Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi 4 Experimental Resin 3D Printer -- Episode 414
  • Date Created: 30 Sep 2019 8:47 PM Date Created
  • Last Updated Last Updated: 4 Oct 2019 7:24 AM
  • Views 10574 views
  • Likes 17 likes
  • Comments 27 comments
Tiny resin based 3D printers may be all the rage now, but size matter sometimes, and how these printers operate does not scale up well. Clem has an Idea to circumvent these technical limitations with a ground breaking giant 4k Resin 3D printer! Utilizing 2 Raspberry Pis (4 & 3B+) he sets out to prove that FEP foil can be replaced with a specialized liquid, making the LCD-masking technique viable for large format 3D printers!
Supplemental Content:
  • A lot of parts for the mechanics were salvaged from this project: Episode 359: Make Your Own CNC Pyrography Wood Burner
  • The heatsinks were covered in-depth in this video:  Episode 399: Candle-Powered Robot
  • The main board for the giant 3D printer is the MAYER MOVES Dev Kit showcased in this episode: Episode 410: MacPro G5 Cheese Grater with Raspberry Pi 4
  • Click here to get the complete MAYER MOVES Motor Control Dev Kit
Bill of Material:
Raspberry pi 4B Raspberry-PI 1 Buy Now
Raspberry p3B /3B+ Raspberry-PI 1 Buy Now
PRO SIGNAL Audio / Video Cable Assembly, HDMI A Plug to Micro HDMI D Plug, 6.6 ft, 2 m, Black PRO SIGNAL 1 Buy Now
CARLO GAVAZZI Solid State Relay, SPST-NO, 25 A, 280 VAC, Panel, Screw, Zero Crossing CARLO GAVAZZI 1 Buy Now
RASPBERRY-PI Daughter Board, Raspberry Pi 7" Touch Screen Display, 10 Finger Capacitive Touch RASPBERRY-PI 1 Buy Now
MEAN WELL AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 100.8 W, 36 V, 2.8 A MEAN WELL 1 Buy Now
MEAN WELL AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 50.4 W, 12 V, 4.2 A MEAN WELL 1 Buy Now
MULTICOMP Axial Fan, 12 V, DC, 60 mm, 33.05 dBA, 18.84 cu.ft/min MULTICOMP 3 Buy Now
MEAN WELL AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 15 W, 5 V, 3 A MEAN WELL 2 Buy Now
TRINAMIC Evaluation Board, TMC2209 SilentStepStick, 2-Phase Motor Driver TRINAMIC 1 Buy Now
NANOTEC Stepper Motor, High Torque, DC, 0.5 N-m, 1.8 A, Two Phase, 1.75 ohm, 3.3 mH NANOTEC 1 Buy Now
OMRON Microswitch, Snap Action, Hinge Roller Lever, SPDT, Solder, 5 A OMRON 1 Buy Now
Additional Parts:
Product Name
4k instore Display Monitor 28“
Aluminium Extrusion for the Frame
PMMA-XT for the Vat
PMMA/Acrylic for the Case
3D printing filament for all the printed parts
UV LEDs  and heatsinks
ResinPrinter_Resources.zip
Rasperry Pi4 Resin 3d Experimental Printer
element14 Presents  |  About Clem  |  Project Videos
  • 3d printer
  • formlabs
  • large 3d printer
  • clem
  • 4k 3d printer
  • nonotec
  • solid state relay
  • e14presents
  • trinamic
  • anycubic photon
  • omron
  • resin printer upgrade
  • e14presents_mayermakes
  • resin printer
  • big 3d printer
  • elegoo mars
  • large resin printer
  • raspberry pi 4
  • giant 3d printer
  • 2-phase motor
  • Raspberry Pi Touchscreen
  • fom1
  • diy 3d printer
  • multicomp
  • form2
  • pro signal
  • friday_release
  • 4k resin printer
  • mayermakes
  • e14p_CMM
  • mayermakes
    mayermakes over 7 years ago +5
    If you have any questions I'll be happy to answer them here. Clarification on the Firmware: NanoDLP is FREE(as in cost) , but it is not open source. You can use share and distribute it freely even comercially…
  • pumpernickel
    pumpernickel over 7 years ago +3
    Hello! I wrote some ideas about a large format MSLA printer in the youtube comments and was asked to post em here. I've thought about three ways, each with their advantages and disadvantages: 1. Easiest…
  • deadbe3f
    deadbe3f over 6 years ago +3
    Hi Clem, I found your youtube video very interesting, I am wondering why not use the low refractive index substrate with a silicone applied coating? lots of laser resin folks are using acrylic like vats…
  • celcius1
    celcius1 over 6 years ago
    Hi Clem,
    Sorry for posting in an older project of yours, but whilst I was posting on your latest project I had a light bulb moment, as I do work with Telecommunications in my day job, I recently did some fibre optic work for a few clients and used field terminated connectors, sorry for the long intro but I'm getting to the point, these field terminated connectors use an INDEX MATCHING GEL so to match the glass fibre to the polished glass in the connector.
    So the idea I have is, if you can source the index matching gel used in field terminated fibre optic SC or SC-A connectors, its designed to have the same index as glass, and being a gel, its denser than the resin, and the index gel only needs to be a thin layer.
    So that would be the best stuff to use.  But I don't know why I did not think of it before, but thanks to having a recent client getting fibre optic work done, it came to mind again.  But the difficult part is sourcing the index matching gel.
    Regards
    Paul
    Edit: did a quick search and found this https://www.fiberinstrumentsales.com/fis-matching-gel-4-oz.html
    and this https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=354
    and this TechOptics - Index Matching Gels
    and this https://www.newport.com/f/index-matching-fluid
    even found thisIndex Matching Materials
  • celcius1
    Hi Clem,
    Regards
    Paul
  • mayermakes
    mayermakes over 6 years ago in reply to celcius1
    I'm always happy about comments on older posts as it keeps them relevant and I often go back to those projects.
    You are right!
    I have heard of such gels before but no way to source them it didn't even seem that our local Fibre companies use it.
    I'm currently working on the version. Two of this 3d printer and have some ideas that might eliminate the need for a specialized liquid.
  • celcius1
    celcius1 over 6 years ago in reply to mayermakes
    If you want I can speak to my local supplier, and see if they can source the index matching gel, and get back to you with a price.
    My contact at the supplier is always willing to help me out with fibre optic's as he owes me a favour or two
  • mayermakes
    thanks for the update, a very handy chart!
  • celcius1
    Your welcome mate.
    Just trying to shoot a thought across, the resins used in SLA printers, do they stick to glass?  If not have you investigated using a vat with a glass base?
  • mayermakes
    Pretty much all resins I encountered stick to Glas and most plastics, there are silicones used for laser based printers.
    Those don't work as well with msla anecdotally.
