Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum IOT Central doesn't receive telemetry / events?
  • Subscribers 51 subscribers
  • Views 1157 views
  • azurespherech
  • azure sphere
  • azuresphkt
alexpawlak
alexpawlak over 7 years ago
Hey there!
I tried to follow Azure IOT Central blog by @bwilless to get started with Avnet Azure Sphere, but seemingly something's wrong with what I did and I have no idea how to troubleshoot it.
First off - the device get's provisioned - so the connectivity is there. Wifi is connected, all working fine, IOTHubClient is accepting the message but never sends it to Azure IOT central...
[Info] Sending telemetry: {"gX":"95.8920", "gY":"-6.9540", "gZ":"1003.5720", "pressure": "997.65", "aX": "-0.07", "aY": "-0.07", "aZ": "0.00"}
[Azure IoT Hub client] INFO: IoTHubClient accepted the message for delivery
LSM6DSO: Acceleration [mg]  : 96.0140, -6.7100, 1003.3280
LSM6DSO: Angular rate [dps] : -0.07, 0.00, 0.00
LSM6DSO: Temperature  [degC]: 37.30
LPS22HH: Pressure     [hPa] : 997.67
LPS22HH: Temperature  [degC]: 35.64
[Info] Sending telemetry: {"gX":"96.0140", "gY":"-6.7100", "gZ":"1003.3280", "pressure": "997.67", "aX": "-0.07", "aY": "0.00", "aZ": "0.00"}
On one of the screenshots there is a step: "[INFO] Connection to IOT Hub has been established" - I think I've never seen it in the output.
Any idea how to troubleshoot Azure IOT Central connectivity ?
Thanks for any help!
Alex Pawlak
Avnet's Azure Sphere Starter-Kit (Out of Box Demo) Part 3 of 3
  • bwilless
    bwilless over 7 years ago +2 verified
    Hi Alex, There are a couple of tools that you can use to see data going to Azure. For IoT Central you can use the iotc-explorer utility. Details on the tool and how to use it are here: https://github.com…
  • bwilless
    bwilless over 7 years ago +2 suggested
    Some other thoughts . . . Did you update your "allowed connections" entry in the app_manifest.json file with the IoT Hub FQDN? The OS will not allow any data to an FQDN that's not listed in this section…
  • alexpawlak
    alexpawlak over 7 years ago in reply to bwilless +1
    Hey! I'm quite sure it has been network-related. For some reason my ISP has been blocking the connection. I have created a new Wifi profile for my mobile hotspot and the app started running perfectly fine…
  • bwilless
    0 bwilless over 7 years ago
    Hi Alex,
    There are a couple of tools that you can use to see data going to Azure.  For IoT Central you can use the iotc-explorer utility.  Details on the tool and how to use it are here:  https://github.com/Azure/iotc-explorer
    From Visual Studio you can also use the Visual Studio Cloud Explorer to see data going to/from Azure.  Details here:  https://docs.microsoft.com/en-us/visualstudio/azure/vs-azure-tools-resources-managing-with-cloud-explorer?view=vs-2019
    You mention that you see that the device gets provisioned, do you see the debug output stating that the IoT Hub connection has been established?
    Brian
  • bwilless
    Did you update your "allowed connections" entry in the app_manifest.json file with the IoT Hub FQDN?  The OS will not allow any data to an FQDN that's not listed in this section.
    Did you set the build options to use IoT Central as opposed to IoT Hub?
    Brian
  • alexpawlak
    0 alexpawlak over 7 years ago in reply to bwilless
    Hey!
    I'm quite sure it has been network-related. For some reason my ISP has been blocking the connection. I have created a new Wifi profile for my mobile hotspot and the app started running perfectly fine as expected. It made me think there's something wrong with networking as I tried to follow IOT Hub scenario and failed in similar fashion. I'm not sure about networking with IoT but it seems this has been something my ISP has been blocking for reasons they only know.
    It's ALWAYS network fault :-)
  • bwilless
    0 bwilless over 7 years ago in reply to alexpawlak
    Hi Alex,
    I just posted a new blog focused on troubleshooting IoT Hub connection issues.  There's a section on verifying that the required network ports are open.  Can you try these steps and report back on which port(s) were blocked by your ISP?
    Troubleshooting Azure IoT Hub Connection Issues
    Brian
