Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35830 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • aosatx04
    aosatx04 over 5 years ago in reply to fright
    Thanks Mick,
    Yeah still getting message. Buts its probably something to do with programming logic....
    Just going to crack open an adruino books and start from basics...
    thanks for input greatly appreciated...
  • fright
    fright over 5 years ago in reply to aosatx04
    Hi. You just need to download the library.
    https://www.arduino.cc/reference/en/libraries/joystick/
  • aosatx04
    Kaleb,
    Quick question please?
    Above is what I have so far but could you please clarify where your getting Joystick.h file. When I attempt to verify in Ide editor I get error message "Joystick_ does not name type".
    thanks for your help and especially thanks for your shared information on Heli Collective:)
    Oh Yeah please understand i've always been more of a hardware guy and can build hardware and wire it up like its candy:) software on the other hand is kinda my weak-point... So please excuse the rookie question....
    respectfully
    Andrew
  • gainey
    gainey over 5 years ago
    Hi everyone instead of using arduino I have one of these boards BU0836X 12-Bit Joystick Board [BU0836X] - 49.99GBP : Leo Bodnar, Simulator Electronics
    If I use this board do I need to change the Bourns encoder for the collective to raise and lower and will I also need to change the small gear to something else ?
    any suggestions would be great will everything work ok with this board
    I also noticed with this board it shows to wire the ground for each switch / button strange
  • gainey
    hi this looks great, is their an exploded view or a build video as the above video is sped up so hard to follow what goes where
    thankyou
  • parasol33
    parasol33 over 5 years ago
    Hi all, i have begun a similar project to make it work first as a switch board with an Arduino Leonardo and i will be moving on to implement this collective once all the elements seem to work fine. I have a simple question about using toggle switches [ON-ON] in such a setup, and not momentary, and the question is how do you manipulate the time release on the switch input so as not to register as continous press...The point being, switch in one direction press x button for y ms, other direction press z button for t ms...Any pointers on how to code this? Thanks again for such a brilliant project and idea. I would appreciate any input on this as i am just beggining to delve into the workings of arduino and i am constantly learning.
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to kraythorne
    That is very odd, when I load that page in chrome (and in incognito, not logged in) it shows a button just above the spatial block on the upper right hand side that says "download" from there you can download many formats of the files.
    I have added the .fbx file to github for download. Link to github is above.
    Let me know if that helps,
    -Kaleb Clark
  • kraythorne
    kraythorne over 5 years ago in reply to KalebTheMaker
    I can see the design in the fusion 360 page, but cannot work out how to download the fusion files - can you advise which buttons to use to download the files (See my screenshot). Thanks for coming back to me image
  • nzcypher819
    nzcypher819 over 5 years ago in reply to KalebTheMaker
    Hi Kaleb,
    Any chance you could upload the Eagle schematic file please? Im going down the route of getting the board printed as my soldering skills are sub-par. Thanks in advance.
  • KalebTheMaker
    Hi Steve,
    Did you get all the files you needed?
    -Kaleb
