Home Automation
  • Home Automation
Home Automation
Blog OpenHAB 2 with Matrix Creator and RasPi 3 A+: Everloop and demo
  • Author Author: jomoenginer
  • Date Created: 15 Mar 2019 7:12 AM Date Created
  • Views 1458 views
  • homeautomationch
  • mqtt
  • python
  • rpiintermediate
  • matrix labs
  • arduino mkr1010
  • matrix-lite-py
  • matrix creator
  • raspberry pi 3 a+
jomoenginer
jomoenginer
15 Mar 2019
Home Automation
Enter Your Electronics & Design Project for a chance to win a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
Overview
This is my last post for the Home Automation Project14 event due to time constraints.  My intention was to implement controlling the GPIO connections from P2 on the MATRIX Creator via openHAB, but that is not quite working at this point, so I am moving to just the Everloop control which I already have configured in openHAB.  This control from openHAB is from the Exec Binding calling python scripts using the matrix-lite-py interfaces.   The Basic UI is used from openHAB to send the commands to the MATRIX Creator.
Previous Posts:
OpenHAB 2 with Matrix Creator and RasPi 3 A+: Intro
OpenHAB 2 with Matrix Creator and RasPi 3 A+: MATRIX Lite Python
OpenHAB 2 with Matrix Creator and RasPi 3 A+: OpenHAB 2 MQTT Binding
OpenHAB 2 with Matrix Creator and RasPi 3 A+: OpenHAB 2 Exec Binding
OpenHAB 2 with Matrix Creator and RasPi 3 A+: GPIO and Postmortem
MATRIX Lite Python
Using the example that came with the MATRIX Lite Python interfaces, I have created a couple of methods that can turn on and off the Everloop LEDs as well as control the color and brightness.
   Python Script uses a Dictionary to sed specific colors.
ledMatrix = {'red': {'ledr' : 1, 'ledg' : 0 , 'ledb' : 0, 'ledw' : 0},
            'green': {'ledr' : 0, 'ledg' : 1 , 'ledb' : 0, 'ledw' : 0},
            'blue': {'ledr' : 0, 'ledg' : 0 , 'ledb' : 1, 'ledw' : 0},
            'white': {'ledr' : 0, 'ledg' : 0 , 'ledb' : 0, 'ledw' : 1},
            'off': {'ledr' : 0, 'ledg' : 0 , 'ledb' : 0, 'ledw' : 0},
            'on': {'ledr' : 1, 'ledg' : 1 , 'ledb' : 1, 'ledw' : 1}
## LED Example ##
def runEverloop(self, color):
self.everloop = hal.everloop()
color = color.lower()
print ("Color: %s" % color)
for i in range(self.everloop.ledCount):
#led = hal.led(0,0,0,0)#led.r led.g led.b led.w
led = hal.led(ledMatrix.get(color, {}).get('ledr'),
ledMatrix.get(color, {}).get('ledg'),
ledMatrix.get(color, {}).get('ledb'),
ledMatrix.get(color, {}).get('ledw'),
self.leds.append(led)
del led
self.everloop.set(self.leds)
   Python method to dynamically set LED colors:
## LED Color set ##
def setEverloop(self, colorVal):
print ("Color: %s" % colorVal)
colorList = colorVal.split(":")
led = hal.led(int(colorList[0], 16),
int(colorList[1], 16),
int(colorList[2], 16),
int(colorList[3], 16)
del led
del colorList
Sorry, I am not sure what is happening with the formatting of the code but I do not have time to fix they way the code looks.
openHAB Items config
Switch SetELoopRed "EverLoop Red" { channel="exec:command:eloop_color_red:online" }
Switch SetELoopBlue "EverLoop Blue" { channel="exec:command:eloop_color_blue:online" }
Color SetELoopColor "EverLoop Color" <slider>
openHAB Sitemap config
Frame label="EverLoop" {
Switch item=SetELoopRed label="eLoop Red" icon="colorpicker"
Switch item=SetELoopBlue label="eLoop Blue" icon="colorpicker"
Frame label="EverLoop Color" {
Colorpicker item=SetELoopColor label="eLoop color" icon="colorpicker"
openHAB Rules
import org.eclipse.smarthome.core.library.types.HSBType
var String eLoopCmd = '/usr/bin/python3 /opt/openhab2/conf/scripts/newTempScript.py '
//var String eLoopColor = '/usr/bin/python3 /opt/openhab2/conf/scripts/newTempScript.py ' + '--color' + ' '
rule "Set Eloop Red"
when
    Item SetELoopRed received command
then
    if(receivedCommand == ON) {
        var String eLoopRed = eLoopCmd + '-e' + ' \"'+ 'red' + '\"'
        logInfo("SetELoopRed", "setting everloop to red")
        executeCommandLine(eLoopRed)
    else {
        var String eLoopOff = eLoopCmd + '-e' + ' \"'+ 'off' + '\"'
        logInfo("SetELoopRed", "setting everloop to off")
        executeCommandLine(eLoopOff)
end
rule "Set Eloop Blue"
when
    Item SetELoopBlue received command
then
        var String eLoopBlue = eLoopCmd + '-e' + ' \"'+ 'blue' + '\"'
        logInfo("SetELoopBlue", "setting everloop to blue")
        executeCommandLine(eLoopBlue)
    else {
        logInfo("SetELoopBlue", "setting everloop to off")
end
rule "Set Eloop Color"
when
    Item SetELoopColor received update
then
    logInfo("SetELoopColor", "Get Color")
    var hsbValue    = SetELoopColor.state as HSBType
    var brightness  = hsbValue.brightness.intValue
    var redValue    = ((((hsbValue.red.intValue * 255) / 100) * brightness) / 100).toString
    var greenValue    = ((((hsbValue.green.intValue * 255) / 100) * brightness) / 100).toString
    var blueValue    = ((((hsbValue.blue.intValue * 255) / 100) * brightness) / 100).toString
    logWarn("Red", redValue)
    logWarn("Green", greenValue)
    logWarn("Blue", blueValue)
    var String cmd = eLoopCmd + '-c' + ' ' + '\"' + redValue + ':' + greenValue + ':' + blueValue + ':' + '0' + '\"'
    logInfo("SetELoopColor", cmd)
    executeCommandLine(cmd)
end
  openHAB Basic UI Everloop Controls
Well, that is about it.    This has been interesting, and as always I wished I had more time to get more done, but I at least I was able to this much configured.   There is still a whole host of things that can be done with this config and I will continue to work with it.  I'd like to thank Tariq and element14 for providing me with the MATRIX Creator and Raspberry Pi 3 A+ for the project.
  • aabhas
    aabhas over 7 years ago +1
    jomoenginer Great series of blog with Matrix Creator and Raspberry Pi and also Thanks a lot for help provided in the discussion . Aabhas Senapati
  • dixonselvan
    dixonselvan over 7 years ago
    jomoenginer Excellent series of work! I too couldn't get that much time to put into my project what all I have planned. The Everloop demo was so satisfying to watch in particular the rainbow demo.
  • dixonselvan
