WorkBench Wednesdays
  • WorkBench Wednesdays
Documents How to Program Test Tools with Python - Workbench Wednesdays 66
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 28 Dec 2022 7:30 PM Date Created
  • Last Updated Last Updated: 14 Jun 2024 5:21 PM
  • Views 37224 views
  • Comments 57 comments
If your test tools have a USB or LAN port, there is a good chance that they support SCPI. Using pyVISA, you can write automated test programs for most equipment without expensive software. This video explains terms like VISA, SCPI, and USBTMC. Then it shows how to use Python and pyVISA to connect to test equipment with a Raspberry Pi (or any Linux computer.)
Watch the Video:
Bonus Content:
  • PyVISA
  • RsInstrument, R&S Python Implementation (also uses pyvisa!)
  • Keysight IO Suite
  • R&S VISA
  • Standard Commands for Programmable Instruments (SCPI) Syntax. (web archive mirror IVI Foundation)
  • SCPI Specification
  • Blog post, Early peak at bode plot script
  • Snapshot of Code
  • Github link for code
Bill of Material:
34465A Bench Multimeter, Truevolt, 6.5 digit Keysight 1 Buy Now
TL081 - JFET General Purpose, 4 MHz SOIC-8 ST Microelectronics 1 Buy Now
Bench Oscilloscope - 200 MHz, 1 GSa/s, 14-bit, AFG, DMM Multicomp Pro 1 Buy Now
MXO4 - 4 Channel Oscilloscope 200 MHz Rohde & Schwarz 1 Buy Now
HMC8043 Bench Power Supply, Programmable, 3 Output, 0 V, 32 V, 3 A Rohde & Schwarz 1 Buy Now
RPI400-KIT-US Raspberry Pi 400 Kit, BCM2711, Quad-Core, 64bit, ARM, Cortex-A72, US PSU, US Keyboard Layout Raspberry Pi 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • Remote Programming
  • VXI
  • gpib
  • USBTMC
  • visa
  • lxi
  • IVI
  • scpi
  • baldengineer
    baldengineer over 2 years ago in reply to zack_el +3
    For some reason, posting these instructions here causes errors. You need to create a udev rule. Here's how to do it: www.baldengineer.com/accessing-usb-instruments-with-pyvisa-on-linux.html
  • mayermakes
    mayermakes over 3 years ago +1
    ohoh..I sense some automation i have to implement....
  • mayermakes
    mayermakes over 3 years ago in reply to baldengineer +1
    if anyone has a gripe with using a pi, I can warmly recommend doing it with a Beaglebone black. this also gave me the idea of maybe developing some sort of plug and play box with a pocketbeagle that reads…
  • baldengineer
    The DP832 does not require NI's VISA. None of Rigol's tools do. Any VISA driver can connect to to the DP832.
  • zack_el
    zack_el over 2 years ago
    a excellent video. My goal is to program and control the Rigol DP832 DC power supply using a Raspberry Pi 5 and Python via the USB interface. This requires the NI-VISA driver. However, the driver could not be installed on the Raspberry Pi because it is not compatible with the ARM architecture. Now I am wondering how you managed to control your device via USB and LAN interfaces. Do you not need the NI-VISA driver for that?"
  • baldengineer
    baldengineer over 2 years ago in reply to Aed
    Here is the latest code: github.com/.../baldee-plot
    And here's another pyVISA project. It uses a power supply and load to calculate / plot the efficiency of a DC-DC converter with varied load: https://github.com/baldengineer/bald-efficiency. (Video on this: DC-to-DC Converter Efficiency: How to Automate Measurements and Improve Performance - Workbench Wednesdays 72.)
    beacon_dave over 2 years ago in reply to Aed
    Download page is here:
    /challenges-projects/element14-presents/workbenchwednesdays/m/files/147059
    click the blue download button
    ( tariq.ahmad  code link looks like it needs updating )
  • Aed
    Aed over 2 years ago
    I just signed up but when I click on the Code link the page is not found.  Where can I find the Python code?
  • baldengineer
    baldengineer over 3 years ago in reply to Saisri
    This is a generic TCP/IP problem and not specific to Python or pyvisa.
    However, if the instruments support LXI or VXI11, then you can follow the instructions in "Ethernet resources" to auto-discover them.
    https://pyvisa.readthedocs.io/projects/pyvisa-py/en/latest/installation.html
  • Saisri
    Saisri over 3 years ago
    Hello, Thanks for the video. I have a small question regarding pyvisa programming with LAN.
    I can connect with different Siglent devices such as SDM3055 multimeter, SDL1020X-E electronic load, SPD3303X-E Power Supply, etc. I am connecting all these devices with different LAN cables and can see the IP addresses of each device individually and can work with them using pyvisa without any problem.
    My doubt is, can I get the IP addresses of all these devices automatically with Python without finding them manually? Because, I could not see the IP addresses of these devices with any of the commands such as 'arp -a', 'ifconfig', or any other way.
    Once I connect them by manually entering the IP addresses, I can see those IP's later If I use the 'arp -a' command, etc.
    Q: is there any way to detect and connect automatically using LAN?
    Thanks and Best regards,
    Sai
  • baldengineer
    baldengineer over 3 years ago in reply to Kronus
    In general, the name from list_resources() is the name you need to use. All of the example resources names are from me copy/pasting them.
  • Kronus
    Kronus over 3 years ago in reply to baldengineer
    One more question for you. Where are your resource names coming from that "open_resources" uses? We tried using the output of each instrument we got from the "list_resources", but kept getting errors. Some of the resource names used by "open_resources" seem to be very long. Is there something else we need to do to get/set them?
  • Kronus
    Thank you so much! This is huge!
