Webinars, Training and Events
Forum Eagle libraries
Join Webinars, Training and Events to participate - click to join for free!
  • Replies 9 replies
  • Subscribers 1056 subscribers
  • Views 2127 views
  • help_required
  • libraries
Eagle libraries
I would like to learn more about how to find specific components and in which libraries to find them.  I know you can create your own components and Libraries, but for now I only use common components, which most likely are already created and stored in a library somewhere.
The problem is that it takes time to browse through libraries trying to find where the component is that I am looking for.
  • jmbldwn
    jmbldwn over 12 years ago in reply to dgashby
    I think the pointy-pin designator Dean is looking for could be achieved by checking the "xref" button in the label info field.  When you do that it puts the label inside that shape, and you can rotate it to the direction you want it to point.
    e14 Contributor over 12 years ago in reply to jmbldwn
    I like your website! It is the bomb! Thank you.
    shabaz over 12 years ago in reply to dgashby
    The parts are organised under folder names. Unless it's really a component (in which case you may find it in the 'con-...' libraries (for connector), then it may not exist. If desired, you could create it as a part, and perhaps place it in a personal library or in the 'docu-dummy' library since it is a documentation type symbol.
    Or you could give the wire a name (e.g. GPIO) and then put a label beside it (there are Name and Label icons in the EAGLE toolbar).
  • dgashby
    dgashby over 12 years ago
    What if you're not sure of the name, and after trying many different combinations in the search box still can't find what your looking for?  A classic example that I'm currently looking for is the schematic shape for a single GPIO output pin as used in the diagram below:
    Fullscreen contentimage_176289.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    Sorry, I'm a relative newcomer to eagle so still learning the ropes.
  • jmbldwn
    jmbldwn over 12 years ago in reply to shabaz
    I didn't say I trust parts I find on the internet.  I always thoroughly check them for accuracy.  I find it faster and less tedious than making the part myself.
    shabaz over 12 years ago in reply to jmbldwn
    Jim Baldwin wrote:
    but if you want to find a part you don't have it can be very difficult to find it on the internet
    Sorry, but I wouldn't trust a part on the free, public Internet.. who would? And more to the point, who should?
    I trust some simple parts in EAGLE because I've used them before.
    All other parts I create myself, to meet my needs.
    If there is a particular, trusted library from a third party, it can be placed inside the EAGLE library folder.
    And then, the Find feature in EAGLE works very well - it is near instantaneous and finds my parts and EAGLE standard parts, and any trusted third party.
  • jmbldwn
    That works if you are using a part already on your computer, but if you want to find a part you don't have it can be very difficult to find it on the internet because they tend to be buried in library and schematic files.
    I use the search box in EAGLE when you add the part. It is near-instantaneous.
    For example, if you're looking for a BC547 transistor, search for:
    BC547*
    or
    *547*
    etc..
  • jmbldwn
    Funny.  I had the same feeling when I started using Eagle so I made a website just for this purpose.
    Try it out and let me know what you think.  I would love to hear if it works for you.
    http://schematicpal.com
    -Jim
