Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35800 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to e14 Contributor
    How are you downloading the DXF? If you try to right click it and "save file as" it will save a html page. If you clone the repository and open from there it should work.
    I just cloned the repo and opened the .DXF file in lightburn and it opened no problem.
    -Kaleb
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to gtg938v
    Hi there,
    I just downloaded the FBX from github, imported it and opened it. I do not think its corrupted. I am running the latest release of F360 currently. What is the failure that your fusion 360 reports?
    e14 Contributor over 5 years ago
    Do anybody have the BasePlate.dxf working? I always get a error if I try to open it.
    Thank you
  • webitman
    webitman over 5 years ago in reply to gtg938v
    Thank you very helpful , have managed to download and instal "ClickEncoder, Joystick, and TimerOne"  libraries needed for this project,
    but it still won't verify? I am getting a load of things that need doing now and I am becoming confused, in the ACE128,h file its asking for ACE128_MCP23008 to be defined but it already is,
    I have printed out the error list as a text file and it's 5 pages long.
    Paul
  • gtg938v
    gtg938v over 5 years ago in reply to webitman
    Paul,
    Check this video out, should help!
    https://youtu.be/igdBT0hwsJc
  • webitman
    Absolutly brilliant design Kaleb, I have actualy built this and ready to fly,
    BUT as I am new to the Arduino IDE i'm having trouble uploading the code as I keep getting : Arduino: 1.8.13 (Windows 10), Board: "Arduino Micro" CollectiveControl:1:10: fatal error: ClickEncoder.h: No such file or directory #include <ClickEncoder.h>
    Can you point me in the right direction please as to the correction of this problem.
    Thanks Paul
  • gtg938v
    gtg938v over 5 years ago in reply to e14 Contributor
    I submitted the file to Autodesk Customer Support and they said,
    "Thanks for the files you added to this support request. I have been able to reproduce the issue on my computer and also with several Autodesk software able to open FBX files. I can confirm that this file is corrupted."
    I'll let you know if they have any fixes on their end.
    In the mean time, Kaleb do you mind trying another upload of the fusion file? Maybe in a different file format?
    Thanks!
    Rich
    Hi first of all thank you this is amazing.
    But I cant open the Base DXF File and cant find the Fusion files. Am I doing something wrong?
  • aosatx04
    aosatx04 over 5 years ago in reply to gtg938v
    Richard,
    I had no problems with fbx file. I'm currently using the following version of Fusion360;
    2.09.9930
    Active Plan: Fusion 360, Subscription
    macOS 10.16.0
  • gtg938v
    gtg938v over 5 years ago in reply to KalebTheMaker
    Kaleb,
    For some reason when I try to open the fbx file from github in fusion it gives me a failure. It's as if the file is corrupted? Or maybe it's the wrong version?
    Thank you for the help, I really love your project, and thank you for making it publically available.
    Rich
