Project Videos
  • Project Videos
Project Videos
Documents How Do BattleBots Work? In the Pit with HyperShock -- Episode 654
  • Date Created: 16 May 2024 4:08 PM Date Created
  • Last Updated Last Updated: 17 May 2024 9:50 AM
  • Views 2056 views
  • Likes 8 likes
Get an inside look at HyperShock, the impressive robot engineered by Team HyperShock for Battlebots. In this interview, we'll dive into the technical details and design elements that set HyperShock apart in the competitive robotics arena. From its evolution to its standout features, join us as we uncover the story behind HyperShock's journey to the Battlebots competition in conjunction with sponsorship support from multicomp pro and their line of products.
Watch the Video:
James gets the opportunity to interview Will from Team HyperShock at the Battlebots competition in Las Vegas to delve into the technical intricacies of their formidable creation. HyperShock, weighing in at 250lb, is a fighting robot that commands attention with its bright yellow blur as it tears through opponents on the Battlebots stage.
Will provides valuable insights into the design and evolution of HyperShock, revealing that it has undergone six iterations since its inception in 2015. The current version represents the team's dedication to achieving the perfect balance of power, efficiency, and reliability. With a few tweaks from last year's model, HyperShock stands as a testament to the team's engineering prowess and relentless pursuit of perfection.
A key highlight of the conversation is the discussion on the use of brushless motors in HyperShock. Will explains how these motors offer superior efficiency and power density compared to traditional brushed motors, contributing to the robot's impressive performance in the arena. Additionally, the implementation of external encoders ensures precise position sensing and low-end torque, essential for delivering devastating blows to opponents.
HyperShock's modular construction is another technical feat worth noting. With quick assembly and disassembly of critical components such as drive modules and weapon systems, the team can adapt their strategy on the fly to outmanoeuvre and outwit their opponents. This modular approach not only enhances flexibility but also facilitates rapid iteration and optimization, keeping HyperShock at the forefront of competitive robotics.
Did you catch the series and watch BattleBots? Which bot did you root for? Or maybe you’re more familiar with Robot Wars in the UK? Have you used any of the same multicomp pro products that Team HyperShock have used? Let us know in the comments below.
Download & Links:
  •  HyperShock AMA with Will Bales of Team HyperShock in Battlebots (Win a Soldering Kit!)
  • Team HyperShock
Build like Team HyperShock with their multicomp PRO kit
Soldering Re-Work Station, 900W MULTICOMP PRO 1 Buy Now
Benchtop Soldering Fume Extractor, ESD-Safe MULTICOMP PRO 1 Buy Now
Wide Range Bench Power Supply, 60V, 15A TENMA 1 Buy Now
Handheld Digital Multimeter, True RMS MULTICOMP PRO 1 Buy Now
Handheld Digital Tachometer MULTICOMP PRO 1 Buy Now
Thermal Imager, Handheld, 80x60 Resolution MULTICOMP PRO 1 Buy Now
Multi-Functional VDE Cable Cutter DURATOOL 1 Buy Now
Electronic Cutters, Flush, 150mm MULTICOMP PRO 1 Buy Now
Electronic Cutters, Diagonal, 180mm DURATOOL 1 Buy Now
Electronic Cutters, Long Needle Nose, 150mm MULTICOMP PRO 1 Buy Now
Cable & Wire Spool Rack PRO POWER 1 Buy Now
High Temperature Masking Tape, 15mm MULTICOMP PRO 1 Buy Now
High Temperature Masking Tape, 6mm MULTICOMP PRO 1 Buy Now
Aluminium Foil Tape, Non-Conductive, 45m PRO POWER 1 Buy Now
Tinned Copper Wire, 138m MULTICOMP PRO 1 Buy Now
Heatshrink Tubing, Adhesive Lined, 6", 3:1, Black PRO POWER 1 Buy Now
Heatshrink Tubing, Adhesive Lined, 6", 3:1, Black MULTICOMP PRO 1 Buy Now
Soldering Tip, Conical, 3.2mm MULTICOMP PRO 1 Buy Now
Soldering Tip, Chisel, 4.6mm MULTICOMP PRO 1 Buy Now
Soldering Tip, Chisel, 2.4mm MULTICOMP PRO 1 Buy Now
Soldering Tip, Pointed, 0.5mm MULTICOMP PRO 1 Buy Now
Soldering Tip, Knife, 15mm MULTICOMP PRO 1 Buy Now
element14 presents
element14 presents  |  About James |  Project Videos
  • Electrical engineering insights
  • brushless motors
  • Competitive engineering
  • Team HyperShock
  • Battlebots competition
  • HyperShock evolution
  • Pragmatic design strategies
  • e14p_JBE
  • Performance optimization
  • Engineering insights into HyperShock
  • Precision position sensing
  • Fighting machine design
  • Cutting-edge technology
  • Technical specifications of HyperShock
  • Modular construction
  • Innovation in Battlebots
  • friday_release
  • koudelad
    koudelad over 2 years ago
    Great interview. It looks like the team is travelling with a full featured workshop to handle all possible situations.
    I had to look up a few videos of the actual battles and it is mechanically very brutal :)
    Tip: HyperShock vs Gigabyte
  • koudelad
