Ultrazed Hardware Design OOB Demo Fail - Serial Connection Gone
  • Replies 9 replies
  • Subscribers 358 subscribers
  • Views 1779 views
  • ultrazed
Anonymous-831639
Anonymous-831639 over 6 years ago
Hi all,
Just opened up my new UltraZed-EV Starter Kit and followed the QuickStart Guide Instructions for getting the Out of Box Demo with a blinking light flashing.
Only problem is neither Terra Term nor PuTTy show any data over the connection as described, and there's no blinking light. I triple checked that all the switches were right, drivers downloaded, bit rate and other settings were correct, but I can't seem to resolve the issue. Any thoughts or tips on how to rectify the situation? Thanks!
  • narrucmot
    narrucmot over 6 years ago +1
    It sounds like the UltraZed-EV SOM may not be fully seated in the connectors to the carrier board. These connectors are very stiff and it takes a lot of force to get them to fully mate. Can you try re…
  • narrucmot
    narrucmot over 6 years ago in reply to Anonymous-831639 +1
    OK, a couple of things come to mind. The UltraZed-EV will report two virtual COM ports for TeraTerm or PuTTY to use - have you tried using both of them? Only one of them will be the active STDIO UART.…
  • drozwood90
    drozwood90 over 6 years ago +1
    Hi there, Also, make certain the boot switches are set properly. If you are not careful, I have seen some customers have the inverse of what the switches SHOULD be set to. --Dan
  • narrucmot
    It sounds like the UltraZed-EV SOM may not be fully seated in the connectors to the carrier board.  These connectors are very stiff and it takes a lot of force to get them to fully mate.  Can you try re-seating the SOM onto the carrier?
    --Tom
  • Anonymous-831639
    Anonymous-831639 over 6 years ago in reply to narrucmot
    Hi Tom - thanks for the tip - after inspection it did look like some of the connectors could be seated better (talk about stiff, you weren't joking!)
    However, that hasn't seemed to ameliorate the situation either. I even completely disconnected and disassembled everything and put it back together to make sure it was seated correctly. No dice.
  • narrucmot
    OK, a couple of things come to mind.  The UltraZed-EV will report two virtual COM ports for TeraTerm or PuTTY to use - have you tried using both of them?  Only one of them will be the active STDIO UART.  Also, and I apologize that this is rather rudimentary, but does the blue DONE LED turn on at power-on?  This will confirm that the PL is configured and that boot should be commencing via whatever boot method is selected.
    --Tom
  • drozwood90
    Hi there,
    --Dan
  • Anonymous-831639
    Thanks for the follow up Tom!
    As for both ports - yes I did notice that there were two, but was unaware that only one will be active STDIO UART! Unfortunately, neither one indicates any sort of OOB demo or boot up....
    Sometimes "rudimentary" is what we all need = ) I for one, am not seeing the blue DONE LED firing... the red PS USER LED is on, but the PS DONE LED on the UltraZed-EV, in the bottom left corner of the board, it is not on.. thoughts on next steps? Glad you thought to ask!
  • drozwood90
    drozwood90 over 6 years ago in reply to drozwood90
    Hi there,
    Going along with my previous suggest, you can also try to download one of the latest test images to see what is what.
    The easiest is to just pop on the SDCARD the Vitis (Prebuilt With Example):
    http://avnet.me/DBA_BSPS_PLATFORMS_2019p2
    You can just extract that to the provided Delkin SDCARD
    You can also test the Vitis image if you wish:
    cd /run/media/mmcblk1p1
    export DISPLAY=:0.0
    export XILINX_XRT=/usr
    ./uzevvadd.exe binary_container_1.xclbin
    I hope that helps!
    --Dan
  • Anonymous-831639
    Thanks everybody for your helpful suggestions! tl;dr it looks like we'll be sending the board back to the manufacture for replacement, because it was dead from the start.
    I followed the exact same instructions for a different board - everything worked perfectly. Blue LED, Blinking Red LED, info over the serial connection, everything. Which also meant the drivers on the computer and listening on the serial ports was on happening correctly.
    I got a great SD card image from a friend who also has a board, and we tried various combination of each person's carrier board, SD card, and Ultrazed-EV, with every combination working except for when my Ultrazed EV board was involved, which is very sad, but good to know that I'm not *completely* incompetent, just marginally so.
  • narrucmot
    Thanks for letting us know, and sorry you were shipped a defective SOM.  Hopefully you will get a replacement soon.
    Cheers,
    Tom
  • drozwood90
    drozwood90 over 6 years ago in reply to Anonymous-831639
    Sorry that happened.  I am glad you were able to compare against a working unit and had access to a friend to be able to do a slew of comparisons!  That saved a LOT of time!
    We do analyze boards that are returned for failure analysis.  We have been seeing a higher than normal board death by ESD, I am guessing most people are working from home and did not take ESD into consideration in their home offices.
    Regardless, I hope you do better with the next one!
    --Dan
