Project Videos
  • Project Videos
Project Videos
Documents A Noise-Free DIY Switching Power Supply - How Hard Can It Be? -- Episode 542
  • Date Created: 10 Mar 2022 5:22 PM Date Created
  • Last Updated Last Updated: 18 Mar 2022 8:24 AM
  • Views 13414 views
  • Likes 12 likes
  • Comments 14 comments
Switch Mode Power Supplies (SMPS) need a printed circuit board (PCB). To see why check out this video. We look at how hard could it be to get a PCB design right! Hint: You need copper zones to get a low-noise SMPS design.
Supplemental Content:
  • Free Routing
  • Workbench Wednesdays Measuring SMPS Ripple
  • Resources
Bill of Material:
DC/DC CONV, BUCK/BOOST/INVERT, 85DEG C On-Semi 1 Buy Now
Small Signal Schottky Diode, Single, 45 V, 8 A, 570 mV, 120 A, 150 °C Vishay 1 Buy Now
Power Inductor (SMD), 180 uH, 1.9 A, Shielded, 1.6 A, SRR1210 Series, 12mm x 12mm x 10mm Bourns 1 Buy Now
CAP, 4700uF, 16V, RADIAL, SMD PANASONIC 1 Buy Now
SMD Multilayer Ceramic Capacitor, 0.47 µF, 25 V, 0805 [2012 Metric], ± 10%, X7R, -55 °C SAMSUNG ELECTRO-MECHANICS 1 Buy Now
Surface Mount Thick Film Resistor, CRG Series, 68 kohm, 330 mW, - 5%, 150 V RoHS Compliant: Yes TE CONNECTIVITY 1 Buy Now
SMD Aluminum Electrolytic Capacitor, Radial Can - SMD, 330 µF, 25 V, 0.8 ohm, 2000 hours @ 85°C NIC COMPONENTS 1 Buy Now
Additional Parts:
PCBs: Auto-Routed, 6mil no pour, 6mil with ground pour, and Copper Zones
element14 presents
element14 presents  |  About James |  Project Videos
  • vishay
  • SMPS Design
  • On-Semi
  • buck converter
  • SAMSUNG ELECTRO-MECHANICS
  • smps
  • e14p_JBE
  • panasonic
  • te connectivity
  • james
  • SMPS PCB
  • bourns
  • pcb design
  • NIC COMPONENTS
  • friday_release
    dougw over 4 years ago in reply to kmikemoo +1
    I had an instructor that used the same phrase - I think in connection to report writing objectives. It seems to me the more I know the less obvious it becomes.
    dougw over 4 years ago +1
    Interesting episode, although designing for failure rubs me the wrong way. I would like to see to see if there is a difference between realistic attempts - I doubt anyone would design with a 6 mil trace…
  • mayermakes
    mayermakes over 4 years ago in reply to dougw +1
    I agree, a follow up episode showing how to impedance match traces and compare them to filled zones would be interesting!
    DAB over 4 years ago
    Great episode.
    I remember watching the PC board designers back in the 1970's and you verified everything they told me that works.
    PCB design may look easy but as you demonstrated, looks can be deceiving.
    Even a simple circuit requires some knowledge and experience.
  • baldengineer
    baldengineer over 4 years ago in reply to DAB
    Thanks DAB.
    This video was an idea that I had in the back of my mind for a long time.
    Waiting for them to come back was a little nerve-racking. I sent them all out at the same time. I biggest fear is there would be like a 10-20 mV difference between them!.
    And seeing the "auto routed" vs the "6 mil route, no ground plane" performance made me think: W.T.H. But I built two others of the 6 mil board. They all perform the same!
  • baldengineer
    Thanks DAB.
