Vision Thing
  • Vision Thing
Vision Thing
Blog Poop Buster with Beaglebone AI
Join Vision Thing to participate - click to join for free!
  • Author Author: weiwei2
  • Date Created: 19 Nov 2019 3:20 AM Date Created
  • Views 2557 views
  • Comments 5 comments
  • visionthingch
  • beaglebone-ai
weiwei2
weiwei2
19 Nov 2019
Vision Thing
Enter Your Project for a chance to win an Oscilloscope Grand Prize Package for the Most Creative Vision Thing Project!
Project14 Home
Monthly Themes
Monthly Theme Poll
Poop Buster Setup
Beaglebone AI is used to control a x-y gantry robot by controlling it via USB serial port. some videos are attached towards the later part of this blog
My Journey
I initially struggle with the insufficient disk space on my Beaglebone AI but solve it
Not enough disk space for apt upgrade on Beaglebone AI
along the way, we get to know from the community that a fan is needed for BeagleBone AI, else it risks running into overheating. tariq.ahmad has offered us a fan and mayermakes has made a cap for it, while it is also mentioned inBeagleBone AI (BB-AI) - Getting Started
i also find that the wifi on Beaglebone AI is not stable and keep dropping. It is best to use ethernet.
supplementary tool
  • install makeblock orion driver
          Learning Arduino Programming – Open-source Arduino Robot Building Platform|Makeblock Learning Resource
          since i am using Orion — Select Arduino Uno in the arduino IDE and its respective COM port.
also, download the makeblock libraries at Makeblock-library-for-Arduino: Makeblock library for Arduino
Install processing
  1. Download and install Processing-2.1.2. http://processing.org/
  2. Install the Processing library, controlP5 -- copy the whole folder to C:\Users\xxx\Documents\Processing\libraries
  3. Open the GRemote.pde by Processing, DIY the code and click the “run” button to test it.
Note: can't really use processing due to much works need to done in short time
Install serialport for use bonescript
in terminal, type sudo npm install -g serialport
after that, type echo BB-UART4 > /sys/devices/bone_capemgr.*/slots
Install minicom
sudo apt-get install minicom
i use a Logitech webcam connected to the Beaglebone AI. Photo here shows the x y gantry. This is using MJPG-Streamer. Instruction as in https://www.hackster.io/175809/tidl-on-beaglebone-ai-1ee263
it is also discussed in more details in the AI with Beaglebone section below
Useful Commands
[1] shutdown -> sudo shutdown -h now
[2] reboot -> sudo reboot
[3] to update kernel
cd /opt/scripts⏎
git pull⏎
sudo tools/update_kernel.sh⏎
[4] in nano editor, ^ means ctrl key, e.g:  ^X is ctrl+X , ctrl+o is saving file, it will prompt for filename and we press enter
[5] to clear terminal screen, use clear
[6] v4l2-ctl --list-devices to list the camera connected.
Pinout
The board photo i grab from https://github.com/beagleboard/beaglebone-ai/wiki/Quick-Start-Guide  shows the subsystem layout
i get to know its pin is compatible with other beaglebone and below pinout is what i get from https://beagleboard.org/Support/bone101 . pin 8 can on P9 header can be used to power up the Nidec fan provided by Tariq.
To check whether our BB AI is alive and kicking, connect to the board via USB at 192.168.7.2. We will reach the screen below.
This can be further referred at https://beagleboard.org/getting-started
X-Y Gantry
my X-Y gantry is driven by 2 stepper motors. To drive a stepper motor, i use makeblock orion
it has getting started guide here Makeblock Orion – Open-source Arduino Robot Building Platform|Makeblock Learning Resource
Communication between Beaglebone AI and makeblock orion (Arduino Uno with some connectors for makeblock modules)
i use Beaglebone AI to control Makeblock Orion
on terminal, the Makeblock is found to be /dev/ttyUSB0
snippet of code that setup a serial port listener as well as a writer
this is the testing during development
AI with Beaglebone AI
The only viable example seems like https://www.hackster.io/175809/tidl-on-beaglebone-ai-1ee263  with the TI TIDL library
i have to admit that after looking at the classifiction.tidl.cpp i have not much clues what it is doing
these codes are screenshot from classification.tidl.cpp
to run it, after press run and type password, it takes up to 4-5 minutes for me to able to use MJPG-Streamer to look at the picture
before that, it will shows the error screen below "beaglebone.local refues to connect"
after it is ready, it suppose to detect object. my BeagleBone AI with the Nidec fan is detected as a cellular phone image
To understand TIDL, watch this 13 minutes clip https://training.ti.com/texas-instruments-deep-learning-tidl-overview
the C66x is capable for running deep learning inference. The embedded vision engine (EVE) is a subsystem with coprocessor to provide further video processing and deep learning acceleration. The AM5749 on beaglebone AI contains 2x EVE. As of current, the TIDL supports spatial data input (ie. Video, image, TOF, radar etc)
More details about the workflow can be found at http://downloads.ti.com/mctools/esd/docs/tidl-api/intro.html
However, the url to download the convertor tool is down, so I don’t try with the TIDL translator tool
http://downloads.ti.com/mctools/esd/docs/tidl-api/example.html contains a lot of examples on how to use the TIDL API.
to run the example need to use sudo, ie. debian@beaglebone:/usr/share/ti/examples/tidl/ssd_multibox$ sudo ./ssd_multibox
To view processed image, I use eog. Install it by using
sudo apt-get install eog
Problems Encountered
this section mainly list down problem i cannot resolve
-The beaglebone AI HDMI output works with my normal PC monitor. But it fail to output to my Seeedstudio 10.1 inch display. Originally want to use the 10.1' display as a console. Anyhow i also notice that the Beaglebone AI runs significantly slower when it is connected to a monitor and keyboard, so the incentive to stay connected via USB type-C is a bigger pull.
-non availability of tool for doing deep learning model conversion into TIDL format. even if it is available, i doubt i have time to explore image
Reference
[1] https://www.instructables.com/id/Wireless-Arduino-Control-Using-the-BeagleBone-Blac/
[2] bonescript https://github.com/jadonk/bonescript
Wifi Command Reference --> this is unstable. better use ethernet
[1] connect to wifi .
debian@beaglebone:/var/lib/cloud9$ sudo connmanctl⏎
Note: wifi  enable wifi
[sudo] password for debian: temppwd⏎
connmanctl> scan wifi⏎
Scan completed for wifi
connmanctl> services⏎
  MyWifi wifi_1234567890_1234567890123456_managed_psk
connmanctl> agent on⏎
Agent registered
connmanctl> connect wifi_1234567890_1234567890123456_managed_psk⏎
Agent RequestInput wifi_1234567890_1234567890123456_managed_psk
  Passphrase = [ Type=psk, Requirement=mandatory, Alternates=[ WPS ] ]
  WPS = [ Type=wpspin, Requirement=alternate ]
Passphrase? MySecretPassphrase⏎
Connected wifi_1234567890_1234567890123456_managed_psk
connmanctl> quit⏎
  • weiwei2
    weiwei2 over 6 years ago in reply to dubbie +2
    actually i also face multiple problem....was originally wanting to ask tariq.ahmad whether can extend like a week and 2 so i can greatly improve it.
  • weiwei2
    weiwei2 over 6 years ago in reply to Sean_Miller +2
    wow, that's really a lot of information and helpful stuff there. thanks a lot. Let me try follow your posting to debug some problems
  • Sean_Miller
    Sean_Miller over 6 years ago +2
    Another option for viewing the stream can be typing in your browser this: http://ipnumber:8080 ipnumber would be replaced with your BBAI IP number assigned by your network. I like this option because I…
    dubbie over 6 years ago
    Looks good. Lots of different aspects to get going. You have progressed much further with your BeagleBone AI than I have. I have just managed to turn it on and connect an external terminal.
    Dubbie
  • weiwei2
  • Sean_Miller
    Sean_Miller over 6 years ago in reply to weiwei2
    What problems are you facing?
    This may give some self serve help on BBAI, but community members may be able to help as well:
    BeagleBone AI Survival Guide V3.18: PWM, I2C, Analog/Digital Read/Write, Vision AI, Video Text Overlays, Audio, & Hardware
    See ya',
    Sean
  • Sean_Miller
    See ya',
    Sean
  • weiwei2
    wow, that's really a lot of information and helpful stuff there. thanks a lot. Let me try follow your posting to debug some problems image
