Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35765 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • benaim
    Very nice I just ordered all that I need, but for elevation I will try another thing... image
    Why not use the Hall effect sensor for elevation instead of a big gear ? image
    I think is more precise, and less mechanical...
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to benaim
    It's just the route I took, Initial idea was to go with a timing belt for more precision, but... space.
    What hall effect sensor did you go with?
    -Kaleb
  • fcaballerog
    fcaballerog over 6 years ago in reply to benaim
    Hello Philippe MousKito, could you pass us the modified files and the PCB of your project to be able to adapt it, it looks great, something else, where did you get the components from? buttons etc ... could you give us the list?
    Thank you very much the project looks very nice ..
  • fcaballerog
    Thank you very much the project looks very nice .. I would like to be in contact with you if possible ... Thank you very much ..
  • benaim
    benaim over 6 years ago in reply to fcaballerog
    I said before image , if you want finish this project, it's better to have one 3D Printer, and have notions in prog ( Arduino or other, Arduino it's the best, for me, way to connect your project like a joystick )
    Thinking, take SLT files, print by one Co, and be able to finish this project, no way... because you need to adapt to you config...
    Hardware:( The hardest part )
    For example, the aluminum tube, I never find one ( in France ) in 35 mm so I Ordered one in carbon, but I never received :-(
    So I took one PVC Tube and I make adapter between the base ans head image with mine 3D printer ( Again image )
    Software: ( The hardest part for other persons image )
    Of course, I started with @Kaleb sources, but I changed something to adapt to my needs image
    - Clicks / Double Clicks / Rotation range for the Rotary Encoder.
    - Reactions with buttons.
    I done this project for fly with X-Plane.
    But If you haven't any ideas of software ( Or  / And  ) Is not for you, sorry image
    So, if you want really, and really sur, I can send, some STL files for do  something, but say me where ....
  • fcaballerog
    Buenas tardes Philippe MousKitos, tengo una impresora 3D y una fresadora CNC, por esa parte no hay problema, también tengo conocimientos de programación y conozco el arduino, pero si ya has hecho pruebas y lo estás haciendo bien, sería bueno si no tiene problemas para renunciar a los archivos ... pasando sus archivos STL y el correo electrónico que utilizó ... para que podamos ver su diseño y adaptarlo con respecto al original ...
    Muchas gracias..
  • benaim
    OK, I will send you some files tomorrow, include my firmware
    You can delete your email, to prevent any spam... I wrote your email in my contacts
  • mrpomme
    mrpomme over 6 years ago in reply to benaim
    can you share detial about your implementation as I'm in belgium, I'm pretty interrested to knwo how you done it and which all materials and code needed.
  • dnl40
    dnl40 over 6 years ago in reply to benaim
    Philippe, I am very interested on seen tour code an electrical schematics, mostly for educational purposes, I am learning myself and i got the idea on kaleb code. What I want to see mostly is how you mangaged the correlation of the analog imput from the hall sensor and the magnets mounting. Thanks to kaleb and you for an amazing project. I hope some day I will be up to the task.
  • benaim
    benaim over 6 years ago in reply to dnl40
    I am in holidays now
    See you next week
  • dnl40
    Relax and enjoy!
  • KalebTheMaker
    That looks great Philippe! Well done, I love the hall effect update!
    Is it performing well for you?
    -Kaleb
  • KalebTheMaker
    -Kaleb
  • benaim
    Work very well :-)
    I will send one part of code about hall sensor when I come back from my holidays ;-)
  • Charlienofun
    Charlienofun over 5 years ago in reply to benaim
    Hi Philippe - can you advise on the magnet sizes I should use? (first time using a hall sensor like this). I thought the potentiometer I had was having a short enough rotation but not in reality imageimage
  • benaim
    benaim over 5 years ago in reply to Charlienofun
    I use square magnet 5x5x5.
    I make this choice because many round magnets are not polarised correctly, and too much sellers send bads magnets
    NB: now I use AS5048a it's more precise than SS495a, of course it's working now in SPI interface, not in analog.
  • Charlienofun
    Thanks, benaim, I will go for the bigger square magnets. Did you have to play with magnet distance a lot to get the full range from 45 degrees of rotation? Maybe I should make my mount adjustable instead of hard 45. Interesting you moved to AS5048a, I'm on a Pro micro (planning to fly a quadcopter) and the SPI pins are not used so I could try that as well (will check the datasheet and order one to experiment with as well). Thanks for the info!! Great project KalebTheMaker
  • benaim
    I can see on your second picture, the distance is good for AS5048a but for SS495a is not the good way, SS495a mesure the distance, not angle like AS5048a
  • Charlienofun
    Thanks, benaim I see now the AS5048a is popular for brushless gimbal position. Many PCBs like this I could use in place of the one I have with the potentiometer now. Will pause on the linear sensor and look into this further. Seems like a better solution! Much appreciate the info!! image
  • Charlienofun
    Charlienofun over 5 years ago in reply to Charlienofun
    I might try the AS5600 - lots of cheap kits with magnets and examples of it working on youtube.
    https://www.ebay.com/itm/AS5600-Magnetic-Encoder-Magnetic-Induction-Angle-Measurement-Sensor-IIC-Module/164243118854?_tr…
  • benaim
    Yes I use this board (https://m.fr.aliexpress.com/item/1005001622340192.html) in SPI mode, not analog...
    In SPI is very accurate, in particular with low angles, for us only 45° maybe less.
    Don't forget, you need 4 pins for SPI ( SCLK / MISO /MOSI) but one more for control each SPI device, same if you have only one...
    I'm now on my smartphone, tomorrow, when I will be on my computer, I will send, here, the link of library that I use.
  • Charlienofun
    Ah, I will look at the lib when you get a chance to post it. No rush will be a while before I get a sensor board from China. I was planning to be lazy and try the analog mode of 5600, but first setting its range with i2c so it will have a full 0-5v from whatever rotation it can sense (I got the idea from this demo video from AMS) If that works I don't have to rewrite my existing code image Did you bother with trying this or just went straight to reading the angle over SPI?
  • benaim
    The Lib SPI for AS5048a is here : https://github.com/eborghi10/AS5048A  image
    I to read the angle over SPI, it's more accurate image
