Legacy Personal Blogs Extending Printrbot Simple's build platform...
  • Author Author: bradnorwood
  • Date Created: 12 Nov 2014 6:48 PM Date Created
  • Views 2415 views
  • Comments 23 comments
bradnorwood
bradnorwood
12 Nov 2014
This has been tricky, simple for the z extension. I replaced the rods and screw shaft with larger ones. It extended my z from 100mm to 250mm. But I had to go into G-code and change the maximums there to get it to recognize the extra size. Now I'm printing larger shaft holders for the x increase. I will replace the bed once the dimensions. Then with an increased z and x I will start the y.
  • bradnorwood
    bradnorwood over 11 years ago +2
    Printrboard box top completed 3 hours and 3 minutes.
  • bradnorwood
    bradnorwood over 11 years ago in reply to DAB +1
    DAB hope you you like this one hahaha
    DAB over 11 years ago in reply to bradnorwood +1
    Indeed I do. Great post. DAB
    Brad, could you provide some pictures?
  • bradnorwood
    Not easy! Plus I ran into my sensor not working due to being a metal detecting sensor, so I have to add metal tape lol
  • bradnorwood
    bradnorwood over 11 years ago in reply to bradnorwood
  • bradnorwood
    Old print size with new size, the z was the easyiest to up grade, I actually printed the pipe up right, new size is 90mm x 115mm x 300mm and wow hahaha
  • bradnorwood
    Indeed I do.
    Great post.
  • bradnorwood
    With the increased x the back side needs more support
  • bradnorwood
  • bradnorwood
    A belt guide was added and the x right stabilizer
  • bradnorwood
    I'm relocating the Printrbot board also.
    You are a braver man than I.
  • bradnorwood
    I found myself wanting bigger parts and items, I see how Printrbot needs a few minor upgrades, it's a great starter kit, I built this one and did not order it pre assembled. The original string was very poor quality so I up graded to the gt2 belts. Now I see the bearings being next, I ordered some from adafruit, I see there is a weakness in the x bearings and z ones too. Once I'm done, I should get really high quality prints at small and large sizes. Right now I get small parts easy but the larger ones need a better bearing and mounts to keep it level.
