Ripple
  • Resources
Bill of Material:
DC/DC CONV, BUCK/BOOST/INVERT, 85DEG C On-Semi 1 Buy Now
Small Signal Schottky Diode, Single, 45 V, 8 A, 570 mV, 120 A, 150 °C Vishay 1 Buy Now
Power Inductor (SMD), 180 uH, 1.9 A, Shielded, 1.6 A, SRR1210 Series, 12mm x 12mm x 10mm Bourns 1 Buy Now
CAP, 4700uF, 16V, RADIAL, SMD PANASONIC 1 Buy Now
SMD Multilayer Ceramic Capacitor, 0.47 µF, 25 V, 0805 [2012 Metric], ± 10%, X7R, -55 °C SAMSUNG ELECTRO-MECHANICS 1 Buy Now
Surface Mount Thick Film Resistor, CRG Series, 68 kohm, 330 mW, - 5%, 150 V RoHS Compliant: Yes TE CONNECTIVITY 1 Buy Now
SMD Aluminum Electrolytic Capacitor, Radial Can - SMD, 330 µF, 25 V, 0.8 ohm, 2000 hours @ 85°C NIC COMPONENTS 1 Buy Now
Additional Parts:
PCBs: Auto-Routed, 6mil no pour, 6mil with ground pour, and Copper Zones
element14 presents
element14 presents  |  About James |  Project Videos
  • vishay
  • SMPS Design
  • On-Semi
  • buck converter
  • SAMSUNG ELECTRO-MECHANICS
  • smps
  • e14p_JBE
  • panasonic
  • te connectivity
  • james
  • SMPS PCB
  • bourns
  • pcb design
  • NIC COMPONENTS
  • friday_release
    dougw over 4 years ago in reply to kmikemoo +1
    I had an instructor that used the same phrase - I think in connection to report writing objectives. It seems to me the more I know the less obvious it becomes.
    dougw over 4 years ago +1
    Interesting episode, although designing for failure rubs me the wrong way. I would like to see to see if there is a difference between realistic attempts - I doubt anyone would design with a 6 mil trace…
  • mayermakes
    mayermakes over 4 years ago in reply to dougw +1
    I agree, a follow up episode showing how to impedance match traces and compare them to filled zones would be interesting!
  • koudelad
    koudelad over 3 years ago
    Great episode. I got to it a year after releasing, but glad I found it.
    I guess one solution for less skilled HW designers might be that there will be ready made modules that would be connected to a target PCB via castellated edges or just pin headers, just like use processing power (e.g. Raspberry Pi Pico) / communication modules (many GSM / BT / GPS modules).
  • koudelad
    koudelad over 3 years ago in reply to koudelad
    I also just remembered an experiment of a teaching assistant on EE university. Instead of using a 2 layer PCB, using 4 layers with ground layer and a power layer. Even a sloppy designed PCB that produced a high amount of EMI got under control using this thick.
  • koudelad
  • baldengineer
    baldengineer over 3 years ago in reply to koudelad
    That is what I had to do on the Mega IIe project’s power supply! The noise went down significantly by going to four layers.
    Going forward, I will probably always use 4 layers on (standalone) SMPS designs. But as you said, pre-made modules are often a better option.
