Legacy Personal Blogs The Art of Noise
  • Author Author: jc2048
  • Date Created: 22 May 2021 10:41 AM Date Created
  • Views 8493 views
  • Likes 14 likes
  • Comments 36 comments
  • transistor
  • 2n3904
  • noise
  • analog
The Art of Noise
jc2048
jc2048
22 May 2021
22nd May 2021
I've just been playing with a very simple noise generator and that's the result.
The digital phosphor of the oscilloscope presents multiple traces of the waveform as though it were sketched with a pencil or crayon.
In case it's of any interest, here's the circuit:
The internet is full of variations, with either a Zener, reverse-biased LED, or reverse-biased base-emitter junction as the avalanche 'noise diode'.
For these traces I used a reverse-biased base-emitter junction (the transistor on the left with two pins connected - the other transistor is working as a common-emitter amplifier)
and it produced a very good level of noise out on a 12V supply.
At lower frequencies (the scope is AC-coupled for these), the noise looks quite noise-like. Like this:
but if I go back to the start and show you a single trace of the first waveform, we see this
so we're now looking at a time scale where we can see the avalanching stopping and starting.
Update 4th June 2021
What started as a throwaway blog about an interesting/amusing waveform seems to have taken on a life of its own.
Thanks for all the useful comments below. They've had the useful effect of forcing me to rethink some of this.
1. The original circuit that I copied had an integrator (low-pass filter) in the feedback of the common-emitter stage
[the 27k and the 10uF] to set the DC bias voltage. That means that the resulting overall transfer characteristic will
be high-pass [the inverse]. I should have considered that a bit more at the time. If I simulate it with this following
circuit (I've substituted a simple signal generator, with an 8V DC offset on it, for the 'noise diode' which is the input to the circuit)
I get this for the response
That won't be entirely right - the simulation is small-signal and the generator is working large-signal - but it lets us
see in a rough way what's happening and understand it in general terms. It falls off from a few hundred Hertz downwards.
That means I'm going to see very little of the low frequency noise as the circuit will integrate it away. Indeed, if I had wanted
to use the generator circuit for audio, it would probably have been better if I had moved the low end cut-off down by
another decade [100uF might do instead of the 10uF].
At the top end, that plot shows quite nicely that the response is determined largely by the amplifier transistor running
out of steam and that will depend to some extent on the individual transistor.
2. In my reply to Shabaz in the comments, I suggested that seeing the noise decline as I filtered it with the 'scopes
noise filtering meant that it wasn't white noise. That is quite wrong and I need to correct it. Since random noise level
is a function of bandwidth, if I restrict the bandwith, I lessen the noise seen. That doesn't mean that it's necessarily
'white' noise [equal power per unit of bandwidth], but it most certainly doesn't mean the opposite [that it's not].
In Motchenbacher and Fitchen, they suggest that avalanche noise is white but that there is also excess noise
in the form of multistate noise that is predominently l/f. This is in a section comparing the noise performance
of zener and avalanche diodes, though I presume a reverse-biased base-emitter junction is similar.
  • geralds
    geralds over 5 years ago in reply to shabaz +6
    shabaz wrote: Hi Jon, Very interesting blog post, I had not known noise could be generated at these levels with such a simple circuit! Yes, that's an age-old way of creating noise. Simply operate a transistor…
  • fmilburn
    fmilburn over 5 years ago +5
    By coincidence I became interested in these circuits recently, mostly with the idea of making a random number generator. Horowitz and Hill have one in the Art of Electronics but I also found a good article…
    Jan Cumps over 5 years ago in reply to shabaz +5
    My Tektronic TBS2xxx scope had a reasonable spectrum display. Not magic, but (almost) workable in that frequency range. I gave it away to a makerspace here in Belgium, so that avenue is closed. A SA is…
  • navadeepganeshu
    navadeepganeshu over 5 years ago
    Very nice art of noise!
    I tried it with BC547 and 4.7K,47K and boom, there is the noise generated. It starts coming after exact 12V and I like the way it works. At the output, starts at 0V, slowly rises, and when input is 12V, noise starts generating and the voltage level settles down. When turned off, the capacitor takes it full negative and slowly comes up to 0 at full discharge. Btw, this is the first circuit I am trying with the new RedPitaya scope!
  • jc2048
    jc2048 over 5 years ago in reply to navadeepganeshu
    Your RedPitaya looks an interesting piece of kit. Can you use it as a spectrum analyser to look at how the noise is distributed in the frequency domain?
    shabaz over 5 years ago in reply to Jan Cumps
    Hi Jan,
    Good idea, I was thinking of trying it too, but my spectrum analyzer won't handle the low frequency range. Frank's GW Instek will however, hehe no pressure fmilburn : )
    A SA is a rather niche instrument. If you need it, you need it.
    I'm restructuring my lab to only keep decent basic instruments (and freeing up storage space while rebasing).
    Anything that didn't fit that need, and was still in prime condition, I gave to STEM initiatives.
    • Vote Up +5 Vote Down
  • fmilburn
    fmilburn over 5 years ago in reply to shabaz
    shabaz Too.. much... pressure...  Must... comply... image
    I recreated the circuit but much to my chagrin had to substitute a 3k3 resistor as I did not have a 2k7.  Here is the beauty shot.
    For comparison to Jon's original post, here is 100ms followed by a screen grab at 2us.
    Now a look at the spectrum analyzer view.  The center frequency is 10kHz with a span of 20kHz.  RBW is 20Hz.  Circuit supply voltage is 12V.
    Below the circuit supply voltage is reduced to 6V to get an idea of the floor and there is about a 20dBV drop.
    Now the span is set 0 to 10MHz, showing the droop with frequency.
    Look right?  I'll leave this set up for a while in case someone wants me to run a different look.
  • navadeepganeshu
    navadeepganeshu over 5 years ago in reply to shabaz
    Interesting!
    But yes, RedPitaya doesn't show RBW.
    shabaz over 5 years ago in reply to fmilburn
    Hi Frank,
    Wow, very quick work!
    The results are very useful not only for seeing the circuit behavior but also to just see just how well the GW Instek 'scope handled it - that's amazing, extremely hard/impossible on other contemporary 'scopes.
    About the icing on the cake would be if it can also do averaging in SA mode. If it can, it will just clean up things a bit more, but to be honest it's even great as-is.
    Hi Frank,
  • fmilburn
    Here is the icing image
    Below is 0 to 20kHz span with RBW = 4Hz!  White trace is 256 SA averaged.
    I overlaid the horizontal cursor on 0 to 100kHz shown below and saw no deviation from flat.  Cursor not shown in screenshot below.
    Droop is evident 0 to 1MHz
  • jc2048
    jc2048 over 5 years ago in reply to fmilburn
    Thanks for showing us the spectra. It's interesting seeing what an instrument that operates more like a traditional SA makes of it.
    If I set my 'scope to have a long persistence, it shows me the envelope of the response better.
    This plot is 0 to 2.5MHz, so centre is 1.25MHz. It shows the amplifier roll-off from about 250kHz, which isn't too much different to yours, so it's encouraging that I'm viewing something sensible.
    What type of transistor were you using?
    I'm much more confused about the other end of the scale in the region from a few hundred Hz downwards. I can get radically different results, depending on the settings I use and how I make the measurement. Would you be able to do a trace with a span of 1kHz and a centre of 500Hz?
  • fmilburn
    fmilburn over 5 years ago in reply to jc2048
    I am using 2N3904 transistor.  Below is the trace with 1kHz span and center 500Hz.
    I twiddled knobs in FFT mode and move the horizontal start to better match your FFT view above and  got this:
    I don't understand what magic is involved.  Have a look at this link from Maxim: Building a Low-Cost White-Noise Generator (maximintegrated.com)  Is the SA used in the Maxim link unable to do analysis at low frequency along the line of reasoning that Shabaz described?
  • jc2048
    The reason I was curious about the transistor is that Navadeep Ganesh U was using a BC547 (fT probably something similar to 2N3904, but beta much higher).
    The low frequency spectra is interesting. The circuit naturally rolls off at the low end from about 100Hz downwards because of the integrator in the bias feedback. If the noise were perfectly white, then it should simply show us the amplifier response at the output - the noise multiplied by the gain. (Qualification: that assumes linearity, which won't quite be the case here because the output signal hardly qualifies as 'small signal'.) But it doesn't - it's more or less flat from 100Hz down.
    The noise book I've got says that avalanche diodes suffer from more excess noise [it's contrasting them with diodes where the Zener effect dominates and which are, therefore, better if you want a low-noise reference]. Excess noise is over and above the white noise and is generally l/f (low-frequency) noise. It will cause the overall noise to rise as the frequency falls. I was wondering whether we might see that.
    These are the two FFT traces I was having difficulty with.
    This first is AC coupled and seems to show a very low level of noise and the response looks to be the amplifier response, rolling off below 100Hz. That's with the noise filter quite close to the Nyquist rate for the FFT [too close?].
    This next is DC coupled with the offset removed, which seems to result in a much higher level of signal and the noise actually increasing from 100Hz down. This time the filter is further up, so is aliasing posing a problem?
    Neither is the result you've just got.
  • jc2048
    Sorry, forgot to come back and reply to the question.
    In that particular case, the reason that there's no low-frequency noise is the AC coupling between the amplifiers. The 470pF coupling capacitor and the 50 Ohm input impedance of the amplifier result in a high pass filter.
