Arduino Forum Learning about H-bridges and transistors
  • Replies 38 replies
  • Answers 8 answers
  • Subscribers 422 subscribers
  • Views 4776 views
  • frontpage
  • h-bridge
  • transistors
ovidiub13
ovidiub13 over 10 years ago
I'm trying to learn about transistors and H bridges towards a final goal of controlling a bipolar stepper motor with Arduino.
I've done the following half H-bridge in the process of learning:
My first question: Why can't I use a single resistor to connect the base of both transistors to ground?
  • strb
    strb over 10 years ago +1 suggested
    I'm not sure that this schematic works... the led isn't reverse polarized? Anyway use a pnp as pullup transistor and a npn as pulldown, it's a good thing to put also a limiter resistor to control the current…
  • strb
    strb over 10 years ago in reply to clem57 +1
    Great "how link" clem57
    mcb1 over 10 years ago in reply to ovidiub13 +1 suggested
    What I'm having issues understanding is how transistors work You can consider a transistor as a switch (in this case they are either ON or OFF) The control part of the switch is the base to emitter (NPN…
  • D_Hersey
    0 D_Hersey over 10 years ago
    The inductive kickback will start when the switch is closed.  The spike current will be then at its maximum, equal to the coil current at that moment.  The coil will act to oppose current changes in the switch by creating a potential spike.  This tells us that the max current rating on the diode has to be above the load current.  The faster this diode is, the better.  Use UltraFast or Shottky.  The SMPS industry uses lotsa these in flyback supplies and the like, so it won't be hard to find some for cheap.
  • D_Hersey
    Sometimes, in some configurations, you will see some designers relying on the parasitic diodes associated with MOSFETs and many Darlingtons.  Understand that never does the diode associated with a particular Q protect it.  It always protects some neighboring Q.
    Often undrawn, ya' need a fast, capacious and local capacitor (typically across the motor supply) to suck up the spike.
    0 mcb1 over 10 years ago in reply to Robert Peter Oakes
    Not sure I'd use 1N4148 diodes.
    I tend to prefer 1N4001  to 1N4004 as they handle the current a little better.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago in reply to mcb1
    That's exactly what I said in my comment with the Diagram and I completely agree... It was a Stock Diagram I found image
    oops I should have read all the words .....
    Sorry.
    I do the same from time to time, no apology necessary image, but thanks anyway
    Peter
  • jc2048
    0 jc2048 over 10 years ago in reply to not2xs
    "Typically the h-fe will be somewhere around 1000 to 100000"
    I would disagree with that statement. A few hundred would be more typical for hFE (datasheets usually quote hFE rather than hfe) for small-signal use (collector current 10mA, or so). 100-600 is a realistic range for real devices you might encounter. With medium- and high-power devices, you'd normally be looking at less than 100 once you get up to collector currents of a few amps.
    0 Robert Peter Oakes over 10 years ago in reply to jc2048
    The gains etc are based on the devices shown in the posted schematics, looking at manufacturer data sheets, to exceed these ratings may be possible but you risk thermal and other damage to the device. But as you say, there are other devices you can use, in my case I would go with MOSFETS or other versions of FETs for the switches , they have other issues to deal with, I just happen to like them image
    Peter
