Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Failed to create an Azure Sphere tenant
  • Replies 15 replies
  • Answers 6 answers
  • Subscribers 56 subscribers
  • Views 2906 views
  • azurespherech
  • azure sphere
  • azuresphkt
  • sensing the world
agent1174
agent1174 over 7 years ago
I have been trying to setup azure sphere under my school account. I noticed when I login to Azure i get a message "You are not eligible for an Azure subscription". I'm thinking this isn't going to work well with azure sphere so I create/login to a private .onmicrosoft account but now I get an error "Unable to create a Azure Sphere tenant". I did not claim my device on my school account but I did create a tenant. What could be the problem? Have I gone beyond the point of no return by creating a tenant under my school account?
  • frelfrel
    frelfrel over 7 years ago +3 suggested
    I think there is solotion: https://rzetelnekursy.pl/azure-sphere-first-step-the-device-is-not-responding-an-unexpected-problem-occurred-please-try-again-if-the-issue-persists-please-refer-to-aka-msazurespheresupport…
  • Fred27
    Fred27 over 7 years ago +3 suggested
    I had problems with the device being permanently unresponsive. It turned out a service (Azure Sphere Communication Service or something like that) was failing to start. I reinstallation of the SDK did…
    michaelkellett over 7 years ago in reply to agent1174 +2 suggested
    Are we beginning to understand why they are giving them away ! (I think it's fairly clear that it's a work in progress.) For my own part I hadn't realised that you can only run the MS tools under Windows…
    0 dougw over 7 years ago
    If you really need to create another tenant you can use this command:
    azsphere tenant create --force --name <my-tenant>
    https://docs.microsoft.com/en-us/azure-sphere/install/create-tenant
  • agent1174
    0 agent1174 over 7 years ago in reply to dougw
    Even with -force command it does not work. I get:
    error: Failed to create an Azure Sphere tenant with name 'WildFrontierNET'.
    Trace ID: 89805ca1-9149-4074-82f6-eafc62e3b27b
    error: An unexpected problem occurred. Please try again; if the issue persists, please refer to aka.ms/azurespheresupport for troubleshooting suggestions and support.
    error: Command failed in 00:00:17.7872009.
    0 michaelkellett over 7 years ago in reply to agent1174
    For my own part I hadn't realised that you can only run the MS tools under Windows 10 - so until I get a Windows 10 machine running I'm paused.
  • Fred27
    0 Fred27 over 7 years ago
    Have you got more details of the error. You may find that you need to add a new user to to Azure subscription first, as described here:
    https://docs.microsoft.com/en-us/azure-sphere/install/azure-directory-account#create-a-new-account-and-directory-that-are-not-associated-with-any-other-account
  • agent1174
    0 agent1174 over 7 years ago in reply to Fred27
    I have followed the instructions at that link and I have added a new user to my AAD. I can log in to the new user through Azure Sphere but when I try to create a tenant I get the same error. Can you confirm/deny that creating a tenant is a one time operation per device? I am reading conflicting information on this.
  • peterfenn
    0 peterfenn over 7 years ago in reply to agent1174
    Note:
    1) Creation of a new tenant account with a particular device attached, is only allowed once
    2) The attached device can only be "claimed" to a tenant once
    To check if you've already created a tenant under your AAD, use the following command:
    azsphere tenant list
    PS: Two tips in context of azsphere commands:
    - suffix the command with -? for help on that command
    - suffix the command with -v for verbose output from that command
  • agent1174
    0 agent1174 over 7 years ago in reply to peterfenn
    When I run the command "azsphere tenant list" under my .onmicrosoft login I get the following output:
    warn: No Azure Sphere tenants found under the selected AAD user.
    warn: Use 'azsphere login' to change AAD user, or create a new Azure Sphere tenant using 'azsphere tenant create'.
    error: You do not have access to any Azure Sphere tenants.
    error: Command failed in 00:00:52.6463894.
    When I run the same command logged into my school account I get
    warn: The selected Azure Sphere tenant has been set to 'Wild Frontier NET' (3d179f1b-150c-442e-be4a-14c0c5b15223).
    Successfully logged in with the selected AAD user. This authentication will be used for subsequent commands.
    Command completed successfully in 00:03:29.4363306.
    So am I correct in my understanding that I have essentially bricked my device by creating a tenant under an account that has no Azure subscription access?
  • peterfenn
    Dave
    This not a situation I've encountered before. I recommend re-posting your most recent summary (+ any additional info that may help the Microsoft tech support team) as a support ticket on the Microsoft-hosted Azure Sphere support forum at https://social.msdn.microsoft.com/Forums/en-US/home?forum=azuresphere/
    -Peter
  • peterfenn
    0 peterfenn over 7 years ago in reply to peterfenn
    Dave
    If this is your post on MSDN, I suggest provide the additional detail and re-specify the question
    https://social.msdn.microsoft.com/Forums/en-US/b9fa2b25-1b29-41df-a523-42292f73f808/failed-to-create-an-azure-sphere-ten…
    -Peter
  • peterfenn
    Per the clarification on this topic, at the Microsoft MSDN support forum:
    Use of different work/school accounts for your Azure Sphere tenant and Azure subscription does not "brick" your Starter Kit, it just adds uneccessary complexity
    If a tenant already exists, do NOT create another one unless your company/organization has good reason for doing so!
    Microsoft recommends each company/organization only creates one Azure Sphere tenant.
    Note: Beyond the one-time tenant assignment, Microsoft enables a variety of deployment mechanisms to support OTA updates of different SKUs, SKU sets, regional versions, etc
    https://docs.microsoft.com/en-us/azure-sphere/deployment/deployment-concepts
