WorkBench Wednesdays
  • WorkBench Wednesdays
Documents How to Program Test Tools with Python - Workbench Wednesdays 66
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 28 Dec 2022 7:30 PM Date Created
  • Last Updated Last Updated: 14 Jun 2024 5:21 PM
  • Views 37220 views
  • Comments 57 comments
If your test tools have a USB or LAN port, there is a good chance that they support SCPI. Using pyVISA, you can write automated test programs for most equipment without expensive software. This video explains terms like VISA, SCPI, and USBTMC. Then it shows how to use Python and pyVISA to connect to test equipment with a Raspberry Pi (or any Linux computer.)
Watch the Video:
Bonus Content:
  • PyVISA
  • RsInstrument, R&S Python Implementation (also uses pyvisa!)
  • Keysight IO Suite
  • R&S VISA
  • Standard Commands for Programmable Instruments (SCPI) Syntax. (web archive mirror IVI Foundation)
  • SCPI Specification
  • Blog post, Early peak at bode plot script
  • Snapshot of Code
  • Github link for code
Bill of Material:
34465A Bench Multimeter, Truevolt, 6.5 digit Keysight 1 Buy Now
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
Bench Oscilloscope - 200 MHz, 1 GSa/s, 14-bit, AFG, DMM Multicomp Pro 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
HMC8043 Bench Power Supply, Programmable, 3 Output, 0 V, 32 V, 3 A Rohde & Schwarz 1 Buy Now
RPI400-KIT-US Raspberry Pi 400 Kit, BCM2711, Quad-Core, 64bit, ARM, Cortex-A72, US PSU, US Keyboard Layout Raspberry Pi 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • Remote Programming
  • VXI
  • gpib
  • USBTMC
  • visa
  • lxi
  • IVI
  • scpi
  • baldengineer
    baldengineer over 2 years ago in reply to zack_el +3
    For some reason, posting these instructions here causes errors. You need to create a udev rule. Here's how to do it: www.baldengineer.com/accessing-usb-instruments-with-pyvisa-on-linux.html
  • mayermakes
    mayermakes over 3 years ago +1
    ohoh..I sense some automation i have to implement....
  • mayermakes
    mayermakes over 3 years ago in reply to baldengineer +1
    if anyone has a gripe with using a pi, I can warmly recommend doing it with a Beaglebone black. this also gave me the idea of maybe developing some sort of plug and play box with a pocketbeagle that reads…
  • zack_el
    zack_el over 2 years ago in reply to baldengineer
    Dear Mr. James, I would like to express my sincere gratitude for your support. Thanks to your help, it is now working. I greatly appreciate your patience and expertise. image
  • baldengineer
    Jan Cumps over 2 years ago in reply to Ayoub_Ghaoui
    One action you could take, is to wrap the check for IDN in an exception handler, and ignore instruments that don't reply.
    If an IDN is returned, you know you're talking to an existing, and connected, test instrument.
    Both.
  • Ayoub_Ghaoui
    Ayoub_Ghaoui over 2 years ago in reply to Jan Cumps
    Do you use Windows or Linux operating system?
    Jan Cumps over 2 years ago in reply to zack_el
    ASRL/dev...   , I believe, is not a real device. It's one of the entries generated by NI-VISA software.
    They pop up in my system too, although no device is connected.
  • zack_el
  • baldengineer
    Well, the good news is that Linux is enumerating the device. But for some reason, pyvisa-py cannot see it.
    My new guess is that it is a permissions issue.
    Outside of VScode (or whatever the IDE is), run the python script as root to see if ResourceManager shows it.
  • Ayoub_Ghaoui
    Ayoub_Ghaoui over 2 years ago in reply to zack_el
    I have the same problem!!!!
  • zack_el
    zack_el over 2 years ago in reply to zack_el
