Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15933 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • thomasvdd
    thomasvdd over 6 years ago
    I have made the project and can confirm that the original code runs just fine.
    The behavior you described is how it is intended to function, as you can see from the code:
    When pressing one of the speed buttons, the activespeed variable is being changed.
      if (buttonFast.fallingEdge()) {
        activeSpeed = SPD_FAST;
    The next time the loop() executes, the if statement triggers and presses a key (KEY_4)
    if (activeSpeed != lastSpeed){
        digitalWrite(lastSpeedLED, LOW);
        switch(activeSpeed){
          case SPD_FAST:
            Keyboard.press(KEY_4);
            Keyboard.release(KEY_4);
            digitalWrite(PIN_LED_FAST, HIGH);
            lastSpeedLED = PIN_LED_FAST;
          break;
    When pressing one of the X, Y, Z buttons, the activeAxis variable is being changed.
    (uncomment the serial print to verify if your button works)
      if (buttonX.fallingEdge()) {
        activeAxis = X_AXIS;
        //Serial.println("X");
    HOWEVER, the corresponding button (KEY_RIGHT) is ONLY being pressed when the encoder is turned.
    Pressing the X, Y or Z button only will NOT press any keyboard key.
      if (abs(newScrollPos - lastScrollPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
        if (newScrollPos - lastScrollPos > -1){ // positive increase
          switch(activeAxis){
          case X_AXIS:
            Keyboard.press(KEY_RIGHT);
            Keyboard.release(KEY_RIGHT);
          break;
    In conclusion: if your CNC doesn't move, your rotary encoder is probably badly connected.
    Check the connections from encoder to teensy (also the middle ground pin). If that fails, I would buy a new encoder and try again.
    Hope this helped
    Thomas
  • wildmack
    wildmack over 6 years ago in reply to thomasvdd
    Hello Thomas, thank you so much for helping me out with this, it's driving me nuts.   I bought 2 encoders, so I'll try changing them out today.  I checked the impedance on the encoder, and it changed as I rotated it, so I assumed it was working.  I used the three sided pins of the encoder, outer pin goes to pin 9 on the controller, the center pin is to ground, and the other outer pin is connected to pin 10 on the controller.   I opened the serial monitor and uncommitted the serial print line and each time I press the X,Y,X buttons it shows on the output of the serial monitor screen.  Should it repeat the X,Y,Z on the screen if I turn the encoder?   I'm still learning how to program, so this is way above my understanding.  Is there any way to see if the controller is actually sending the commands, like KEY_RIGHT?  I really need to get this working, so I really appreciate your help.  I just can't figure out what I'm doing wrong.  I have tried it on Easel, and Universal Gcode Sender, and my CNC doesn't move, but it moves if I use the up,down,left,right on my keyboard.
  • wildmack
    I changed to pins 22 and 23, but get the same results as before.
  • wildmack
    I don't see a change when I ground pins 9 and 10 to ground.  I see the change if I turn the encoder, but not by grounding the pins??
  • thomasvdd
    thomasvdd over 6 years ago in reply to wildmack
    So the number never changes from 0 to 1 or higher?
    Try to connect two buttons instead of the rotary encoder and check the output of this code again:
    1 button between pin 9 and ground, 1 button between pin 10 and ground.
    long newScrollPos = encoderScroll.read();
      Serial.println(newScrollPos );
    Do you have a part number of that rotary encoder?
    I am suspecting that you are not using an encoder, but a potentiometer (variable resistor).
    Can you turn the shaft more than 360 degrees or does it have limits? A rotary encoder should be able to continously turn.
  • wildmack
    Hi Thomas, any other ideas?   to me it looks like for some reason the program is never getting to this part:  I tried understanding the logic, but it's way above my head.
          switch(activeAxis){
          case X_AXISr:
          break;
          case Y_AXISr:
            Keyboard.press(KEY_UP);
            Keyboard.release(KEY_UP);
          break;
          case Z_AXISr:
            Keyboard.press(KEY_PAGE_UP);
            Keyboard.release(KEY_PAGE_UP);
        } else {
          switch(activeAxis){
          case X_AXISr:
            Keyboard.press(KEY_LEFT);
            Keyboard.release(KEY_LEFT);
          break;
          case Y_AXISr:
            Keyboard.press(KEY_DOWN);
            Keyboard.release(KEY_DOWN);
          break;
          case Z_AXISr:
            Keyboard.press(KEY_PAGE_DOWN);
            Keyboard.release(KEY_PAGE_DOWN);
        lastScrollPos = newScrollPos;
      if (activeAxis != lastAxis){
        digitalWrite(lastAxisLED, LOW);
        switch(activeAxis){
          case X_AXISr:
            digitalWrite(PIN_LED_X, HIGH);
            lastAxisLED = PIN_LED_X;
          break;
          case Y_AXISr:
            digitalWrite(PIN_LED_Y, HIGH);
            lastAxisLED = PIN_LED_Y;
          break;
          case Z_AXISr:
            digitalWrite(PIN_LED_Z, HIGH);
            lastAxisLED = PIN_LED_Z;
          break;
        lastAxis = activeAxis;
          case SPD_FAST:
          break;
          case SPD_1MM:
            Keyboard.press(KEY_3);
            Keyboard.release(KEY_3);
            digitalWrite(PIN_LED_1MM, HIGH);
            lastSpeedLED = PIN_LED_1MM;
          break;
          case SPD_01MM:
            Keyboard.press(KEY_2);
            Keyboard.release(KEY_2);
            digitalWrite(PIN_LED_01MM, HIGH);
            lastSpeedLED = PIN_LED_01MM;
          break;
          case SPD_001MM:
            Keyboard.press(KEY_1);
            Keyboard.release(KEY_1);
            digitalWrite(PIN_LED_001MM, HIGH);
            lastSpeedLED = PIN_LED_001MM;
          break;
        lastSpeed = activeSpeed;
  • thomasvdd
    See my previous post:
    • Helpful Yes | NoLike (0)Reply
    • Actions
  • wildmack
    OK, connected the two buttons and add the code.  It sends out a continuous series of zeros to the right.  Nothing changes if I ground pins 9 or 10.  I used the same encoder as the one in the project from Element14  Attached are the specs.
    Just seems like it's not reaching the keyboard commands.  It's a brand new teensy, but I guess it could be bad, but even changing the pin assignments I get the same results.  In the program, should the  //Serial.begin(9600);  not be commented out?  I did change it, but got the same results.   ???
    for (int ii = 2; ii < 11; ii++) pinMode(ii, INPUT_PULLUP);
      for (int ii = 14; ii < 21; ii++) pinMode(ii, OUTPUT);
  • thomasvdd
    The Serial.begin(9600); is needed for the serial monitor, just leave it uncommented.
    Since nor the buttons, nor the encoder trigger the encoderScroll.read(); function, I suspect you might be using the wrong library.
    This is the one I am using: https://github.com/PaulStoffregen/Encoder
    Normally, Arduino stores the libraries under Document/libraries/
    Remove all existing encoder libraries from this folder (if any) and replace with the one from the link above.
  • wildmack
    Nope, still no change??
  • thomasvdd
    I'm running out of ideas...
    Include those lines and upload of picture of the serial monitor when turning the encoder:
      if (digitalRead(PIN_ENC_A) == LOW){
         Serial.println("ENC A LOW TRIGGERED");
      if (digitalRead(PIN_ENC_A) == HIGH){
         Serial.println("ENC A HIGH TRIGGERED");
      if (digitalRead(PIN_ENC_B) == LOW){
         Serial.println("ENC B LOW TRIGGERED");
      if (digitalRead(PIN_ENC_B) == HIGH){
         Serial.println("ENC B HIGH TRIGGERED");
    Also, in File>Preferences, enable these settings:
    Share a screenshot of the output.
  • wildmack
    Don't give up on me LOL
    OK, I put the text after this:
    I don't see what checking the two boxes did?
    Here are the screen shots, it changed based on turning the encoder.  But, it was always printing something even when I wasn't pushing a button or turning the encoder??
  • wildmack
  • thomasvdd
    When did you get the
    "ENC A HIGH TRIGGERED" and
    "ENC B HIGH TRIGGERED" ?
    If that happens when the encoder is turned, the encoder is connected correctly.
    In that case, the problem lies with the encoder library.
    I would like to see the output of this window when compiling and uploading. All of it image
