Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35800 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • benaim
    Very nice I just ordered all that I need, but for elevation I will try another thing... image
    Why not use the Hall effect sensor for elevation instead of a big gear ? image
    I think is more precise, and less mechanical...
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to benaim
    It's just the route I took, Initial idea was to go with a timing belt for more precision, but... space.
    What hall effect sensor did you go with?
    -Kaleb
  • mrpomme
    mrpomme over 6 years ago in reply to benaim
    can you share detial about your implementation as I'm in belgium, I'm pretty interrested to knwo how you done it and which all materials and code needed.
  • dnl40
    dnl40 over 6 years ago in reply to benaim
    Philippe, I am very interested on seen tour code an electrical schematics, mostly for educational purposes, I am learning myself and i got the idea on kaleb code. What I want to see mostly is how you mangaged the correlation of the analog imput from the hall sensor and the magnets mounting. Thanks to kaleb and you for an amazing project. I hope some day I will be up to the task.
  • benaim
    benaim over 6 years ago in reply to dnl40
    I am in holidays now
    See you next week
  • dnl40
    Relax and enjoy!
  • KalebTheMaker
    That looks great Philippe! Well done, I love the hall effect update!
    Is it performing well for you?
    -Kaleb
  • benaim
    Work very well :-)
    I will send one part of code about hall sensor when I come back from my holidays ;-)
  • benaim
    Here the part my code for SS495a image
    [code]
    void Update_SS495a()
        SS495a_ReadValue = analogRead(SS495a);
        static int16_t SS495a_ReadValue_Pre = 512;
        static const uint8_t SS495a_Filter = 15;
        static int16_t SS495a_Value_Min = 1023;
        static int16_t SS495a_Value_Max = 0;
        const int16_t Middle        = 503;    // Find without magnet
        const int16_t DeadZone_Up   = 40;     // For mechanic exercice
        const int16_t DeadZone_Down = 40;     // For mechanic exercice
        int32_t SS495a_Value_Up;
        int32_t SS495a_Value_Down;
        static float SS495a_Step_Up = 1;
        static float SS495a_Step_Down = 1;
        static float SS495a_Value_Up_float;
        static float SS495a_Value_Down_float;
        static int16_t SS495a_ToSend;
        static int16_t SS495a_ToSend_Pre = -1;
        // Auto Calibration after Power, Move Up and down to take Max and Min after Power On ( Plug USB )
        if (SS495a_Value_Min > SS495a_ReadValue)
            SS495a_Value_Min = SS495a_ReadValue;
            SS495a_Step_Down = 512.0 / (float)(Middle - (SS495a_Value_Min + DeadZone_Down));
        if (SS495a_Value_Max < SS495a_ReadValue)
            SS495a_Value_Max = SS495a_ReadValue;
            SS495a_Step_Up = 512.0 / (float)((SS495a_Value_Max - DeadZone_Up) - Middle);
        bool IsUp = SS495a_ReadValue > Middle;
        if (IsUp)
            SS495a_Value_Up = SS495a_ReadValue - Middle;
            SS495a_Value_Down = 0;
        else
            SS495a_Value_Down = Middle - SS495a_ReadValue;
            SS495a_Value_Up = 0;
        if ( SS495a_ReadValue  > SS495a_ReadValue_Pre + SS495a_Filter | SS495a_ReadValue  < SS495a_ReadValue_Pre - SS495a_Filter)
            SS495a_Value_Up_float = (float)SS495a_Value_Up;
            SS495a_Value_Down_float = (float)SS495a_Value_Down ;
            SS495a_ToSend = (-(SS495a_Value_Down_float * SS495a_Step_Down) + (SS495a_Value_Up_float * SS495a_Step_Up)) + 512;
            if (SS495a_ToSend > 1023)
                SS495a_ToSend = 1023;
            if (SS495a_ToSend < 0)
                SS495a_ToSend = 0;
            if (SS495a_ToSend_Pre != SS495a_ToSend) // Send Only if different value
                Joystick.setRxAxis(SS495a_ToSend);
                SS495a_ToSend_Pre = SS495a_ToSend;
            SS495a_ReadValue_Pre = SS495a_ReadValue;
    [/code]
    @Webmaster : The Balise [code][/code] don't work image Maybe it's a good idea to activate image
  • mrpomme
    I will try it to with the hall effect sensor it seem better by design and avoid those pot , can you shar eyour code/ print for the 2 magnet piece and sensor holder (I see you user a lot of glue image
  • benaim
    benaim over 6 years ago in reply to mrpomme
    The ( hot) glue is only to fix wires image and the SS495a...
    You can find the code for double magnet below this post.
    If you want my STL of magnets support send me your email
  • dnl40
    That is awsome Philippe, thanks. I am low on cash for now but in a couple of months I will be beginning to buy parts, (for now i am just doing the pricing). If during the construction phase i get stuck I hope is ok to give you a shout out with a question or two jejejeje. Thanks again!
  • dnl40
