Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17912 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • chewkimsoon
    chewkimsoon over 6 years ago
    Excellent project.  Just exactly what I was looking but I am a non-techie and know zero about coding.
    May I raise a few tweaks, as follows:
    (1) Improved presentation.  The date/time of the calendar by the left side seems a bit small.  How about shortening to DD-MMM and making font bigger (my eyesight is not as good as before).  In fact, bigger font overall would make the glancing quicker.
    (2) Aesthetics comment.  Is there a power connector that would not stick out to the right side of the frame?
    (3) Is it possible to install a powerbank on the other unoccupied side so that the unit is standalone, rather than tethered to the power point? No need to have complicated electronics as the powerbank can be removed to charge when needed.
    (4) Portrait mode.  Is that possible?  How would it look like?
    I just got my first raspberry pi and not even got the OS loaded.  Something I wanted to get started.
    Thanks for the inspiration.
    KS
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to chewkimsoon
    Hi Kim,
    Thank you, was really fun to build and share with you all!
    1. Great suggestion on the date format. That would shrink the width, but when changing the size of the font it will increase the height as well. If you look at the way its squeezed in there, there is a pixel or two seperating the date from the time, and a pixel or two on the top and bottom padding. Might be a real tight fit, but might be able to increase the size just a tiny bit.
    2. Two ways to not have the power connector stick out the side. A) Mount the raspberry pi on the other side. B) Get a right angle power connector for the raspberry pi. That would either have it go up or down instead of straight out, depending on left hand or right hand right angle connector.
    3. Yes! Raspberry pi will run just fine on a power bank (as long as it has a 2A output).
    4. It is possible in the way that anything is possible! However, I dont think there would be much space for descriptions of tasks or calendar items. I thought about portrait, but opted for landscape to get the most real estate for descriptions. Answer is: it would take complete reformatting to make it portrait mode. So not easily. Sorry!
    Awesome on your first Raspberry Pi! They are a ton of fun to work with. Lots of good resources and inspiration around here, see you around!
    Thanks,
    -Kaleb
  • KalebTheMaker
    Hi Kim,
    Thanks,
    -Kaleb
