Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Azure Sphere MT3620 Starter Kit by AVNET - how many UART?
  • Subscribers 51 subscribers
  • Views 517 views
  • azurespherech
  • azure sphere
  • azuresphkt
frelfrel
frelfrel over 7 years ago
I need to use in Azure Sphere MT3620 Starter Kit by AVNET two UART - is it possible?
3x ISU interfaces pre-configured for UART, SPI, I2C - if so how to reconfigure it?
  • peterfenn
    peterfenn over 7 years ago +4
    The following info and more, has been posted as a separate blog titled: Azure Sphere - Tips to Max-out your Avnet Starter Kit Hardware! Clarification here on the statement that the three ISUs accessible…
  • peterfenn
    Clarification here on the statement that the three ISUs accessible on this Starter Kit are "preconfigured":
    The limitation is the reduced number of ISU signals pinned-out of the module for support of:
    • ISU0: UART0 (4 IOs)
    • ISU1: SPI1 (5 IOs)
    • ISU2: I2C2 (2 IOs)
    Within these pinout limitations, these can however be assigned as follows:
    • ISU0: use for I2C, UART or SPI
    • ISU1: use for I2C, UART or SPI
    • ISU2: use for I2C only
    The table below shows in blue text the functions these ISUs are "assigned" to on the Starter Kit, followed by the alternative interfaces supported by these pins
    The table below shows in blue text the functions that other GPIOs have been assigned to on the Starter Kit
    TXD outputs of the two M4 dedicated UARTs are available on (unpopulated) J11 pins
    These can alternatively be used for GPIO functions
    For detailed information on your Starter Kit's hardware capabilities, refer to the following documents:
    Hardware User Guide - Azure Sphere MT3620 Starter Kit
    Block Diagram - Azure Sphere MT3620 Starter Kit
    AES-MS-MT3620-SK-G_SCH_2019-07-03
    This should make your available options a lot clearer...  :-)
    -Peter
  • xeonaj
    xeonaj over 7 years ago in reply to peterfenn
    Thanks for the GOOD answer It was a lot helpful in fact I was just wondering how to get started with Azure Sphere.
