NanoRama
  • NanoRama
NanoRama
Blog Laser Focus Assembly Completed
Join NanoRama to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 10 May 2020 10:53 PM Date Created
  • Views 1825 views
  • Likes 9 likes
  • nanoramach
  • vl6180x
  • microview
ralphjy
ralphjy
10 May 2020
NanoRama
Enter Your Project for a chance to win a Nano Grand Prize bundle for the most innovative use of Arduino plus a $400 shopping cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
Since it's almost the end of the Nanorama Challenge I needed to get my laser focus assembly cleaned up.  I'm reasonably satisfied with the hardware but will still need to do some tweaking of the focusing software algorithms.
I'm basically just moving the MicroView module from the solderless breadboard to a hardwired proto PCB that is directly cabled to the GRBL controller.  I'm going to socket the MicroView so that I can remove it for reprogramming if necessary.  It would have been nice if this had been a WiFi capable module so I could have done OTA updating.
Here are the parts that I need to move from the solderless breadboard to a hardwired assembly.
  • 3D printed insert to attach the proto board to the sensor mount on the laser head
  • Proto PCB cut to size using the CNC by replacing the laser with the spindle motor (it's not recommended to cut FR-4 with the laser)
  • Power switch to shut off the assembly independently from the GRBL controller (now getting power from the controller instead of the USB programmer)
Here is the completed assembly.
  • The wires below are the power and I2C connections to the sensor
  • The wires to the left are the power and probe connection to the GRBL controller
Here is the assembly mounted on the laser head with the MicroView inserted.
  • The wires to the left are for the laser head
  • The unattached wires to the right are for the CNC spindle motor
Now I need to clean up the software.  The heavy measurement averaging is affecting the settling time when I search for the focal point distance.  I'm going to play with the settings to find the best compromise.  I'm also doing some longer term characterization of the VL6180X but I'll post that data in a separate blog in a couple of weeks.
Here are links to my previous Nanorama blog posts:
Focus Laser using Micro-LIDAR
Using VL6180X with Averaging
TOF Sensor mounted on Laser
Adding Z Align (Laser Focus) Button to LaserGRBL
    genebren over 6 years ago +1
    Very nice project. I hope that you are able to sort out the remaining issues/features and have a solid and useful tool for getting the most out of you laser.
  • ankur608
    ankur608 over 6 years ago +1
    Great implementation.
  • msbettyhunt
    msbettyhunt over 6 years ago +1
    I found this very helpful and great idea to implement in my new project!
  • ankur608
  • ankur608
