Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15933 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • thomasvdd
    thomasvdd over 6 years ago in reply to wildmack
    See my previous post:
    So the number never changes from 0 to 1 or higher?
    Try to connect two buttons instead of the rotary encoder and check the output of this code again:
    1 button between pin 9 and ground, 1 button between pin 10 and ground.
    long newScrollPos = encoderScroll.read();
      Serial.println(newScrollPos );
    Do you have a part number of that rotary encoder?
    I am suspecting that you are not using an encoder, but a potentiometer (variable resistor).
    Can you turn the shaft more than 360 degrees or does it have limits? A rotary encoder should be able to continously turn.
    • Helpful Yes | NoLike (0)Reply
    • Actions
  • wildmack
    wildmack over 6 years ago in reply to thomasvdd
    Hi Thomas, any other ideas?   to me it looks like for some reason the program is never getting to this part:  I tried understanding the logic, but it's way above my head.
      if (abs(newScrollPos - lastScrollPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
        if (newScrollPos - lastScrollPos > -1){ // positive increase
          switch(activeAxis){
          case X_AXISr:
            Keyboard.press(KEY_RIGHT);
            Keyboard.release(KEY_RIGHT);
          break;
          case Y_AXISr:
            Keyboard.press(KEY_UP);
            Keyboard.release(KEY_UP);
          break;
          case Z_AXISr:
            Keyboard.press(KEY_PAGE_UP);
            Keyboard.release(KEY_PAGE_UP);
        } else {
          switch(activeAxis){
          case X_AXISr:
            Keyboard.press(KEY_LEFT);
            Keyboard.release(KEY_LEFT);
          break;
          case Y_AXISr:
            Keyboard.press(KEY_DOWN);
            Keyboard.release(KEY_DOWN);
          break;
          case Z_AXISr:
            Keyboard.press(KEY_PAGE_DOWN);
            Keyboard.release(KEY_PAGE_DOWN);
        lastScrollPos = newScrollPos;
      if (activeAxis != lastAxis){
        digitalWrite(lastAxisLED, LOW);
        switch(activeAxis){
          case X_AXISr:
            digitalWrite(PIN_LED_X, HIGH);
            lastAxisLED = PIN_LED_X;
          break;
          case Y_AXISr:
            digitalWrite(PIN_LED_Y, HIGH);
            lastAxisLED = PIN_LED_Y;
          break;
          case Z_AXISr:
            digitalWrite(PIN_LED_Z, HIGH);
            lastAxisLED = PIN_LED_Z;
          break;
        lastAxis = activeAxis;
      if (activeSpeed != lastSpeed){
        digitalWrite(lastSpeedLED, LOW);
        switch(activeSpeed){
          case SPD_FAST:
            Keyboard.press(KEY_4);
            Keyboard.release(KEY_4);
            digitalWrite(PIN_LED_FAST, HIGH);
            lastSpeedLED = PIN_LED_FAST;
          break;
          case SPD_1MM:
            Keyboard.press(KEY_3);
            Keyboard.release(KEY_3);
            digitalWrite(PIN_LED_1MM, HIGH);
            lastSpeedLED = PIN_LED_1MM;
          break;
          case SPD_01MM:
            Keyboard.press(KEY_2);
            Keyboard.release(KEY_2);
            digitalWrite(PIN_LED_01MM, HIGH);
            lastSpeedLED = PIN_LED_01MM;
          break;
          case SPD_001MM:
            Keyboard.press(KEY_1);
            Keyboard.release(KEY_1);
            digitalWrite(PIN_LED_001MM, HIGH);
            lastSpeedLED = PIN_LED_001MM;
          break;
        lastSpeed = activeSpeed;
  • thomasvdd
  • wildmack
    I don't see a change when I ground pins 9 and 10 to ground.  I see the change if I turn the encoder, but not by grounding the pins??
  • wildmack
    I changed to pins 22 and 23, but get the same results as before.
  • wildmack
    Interesting.  I included this in the program
      if (digitalRead(PIN_ENC_A) == LOW){
    Serial.println("ENC A TRIGGERED");
    if (digitalRead(PIN_ENC_B) == HIGH){
    Serial.println("ENC B TRIGGERED");
    Here are the results.  when I'm not turning thr encoder, it keeps putting out 00000000000000
    And I included this where it should be outputting the left, right, up, down
    Serial.println("NEW_NEW");
    but "NEW_NEW" never showed up in the serial monitor.  For some reason, it's not going past this line
          switch(activeAxis){
    Any more ideas??  Thanks Dave...........
  • thomasvdd
    As a last suggestion for today:
    The code should also work jf you add a switch between pin 9 and ground or pin 10 and ground. This should give the same result as using an encoder (but less practical of course). By trying this we can rule out a faulty encoder.
  • thomasvdd
    You can also try soldering it to 2 other pins.
    Change the used pin numbers in the code:
    #define PIN_ENC_A     9
    #define PIN_ENC_B     10
    And add these two lines in setup:
    void setup() {
         pinMode(PIN_ENC_A, INPUT_PULLUP);
         pinMode(PIN_ENC_B, INPUT_PULLUP);
  • thomasvdd
    Wiring looks good too.
    Try adding a println here:
    The number should increase every time you turn the encoder.
    As an additional check, also add these lines (will trigger if the encoder gives a pulse):
  • wildmack
    Look OK?
