ZedBoard Hardware Design AXI VDMA
  • Subscribers 359 subscribers
  • Views 1447 views
AXI VDMA
I am having a problem with a simple design on the zedboard. My design consists of a Zynq processor, AXI VDMA, and a AXI TPG. The axi stream clock is set to run at 150Mhz (142.85Mhz actual). The problem is when I synthesize the design it fails timing. The AXI VDMA product guide PG020 shows that the Artix-7 family -1 speed grade can do 150 MHz AXI4-stream.
These are links of images for the timing report.
postimg.org/image/mx3xzenji
postimg.org/image/c206c42p3
  • drozwood90
    0 drozwood90 over 12 years ago
    The first link does not work.
    From what I see in the second link:
    *How full is the part? (sounds like not too much)
    *Are you using a lot of clock fabric?
    *How many clocks do you have?
    *What does your clock tree look like?
    *What do your constraints look like for the clocks in your system?
    --If you are asking for 150, and getting 142, but wrote the constraint for 150, that could cause your failure.
    *How wide are the data buses that you are connecting to the AXI interconnect?
    *do you have any CDC (clock domain crossing) issues?
    *have you tried to register the data once or twice?
    --that is, setup a pipeline
    --Dan
    I have attached some images of the clock setup, block diagram, utilization, tpg config, and vdma config.
    This design was created using the zedboard presets. There is no added constraints.
    http://postimg.org/image/5hzcm2ha1/
    http://postimg.org/image/3mckawsft/
    http://postimg.org/image/ggam495vd/
    http://postimg.org/image/i49riwjqx/
    http://postimg.org/image/5s6v5evw9/
  • drozwood90
    Looking all that over, nothing looks out of place.
    I'm not sure I see where Artix-7 is mentioned in PG020, you are right though, that Zynq can do a 64bit AXI connection at 150Mhz (MAX).
    I still believe that you need to change the constraint that is there.  If you did not have any constraints, it would just pass timing.  Since you did not add any, this must be part of the auto-generated constraints.  Files are called *.xdc and are located in the project folder.
    Again, I suggest you look at your clock tree and modify it to get 150Mhz, if that is what you NEED.  If the constraint is for 150Mhz, and you are getting 142Mhz, you are most likely out of tolerance in the constraint's eyes.  Thus you fail either setup or hold.
    Probably the easiest thing to do, is change the 150Mhz to something else that is a better multiple.  If you do not need it, why push the fabric?  It is only going to make routing difficult as well as consume more power.
    If you NEED 150Mhz, I suggest you disable the 150Mhz FCLK, then in the BD, add a MCMM.  Then use the MCMM to create the 150Mhz.  Using the MCMM IP allows you to choose MCMM or PLL.  UG472 suggests you use a MCMM, unless you need extra jitter control or cannot make the clock frequency that you need.  At 150Mhz, you should start to be concerned with jitter, so my guidance is use the PLL suggestion, if it will give you 150Mhz.
    From the images, it looks like you are doing 1080P video?  You might want to look at our video Reference designs.  There might be something else that you or I am missing - based on the information you presented to me.
    http://zedboard.org/design/1521/11
    Based on what you told me, I think that this Design might be of some use:
    "Zedboard HDMI Display Controller Tutorial for Vivado"
    Using the information you provided, I come up with needing about a 50Mhz clock.
    Your configuration is:
    (1080*1920)*(24 (RGB))*30(FPS)? = 1,492,992,000 bits/sec
    =186,624,000 Bytes/sec
    So, you really only need to run (at 32bit wide, based on his VDMA block) 46+change Mhz.  So, 50Mhz seems adequate.
    32 bits = 4 bytes
    186624000/4 = 46,656,000/sec (or Hz).
    I'm told that if you are doing 1080P60-FPS, you will need at LEAST a 142Mhz clock, as the pixels rate ends up being 148.5Mhz, however there are blanking periods that allows your 142Mhz clock to catch up to the required 148.5Mhz.
    Did that explanation make sense to you?
    --Dan
    I tried putting in a clock wizard module and feed it 100MHz in and it produced 148.5MHz using the MCMM setting. I still however have the problem with timing. I am not sure what constraints to put into a constrain file for this design. I have looked over the constraints from the "Zedboard HDMI Display Controller Tutorial for Vivado" as well as the FMC_IMAGEON and t looks very similar, mostly io pin placement and defining the clocks that come off the PS. The reason I started trying to get 148.5MHz from the axi stream was the following. I had it operating at 100MHz and 320x240 frame and VDMA into ddr. The image was fine. Then when i changed the frame size to 1920x1080 every time the vdma would run it would alternate between proper data and garbage data. The vdma is only writing 1 frame. The current constraints that are auto generated by the probject are below.
    On a side note. I have a problem running any of the video examples due to a license problem with vivado. I have downloaded the evaluation license but it never seems to work. When I generate it get errors based on v_spec, v_cfa, etc.
    system_ooc.xdc
    create_clock -name processing_system7_0_FCLK_CLK0 -period 10 [get_pins processing_system7_0/FCLK_CLK0]
    system_axi_vdma_0_0_clocks.xdc
    system_axi_vdma_0_0_ooc.xdc
    create_clock -name s_axi_lite_aclk -period 50 [get_ports s_axi_lite_aclk]
    set_property HD.CLK_SRC BUFGCTRL_X0Y0 [get_ports s_axi_lite_aclk]
    create_clock -name m_axi_s2mm_aclk -period 10 [get_ports m_axi_s2mm_aclk]
    set_property HD.CLK_SRC BUFGCTRL_X0Y2 [get_ports m_axi_s2mm_aclk]
    create_clock -name s_axis_s2mm_aclk -period 20 [get_ports s_axis_s2mm_aclk]
    set_property HD.CLK_SRC BUFGCTRL_X0Y5 [get_ports s_axis_s2mm_aclk]
    system_axi_vdma_0_0.xdc
    set_false_path -to [get_pins -leaf -of_objects [get_cells -hier *cdc_tig* -filter {is_sequential}] -filter {NAME=~*/D}]
    set_false_path -from [get_cells -hier *cdc_from* -filter {is_sequential}] -to [get_cells -hier *cdc_to* -filter {is_sequential}]
      set_false_path -to   [get_pins  -hierarchical  -filter {NAME =~*S2MM*LB_BUILT_IN*/*rstbt*/*PRE}]
      set_false_path -from [get_cells -hierarchical  -filter {NAME =~*S2MM*LB_BUILT_IN*/*rstbt*/*rst_reg_reg && IS_SEQUENTIAL}]
      set_false_path -from [get_cells -hierarchical  -filter {NAME =~*S2MM*LB_BUILT_IN*/*rstbt*/*rst_reg[*]}]
    system_processing_system7_0_0.xdc
    create_clock -name clk_fpga_0 -period "10" [get_pins "PS7_i/FCLKCLK[0]"]
    set_input_jitter clk_fpga_0 0.3
    set_property iostandard "LVCMOS18" [get_ports "MIO[53]"]
    set_property PACKAGE_PIN "C12" [get_ports "MIO[53]"]
    set_property slew "slow" [get_ports "MIO[53]"]
    set_property drive "8" [get_ports "MIO[53]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[53]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[52]"]
    set_property PACKAGE_PIN "D10" [get_ports "MIO[52]"]
    set_property slew "slow" [get_ports "MIO[52]"]
    set_property drive "8" [get_ports "MIO[52]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[52]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[51]"]
    set_property PACKAGE_PIN "C10" [get_ports "MIO[51]"]
    set_property slew "slow" [get_ports "MIO[51]"]
    set_property drive "8" [get_ports "MIO[51]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[51]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[50]"]
    set_property PACKAGE_PIN "D13" [get_ports "MIO[50]"]
    set_property slew "slow" [get_ports "MIO[50]"]
    set_property drive "8" [get_ports "MIO[50]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[50]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[49]"]
    set_property PACKAGE_PIN "C14" [get_ports "MIO[49]"]
    set_property slew "slow" [get_ports "MIO[49]"]
    set_property drive "8" [get_ports "MIO[49]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[49]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[48]"]
    set_property PACKAGE_PIN "D11" [get_ports "MIO[48]"]
    set_property slew "slow" [get_ports "MIO[48]"]
    set_property drive "8" [get_ports "MIO[48]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[48]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[47]"]
    set_property PACKAGE_PIN "B10" [get_ports "MIO[47]"]
    set_property slew "slow" [get_ports "MIO[47]"]
    set_property drive "8" [get_ports "MIO[47]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[47]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[46]"]
    set_property PACKAGE_PIN "D12" [get_ports "MIO[46]"]
    set_property slew "slow" [get_ports "MIO[46]"]
    set_property drive "8" [get_ports "MIO[46]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[46]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[45]"]
    set_property PACKAGE_PIN "B9" [get_ports "MIO[45]"]
    set_property slew "fast" [get_ports "MIO[45]"]
    set_property drive "8" [get_ports "MIO[45]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[45]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[44]"]
    set_property PACKAGE_PIN "E13" [get_ports "MIO[44]"]
    set_property slew "fast" [get_ports "MIO[44]"]
    set_property drive "8" [get_ports "MIO[44]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[44]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[43]"]
    set_property PACKAGE_PIN "B11" [get_ports "MIO[43]"]
    set_property slew "fast" [get_ports "MIO[43]"]
    set_property drive "8" [get_ports "MIO[43]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[43]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[42]"]
    set_property PACKAGE_PIN "D8" [get_ports "MIO[42]"]
    set_property slew "fast" [get_ports "MIO[42]"]
    set_property drive "8" [get_ports "MIO[42]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[42]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[41]"]
    set_property PACKAGE_PIN "C8" [get_ports "MIO[41]"]
    set_property slew "fast" [get_ports "MIO[41]"]
    set_property drive "8" [get_ports "MIO[41]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[41]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[40]"]
    set_property PACKAGE_PIN "E14" [get_ports "MIO[40]"]
    set_property slew "fast" [get_ports "MIO[40]"]
    set_property drive "8" [get_ports "MIO[40]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[40]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[39]"]
    set_property PACKAGE_PIN "C13" [get_ports "MIO[39]"]
    set_property slew "fast" [get_ports "MIO[39]"]
    set_property drive "8" [get_ports "MIO[39]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[39]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[38]"]
    set_property PACKAGE_PIN "F13" [get_ports "MIO[38]"]
    set_property slew "fast" [get_ports "MIO[38]"]
    set_property drive "8" [get_ports "MIO[38]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[38]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[37]"]
    set_property PACKAGE_PIN "B14" [get_ports "MIO[37]"]
    set_property slew "fast" [get_ports "MIO[37]"]
    set_property drive "8" [get_ports "MIO[37]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[37]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[36]"]
    set_property PACKAGE_PIN "A9" [get_ports "MIO[36]"]
    set_property slew "fast" [get_ports "MIO[36]"]
    set_property drive "8" [get_ports "MIO[36]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[36]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[35]"]
    set_property PACKAGE_PIN "F14" [get_ports "MIO[35]"]
    set_property slew "fast" [get_ports "MIO[35]"]
    set_property drive "8" [get_ports "MIO[35]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[35]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[34]"]
    set_property PACKAGE_PIN "B12" [get_ports "MIO[34]"]
    set_property slew "fast" [get_ports "MIO[34]"]
    set_property drive "8" [get_ports "MIO[34]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[34]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[33]"]
    set_property PACKAGE_PIN "G13" [get_ports "MIO[33]"]
    set_property slew "fast" [get_ports "MIO[33]"]
    set_property drive "8" [get_ports "MIO[33]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[33]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[32]"]
    set_property PACKAGE_PIN "C7" [get_ports "MIO[32]"]
    set_property slew "fast" [get_ports "MIO[32]"]
    set_property drive "8" [get_ports "MIO[32]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[32]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[31]"]
    set_property PACKAGE_PIN "F9" [get_ports "MIO[31]"]
    set_property slew "fast" [get_ports "MIO[31]"]
    set_property drive "8" [get_ports "MIO[31]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[31]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[30]"]
    set_property PACKAGE_PIN "A11" [get_ports "MIO[30]"]
    set_property slew "fast" [get_ports "MIO[30]"]
    set_property drive "8" [get_ports "MIO[30]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[30]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[29]"]
    set_property PACKAGE_PIN "E8" [get_ports "MIO[29]"]
    set_property slew "fast" [get_ports "MIO[29]"]
    set_property drive "8" [get_ports "MIO[29]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[29]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[28]"]
    set_property PACKAGE_PIN "A12" [get_ports "MIO[28]"]
    set_property slew "fast" [get_ports "MIO[28]"]
    set_property drive "8" [get_ports "MIO[28]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[28]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[27]"]
    set_property PACKAGE_PIN "D7" [get_ports "MIO[27]"]
    set_property slew "fast" [get_ports "MIO[27]"]
    set_property drive "8" [get_ports "MIO[27]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[27]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[26]"]
    set_property PACKAGE_PIN "A13" [get_ports "MIO[26]"]
    set_property slew "fast" [get_ports "MIO[26]"]
    set_property drive "8" [get_ports "MIO[26]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[26]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[25]"]
    set_property PACKAGE_PIN "F12" [get_ports "MIO[25]"]
    set_property slew "fast" [get_ports "MIO[25]"]
    set_property drive "8" [get_ports "MIO[25]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[25]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[24]"]
    set_property PACKAGE_PIN "B7" [get_ports "MIO[24]"]
    set_property slew "fast" [get_ports "MIO[24]"]
    set_property drive "8" [get_ports "MIO[24]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[24]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[23]"]
    set_property PACKAGE_PIN "E11" [get_ports "MIO[23]"]
    set_property slew "fast" [get_ports "MIO[23]"]
    set_property drive "8" [get_ports "MIO[23]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[23]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[22]"]
    set_property PACKAGE_PIN "A14" [get_ports "MIO[22]"]
    set_property slew "fast" [get_ports "MIO[22]"]
    set_property drive "8" [get_ports "MIO[22]"]
    set_property PIO_DIRECTION "INPUT" [get_ports "MIO[22]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[21]"]
    set_property PACKAGE_PIN "F11" [get_ports "MIO[21]"]
    set_property slew "fast" [get_ports "MIO[21]"]
    set_property drive "8" [get_ports "MIO[21]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[21]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[20]"]
    set_property PACKAGE_PIN "A8" [get_ports "MIO[20]"]
    set_property slew "fast" [get_ports "MIO[20]"]
    set_property drive "8" [get_ports "MIO[20]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[20]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[19]"]
    set_property PACKAGE_PIN "E10" [get_ports "MIO[19]"]
    set_property slew "fast" [get_ports "MIO[19]"]
    set_property drive "8" [get_ports "MIO[19]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[19]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[18]"]
    set_property PACKAGE_PIN "A7" [get_ports "MIO[18]"]
    set_property slew "fast" [get_ports "MIO[18]"]
    set_property drive "8" [get_ports "MIO[18]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[18]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[17]"]
    set_property PACKAGE_PIN "E9" [get_ports "MIO[17]"]
    set_property slew "fast" [get_ports "MIO[17]"]
    set_property drive "8" [get_ports "MIO[17]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[17]"]
    set_property iostandard "LVCMOS18" [get_ports "MIO[16]"]
    set_property PACKAGE_PIN "D6" [get_ports "MIO[16]"]
    set_property slew "fast" [get_ports "MIO[16]"]
    set_property drive "8" [get_ports "MIO[16]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[16]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[15]"]
    set_property PACKAGE_PIN "E6" [get_ports "MIO[15]"]
    set_property slew "slow" [get_ports "MIO[15]"]
    set_property drive "8" [get_ports "MIO[15]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[15]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[14]"]
    set_property PACKAGE_PIN "B6" [get_ports "MIO[14]"]
    set_property slew "slow" [get_ports "MIO[14]"]
    set_property drive "8" [get_ports "MIO[14]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[14]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[13]"]
    set_property PACKAGE_PIN "A6" [get_ports "MIO[13]"]
    set_property slew "slow" [get_ports "MIO[13]"]
    set_property drive "8" [get_ports "MIO[13]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[13]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[12]"]
    set_property PACKAGE_PIN "C5" [get_ports "MIO[12]"]
    set_property slew "slow" [get_ports "MIO[12]"]
    set_property drive "8" [get_ports "MIO[12]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[12]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[11]"]
    set_property PACKAGE_PIN "B4" [get_ports "MIO[11]"]
    set_property slew "slow" [get_ports "MIO[11]"]
    set_property drive "8" [get_ports "MIO[11]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[11]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[10]"]
    set_property PACKAGE_PIN "G7" [get_ports "MIO[10]"]
    set_property slew "slow" [get_ports "MIO[10]"]
    set_property drive "8" [get_ports "MIO[10]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[10]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[9]"]
    set_property PACKAGE_PIN "C4" [get_ports "MIO[9]"]
    set_property slew "slow" [get_ports "MIO[9]"]
    set_property drive "8" [get_ports "MIO[9]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[9]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[8]"]
    set_property PACKAGE_PIN "E5" [get_ports "MIO[8]"]
    set_property slew "fast" [get_ports "MIO[8]"]
    set_property drive "8" [get_ports "MIO[8]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[8]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[7]"]
    set_property PACKAGE_PIN "D5" [get_ports "MIO[7]"]
    set_property slew "slow" [get_ports "MIO[7]"]
    set_property drive "8" [get_ports "MIO[7]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[7]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[6]"]
    set_property PACKAGE_PIN "A4" [get_ports "MIO[6]"]
    set_property slew "fast" [get_ports "MIO[6]"]
    set_property drive "8" [get_ports "MIO[6]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[6]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[5]"]
    set_property PACKAGE_PIN "A3" [get_ports "MIO[5]"]
    set_property slew "fast" [get_ports "MIO[5]"]
    set_property drive "8" [get_ports "MIO[5]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[5]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[4]"]
    set_property PACKAGE_PIN "E4" [get_ports "MIO[4]"]
    set_property slew "fast" [get_ports "MIO[4]"]
    set_property drive "8" [get_ports "MIO[4]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[4]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[3]"]
    set_property PACKAGE_PIN "F6" [get_ports "MIO[3]"]
    set_property slew "fast" [get_ports "MIO[3]"]
    set_property drive "8" [get_ports "MIO[3]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[3]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[2]"]
    set_property PACKAGE_PIN "A2" [get_ports "MIO[2]"]
    set_property slew "fast" [get_ports "MIO[2]"]
    set_property drive "8" [get_ports "MIO[2]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[2]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[1]"]
    set_property PACKAGE_PIN "A1" [get_ports "MIO[1]"]
    set_property slew "fast" [get_ports "MIO[1]"]
    set_property drive "8" [get_ports "MIO[1]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "MIO[1]"]
    set_property iostandard "LVCMOS33" [get_ports "MIO[0]"]
    set_property PACKAGE_PIN "G6" [get_ports "MIO[0]"]
    set_property slew "slow" [get_ports "MIO[0]"]
    set_property drive "8" [get_ports "MIO[0]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "MIO[0]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_VRP"]
    set_property PACKAGE_PIN "N7" [get_ports "DDR_VRP"]
    set_property slew "FAST" [get_ports "DDR_VRP"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_VRP"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_VRN"]
    set_property PACKAGE_PIN "M7" [get_ports "DDR_VRN"]
    set_property slew "FAST" [get_ports "DDR_VRN"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_VRN"]
    set_property iostandard "SSTL15" [get_ports "DDR_WEB"]
    set_property PACKAGE_PIN "R4" [get_ports "DDR_WEB"]
    set_property slew "SLOW" [get_ports "DDR_WEB"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_WEB"]
    set_property iostandard "SSTL15" [get_ports "DDR_RAS_n"]
    set_property PACKAGE_PIN "R5" [get_ports "DDR_RAS_n"]
    set_property slew "SLOW" [get_ports "DDR_RAS_n"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_RAS_n"]
    set_property iostandard "SSTL15" [get_ports "DDR_ODT"]
    set_property PACKAGE_PIN "P5" [get_ports "DDR_ODT"]
    set_property slew "SLOW" [get_ports "DDR_ODT"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_ODT"]
    set_property iostandard "SSTL15" [get_ports "DDR_DRSTB"]
    set_property PACKAGE_PIN "F3" [get_ports "DDR_DRSTB"]
    set_property slew "FAST" [get_ports "DDR_DRSTB"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DRSTB"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS[3]"]
    set_property PACKAGE_PIN "V2" [get_ports "DDR_DQS[3]"]
    set_property slew "FAST" [get_ports "DDR_DQS[3]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS[3]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS[2]"]
    set_property PACKAGE_PIN "N2" [get_ports "DDR_DQS[2]"]
    set_property slew "FAST" [get_ports "DDR_DQS[2]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS[2]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS[1]"]
    set_property PACKAGE_PIN "H2" [get_ports "DDR_DQS[1]"]
    set_property slew "FAST" [get_ports "DDR_DQS[1]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS[1]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS[0]"]
    set_property PACKAGE_PIN "C2" [get_ports "DDR_DQS[0]"]
    set_property slew "FAST" [get_ports "DDR_DQS[0]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS[0]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS_n[3]"]
    set_property PACKAGE_PIN "W2" [get_ports "DDR_DQS_n[3]"]
    set_property slew "FAST" [get_ports "DDR_DQS_n[3]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS_n[3]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS_n[2]"]
    set_property PACKAGE_PIN "P2" [get_ports "DDR_DQS_n[2]"]
    set_property slew "FAST" [get_ports "DDR_DQS_n[2]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS_n[2]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS_n[1]"]
    set_property PACKAGE_PIN "J2" [get_ports "DDR_DQS_n[1]"]
    set_property slew "FAST" [get_ports "DDR_DQS_n[1]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS_n[1]"]
    set_property iostandard "DIFF_SSTL15_T_DCI" [get_ports "DDR_DQS_n[0]"]
    set_property PACKAGE_PIN "D2" [get_ports "DDR_DQS_n[0]"]
    set_property slew "FAST" [get_ports "DDR_DQS_n[0]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQS_n[0]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[9]"]
    set_property PACKAGE_PIN "G1" [get_ports "DDR_DQ[9]"]
    set_property slew "FAST" [get_ports "DDR_DQ[9]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[9]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[8]"]
    set_property PACKAGE_PIN "G2" [get_ports "DDR_DQ[8]"]
    set_property slew "FAST" [get_ports "DDR_DQ[8]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[8]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[7]"]
    set_property PACKAGE_PIN "F1" [get_ports "DDR_DQ[7]"]
    set_property slew "FAST" [get_ports "DDR_DQ[7]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[7]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[6]"]
    set_property PACKAGE_PIN "F2" [get_ports "DDR_DQ[6]"]
    set_property slew "FAST" [get_ports "DDR_DQ[6]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[6]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[5]"]
    set_property PACKAGE_PIN "E1" [get_ports "DDR_DQ[5]"]
    set_property slew "FAST" [get_ports "DDR_DQ[5]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[5]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[4]"]
    set_property PACKAGE_PIN "E3" [get_ports "DDR_DQ[4]"]
    set_property slew "FAST" [get_ports "DDR_DQ[4]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[4]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[3]"]
    set_property PACKAGE_PIN "D3" [get_ports "DDR_DQ[3]"]
    set_property slew "FAST" [get_ports "DDR_DQ[3]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[3]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[31]"]
    set_property PACKAGE_PIN "Y1" [get_ports "DDR_DQ[31]"]
    set_property slew "FAST" [get_ports "DDR_DQ[31]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[31]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[30]"]
    set_property PACKAGE_PIN "W3" [get_ports "DDR_DQ[30]"]
    set_property slew "FAST" [get_ports "DDR_DQ[30]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[30]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[2]"]
    set_property PACKAGE_PIN "B2" [get_ports "DDR_DQ[2]"]
    set_property slew "FAST" [get_ports "DDR_DQ[2]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[2]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[29]"]
    set_property PACKAGE_PIN "Y3" [get_ports "DDR_DQ[29]"]
    set_property slew "FAST" [get_ports "DDR_DQ[29]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[29]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[28]"]
    set_property PACKAGE_PIN "W1" [get_ports "DDR_DQ[28]"]
    set_property slew "FAST" [get_ports "DDR_DQ[28]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[28]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[27]"]
    set_property PACKAGE_PIN "U2" [get_ports "DDR_DQ[27]"]
    set_property slew "FAST" [get_ports "DDR_DQ[27]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[27]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[26]"]
    set_property PACKAGE_PIN "AA1" [get_ports "DDR_DQ[26]"]
    set_property slew "FAST" [get_ports "DDR_DQ[26]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[26]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[25]"]
    set_property PACKAGE_PIN "U1" [get_ports "DDR_DQ[25]"]
    set_property slew "FAST" [get_ports "DDR_DQ[25]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[25]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[24]"]
    set_property PACKAGE_PIN "AA3" [get_ports "DDR_DQ[24]"]
    set_property slew "FAST" [get_ports "DDR_DQ[24]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[24]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[23]"]
    set_property PACKAGE_PIN "R1" [get_ports "DDR_DQ[23]"]
    set_property slew "FAST" [get_ports "DDR_DQ[23]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[23]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[22]"]
    set_property PACKAGE_PIN "M2" [get_ports "DDR_DQ[22]"]
    set_property slew "FAST" [get_ports "DDR_DQ[22]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[22]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[21]"]
    set_property PACKAGE_PIN "T2" [get_ports "DDR_DQ[21]"]
    set_property slew "FAST" [get_ports "DDR_DQ[21]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[21]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[20]"]
    set_property PACKAGE_PIN "R3" [get_ports "DDR_DQ[20]"]
    set_property slew "FAST" [get_ports "DDR_DQ[20]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[20]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[1]"]
    set_property PACKAGE_PIN "C3" [get_ports "DDR_DQ[1]"]
    set_property slew "FAST" [get_ports "DDR_DQ[1]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[1]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[19]"]
    set_property PACKAGE_PIN "T1" [get_ports "DDR_DQ[19]"]
    set_property slew "FAST" [get_ports "DDR_DQ[19]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[19]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[18]"]
    set_property PACKAGE_PIN "N3" [get_ports "DDR_DQ[18]"]
    set_property slew "FAST" [get_ports "DDR_DQ[18]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[18]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[17]"]
    set_property PACKAGE_PIN "T3" [get_ports "DDR_DQ[17]"]
    set_property slew "FAST" [get_ports "DDR_DQ[17]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[17]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[16]"]
    set_property PACKAGE_PIN "M1" [get_ports "DDR_DQ[16]"]
    set_property slew "FAST" [get_ports "DDR_DQ[16]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[16]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[15]"]
    set_property PACKAGE_PIN "K3" [get_ports "DDR_DQ[15]"]
    set_property slew "FAST" [get_ports "DDR_DQ[15]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[15]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[14]"]
    set_property PACKAGE_PIN "J1" [get_ports "DDR_DQ[14]"]
    set_property slew "FAST" [get_ports "DDR_DQ[14]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[14]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[13]"]
    set_property PACKAGE_PIN "K1" [get_ports "DDR_DQ[13]"]
    set_property slew "FAST" [get_ports "DDR_DQ[13]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[13]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[12]"]
    set_property PACKAGE_PIN "L3" [get_ports "DDR_DQ[12]"]
    set_property slew "FAST" [get_ports "DDR_DQ[12]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[12]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[11]"]
    set_property PACKAGE_PIN "L2" [get_ports "DDR_DQ[11]"]
    set_property slew "FAST" [get_ports "DDR_DQ[11]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[11]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[10]"]
    set_property PACKAGE_PIN "L1" [get_ports "DDR_DQ[10]"]
    set_property slew "FAST" [get_ports "DDR_DQ[10]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[10]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DQ[0]"]
    set_property PACKAGE_PIN "D1" [get_ports "DDR_DQ[0]"]
    set_property slew "FAST" [get_ports "DDR_DQ[0]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DQ[0]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DM[3]"]
    set_property PACKAGE_PIN "AA2" [get_ports "DDR_DM[3]"]
    set_property slew "FAST" [get_ports "DDR_DM[3]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DM[3]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DM[2]"]
    set_property PACKAGE_PIN "P1" [get_ports "DDR_DM[2]"]
    set_property slew "FAST" [get_ports "DDR_DM[2]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DM[2]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DM[1]"]
    set_property PACKAGE_PIN "H3" [get_ports "DDR_DM[1]"]
    set_property slew "FAST" [get_ports "DDR_DM[1]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DM[1]"]
    set_property iostandard "SSTL15_T_DCI" [get_ports "DDR_DM[0]"]
    set_property PACKAGE_PIN "B1" [get_ports "DDR_DM[0]"]
    set_property slew "FAST" [get_ports "DDR_DM[0]"]
    set_property PIO_DIRECTION "BIDIR" [get_ports "DDR_DM[0]"]
    set_property iostandard "SSTL15" [get_ports "DDR_CS_n"]
    set_property PACKAGE_PIN "P6" [get_ports "DDR_CS_n"]
    set_property slew "SLOW" [get_ports "DDR_CS_n"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_CS_n"]
    set_property iostandard "SSTL15" [get_ports "DDR_CKE"]
    set_property PACKAGE_PIN "V3" [get_ports "DDR_CKE"]
    set_property slew "SLOW" [get_ports "DDR_CKE"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_CKE"]
    set_property iostandard "DIFF_SSTL15" [get_ports "DDR_Clk"]
    set_property PACKAGE_PIN "N4" [get_ports "DDR_Clk"]
    set_property slew "FAST" [get_ports "DDR_Clk"]
    set_property PIO_DIRECTION "INPUT" [get_ports "DDR_Clk"]
    set_property iostandard "DIFF_SSTL15" [get_ports "DDR_Clk_n"]
    set_property PACKAGE_PIN "N5" [get_ports "DDR_Clk_n"]
    set_property slew "FAST" [get_ports "DDR_Clk_n"]
    set_property PIO_DIRECTION "INPUT" [get_ports "DDR_Clk_n"]
    set_property iostandard "SSTL15" [get_ports "DDR_CAS_n"]
    set_property PACKAGE_PIN "P3" [get_ports "DDR_CAS_n"]
    set_property slew "SLOW" [get_ports "DDR_CAS_n"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_CAS_n"]
    set_property iostandard "SSTL15" [get_ports "DDR_BankAddr[2]"]
    set_property PACKAGE_PIN "M6" [get_ports "DDR_BankAddr[2]"]
    set_property slew "SLOW" [get_ports "DDR_BankAddr[2]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_BankAddr[2]"]
    set_property iostandard "SSTL15" [get_ports "DDR_BankAddr[1]"]
    set_property PACKAGE_PIN "L6" [get_ports "DDR_BankAddr[1]"]
    set_property slew "SLOW" [get_ports "DDR_BankAddr[1]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_BankAddr[1]"]
    set_property iostandard "SSTL15" [get_ports "DDR_BankAddr[0]"]
    set_property PACKAGE_PIN "L7" [get_ports "DDR_BankAddr[0]"]
    set_property slew "SLOW" [get_ports "DDR_BankAddr[0]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_BankAddr[0]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[9]"]
    set_property PACKAGE_PIN "H5" [get_ports "DDR_Addr[9]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[9]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[9]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[8]"]
    set_property PACKAGE_PIN "J5" [get_ports "DDR_Addr[8]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[8]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[8]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[7]"]
    set_property PACKAGE_PIN "J6" [get_ports "DDR_Addr[7]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[7]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[7]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[6]"]
    set_property PACKAGE_PIN "J7" [get_ports "DDR_Addr[6]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[6]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[6]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[5]"]
    set_property PACKAGE_PIN "K5" [get_ports "DDR_Addr[5]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[5]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[5]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[4]"]
    set_property PACKAGE_PIN "K6" [get_ports "DDR_Addr[4]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[4]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[4]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[3]"]
    set_property PACKAGE_PIN "L4" [get_ports "DDR_Addr[3]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[3]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[3]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[2]"]
    set_property PACKAGE_PIN "K4" [get_ports "DDR_Addr[2]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[2]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[2]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[1]"]
    set_property PACKAGE_PIN "M5" [get_ports "DDR_Addr[1]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[1]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[1]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[14]"]
    set_property PACKAGE_PIN "G4" [get_ports "DDR_Addr[14]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[14]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[14]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[13]"]
    set_property PACKAGE_PIN "F4" [get_ports "DDR_Addr[13]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[13]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[13]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[12]"]
    set_property PACKAGE_PIN "H4" [get_ports "DDR_Addr[12]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[12]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[12]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[11]"]
    set_property PACKAGE_PIN "G5" [get_ports "DDR_Addr[11]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[11]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[11]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[10]"]
    set_property PACKAGE_PIN "J3" [get_ports "DDR_Addr[10]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[10]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[10]"]
    set_property iostandard "SSTL15" [get_ports "DDR_Addr[0]"]
    set_property PACKAGE_PIN "M4" [get_ports "DDR_Addr[0]"]
    set_property slew "SLOW" [get_ports "DDR_Addr[0]"]
    set_property PIO_DIRECTION "OUTPUT" [get_ports "DDR_Addr[0]"]
    set_property iostandard "LVCMOS33" [get_ports "PS_PORB"]
    set_property PACKAGE_PIN "B5" [get_ports "PS_PORB"]
    set_property slew "slow" [get_ports "PS_PORB"]
    set_property drive "8" [get_ports "PS_PORB"]
    set_property iostandard "LVCMOS33" [get_ports "PS_SRSTB"]
    set_property PACKAGE_PIN "C9" [get_ports "PS_SRSTB"]
    set_property slew "slow" [get_ports "PS_SRSTB"]
    set_property drive "8" [get_ports "PS_SRSTB"]
    set_property iostandard "LVCMOS33" [get_ports "PS_CLK"]
    set_property PACKAGE_PIN "F7" [get_ports "PS_CLK"]
    set_property slew "slow" [get_ports "PS_CLK"]
    set_property drive "8" [get_ports "PS_CLK"]
    system_rst_clk_wiz_0_100M_0_board.xdc
    system_rst_clk_wiz_0_100M_0.xdc
    set_false_path -through [get_ports ext_reset_in]
    system_rst_clk_wiz_0_100M_0_ooc.xdc
    create_clock -name slowest_sync_clk -period 10 [get_ports slowest_sync_clk]
    system_rst_processing_system7_0_100M_1.xdc
    system_rst_processing_system7_0_100M_1_board.xdc
    system_rst_processing_system7_0_100M_1_ooc.xdc
    system_auto_us_0_ooc.xdc
    create_clock -period 100.0 -name aclk [get_ports *_axi_aclk]
    system_auto_us_0_clocks.xdc
    system_clk_wiz_0_1.xdc
    create_clock -period 10.0 [get_ports clk_in1]
    set_input_jitter [get_clocks -of_objects [get_ports clk_in1]] 0.1
    system_clk_wiz_0_1_ooc.xdc
    system_clk_wiz_0_1_board.xdc
    system_xbar_0_ooc.xdc
    create_clock -period 100.0 -name aclk [get_ports aclk]
    system_auto_pc_1_ooc.xdc
    system_auto_pc_0_ooc.xdc
    system_v_tpg_0_1_ooc.xdc
    create_clock -name aclk -period 6.734 [get_ports aclk]
    create_clock -name s_axi_aclk -period 10 [get_ports s_axi_aclk]
    system_v_tpg_0_1_clocks.xdc
      set video_clk   [get_clocks -of [get_ports aclk]]
      set axilite_clk [get_clocks -of [get_ports s_axi_aclk]]
      set_max_delay -from $video_clk -to [get_cells -hierarchical -filter {NAME =~ *video_cntrl*/*SYNC2PROCCLK_I*/data_sync_reg[0]*}] -datapath_only [get_property -min PERIOD $video_clk]
      set_max_delay -from $axilite_clk -to [get_cells -hierarchical -filter {NAME =~ *video_cntrl*/*SYNC2VIDCLK_I*/data_sync_reg[0]*}] -datapath_only [get_property -min PERIOD $axilite_clk]
    Sorry for the delay,
    I posted a comment days ago but it still has not been added to this thread. Said waiting for admin confirmation I am guessing due to the length of the message.
    I have tried adding the Clocking Wizard IP core to the design which uses the MCMM to generate the 148.5MHz clock fro ma 100MHz clock. I still however get the failing timing problem. The problem happens when I connect the Test Pattern Generator to the VDMA IP Blocks. The design works fine at 100MHz at a low resolution. This is what caused me to try to increase the clock frequency as per the datasheet for the test pattern generator. It is asking for 148.5MHz at 1080p. The problem I encountered with 100MHz is the image that gets transferred into memory is alternating between a good frame and a corrupted frame.
    I have looked through the timing constraints on both the HDMI tutorial design as well as the FMC_IMAGEON design but the constraints look the same apart from pin assignments. I have a problem running the sample designs due to a problem with applying the license for the video evaluation, this prevents me from running the tutorials. It complains about the v_spec, v_cfa, ect cores.
    The constants that are automatically in the vivado project folder for this design ad linked below. I am not sure how what constraints must be applied to this design to make it work. If you could clarify the constraints it would be appropriated.
    pastebin.com/43BR59U7
  • drozwood90
    Hi cuboard,
    I can't really do a detailed debug analysis of your design.  I would recommend that you take a look at some of the Vivado constraints training materials and training sessions on the Xilinx website.  I think that will help you the most.
    If you cannot get the Xilinx IP to license properly, you need to go to the Xilinx forums and get help from Xilinx.  Their system controls the licensing.  After you get the licensing straightened out, you will be able to run the example designs that I noted before.  That might be the most productive use of your time in getting a handle on why your design is not meeting timing.
    --Dan
