BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Embedded World 2023 - BeaglePlay Give Away, Meet & Greet with Jason Kridner
Join BeagleBoard to participate - click to join for free!
  • Replies 25 replies
  • Subscribers 107 subscribers
  • Views 4862 views
  • embedded world 2023
e14phil
e14phil over 3 years ago
At Embedded World 2023 we are Giving Away up to 10 BeaglePlay®︎
Are you attending Embedded World 2023 in person?
We are hosting a giveaway of limited number of BeaglePlay on Wednesday 15th March with the Chance to Meet Jason Kridner, co-founder of the BeagleBoard.org project (https://beagleboard.org/about/jkridner)
BeaglePlay is an open-source single board computer designed to simplify the process of adding sensors, actuators, indicators, human interfaces, and connectivity to a reliable embedded system. It features a powerful 64-bit, quad-core processor and innovative connectivity options, including Wi-Fi, Gigabit Ethernet, sub-GHz wireless, and single-pair Ethernet with power-over-data-line.
With compatibility with 1,000s of off-the-shelf add-ons and a customized Debian Linux image,
BeaglePlay makes expansion and customization easy. It also includes ribbon-cable connections for cameras and touch-screen displays, and a socket for a battery-backed real-time-clock, making it ideal for human-machine interface designs. With its competitive price and user-friendly design, BeaglePlay provides a positivedevelopment experience for users.
  • Multicore A53s with R5, M4s and PRUs processor, TI AM6254
  • Wi-Fi/2.4G, MIMO/5G, SISO M2 1216, TI WL1807 Wi-Fi module, U.FL x2
  • TI BLE/SubG CC1352P7 M4+M0 with BeagleConnect firmware
  • 2GB(1Gb x 16)-1600MHz 3200Mbps DDR
  • Kingston 16GB eMMC
  • Gigabit Ethernet with RJ45 x1, single pair Ethernet and power over with RJ11
  • Power input with USB Type-C
  • HDMI Type-A supports up to Full-HD/1080P with 24-bit RGB
  • Support FPC 22pin CSI and FPC 40pin OLDI
  • 1x MikroBus connector, 1x USB Type-A, 1x micro SD socket, 1x QWIIC, 1x grove connector, 1x RTC
How To Win
EDIT: All BeaglePlay have been collected, thank you to everyone who turned up and entered!
T&C Apply!
Map
Terms and Conditions
  • e14phil
    e14phil over 3 years ago +6
    I got mine here on the community stand at Embedded world!
  • e14phil
    e14phil over 3 years ago in reply to misaz +3
    Thank you for picking up your BeaglePlay!
  • e14phil
    e14phil over 3 years ago in reply to securely +3
    Thank you!!
  • bidrohini
    bidrohini over 3 years ago
    Sounds like a good opportunity. All the best to the participants.
    shabaz over 3 years ago
    Hi Phil,
    I hope you all have fun there, as well as a productive work time! I was wondering, can you get these from Embedded World if they are available, for a small giveaway too : ) They are on the Farnell website, but not in stock for a month : (
    Also, question for Jason : )
    Anyone working on a tutorial for using the BeagleConnect Freedom with Windows? (e.g. using Windows Subsystem for Linux). It will be nice for people to quickly get started that way on a desktop, before moving to a Linux board.
  • misaz
    misaz over 3 years ago
    I like the device has chip with Sub-GHz communication support which makes this device unique. Other SBC usualy has Wi-FI/BLE but sub-GHz requires additional module/shield. I do not know how hard would it be to implement because it is not handled by main CPU.
    I plan to atend Embedded world this year so I most probably will meet you at wednesday. My project proposal featuring sub-GHz is gateway for connecting multiple low-power remote sensors sending their measurements over 433 MHz band and non-low-power BeaglePlay listening for data from sensors on 433 MHz band and forwarding data to the Internet (cloud). This results to systeminto system that many sensors can run on battery and one gateway connects all of them to the internet.
  • abecker
    abecker over 3 years ago
    Use it in Home automation with BLE/ Wifi, and subGhz Sensor communications.
    And .. my local Music server with Display
  • koudelad
    koudelad over 3 years ago
    As shabaz mentioned, BeaglePlay would be best tested with one or more BeagleConnect Freedom modules.
    I use a variety of sensors for measuring ambient environment - SHTC3 and SHT31 for temperature and humidity, LPS22HH for ambient pressure, SCD30 as an IR CO2 sensor, SGPC3 as a VOC sensor, SPS30 for mass concentration in the air and SFA30 to detect formaldehyde. This setup has been working for almost 3 years in two homes.
    sensors
    All the sensors are connected to an STM32G071, which creates a sensor hub and published all the measured data via a serial port to the raspberry pi, which stores the values through node-red into an influx db. It also publishes the data via a web interface of Chronograf.
    I have been thinking a lot about making this compact, but also wireless, mainly for the possibility to connect three of these sensor hubs into one concetrator for data visualization and finding some trends and predictions.
    I am really curious about the sub-ghz interface and making it easy for me as a developer to embed the wireless communication as simple as possible. The reason why I haven't made this wireless, yet, is the complexity. Also, I don't think it is a good idea to invent own transfer protocols. BeaglePlay and BeagleConnect Freedom might really help in this. I am very curious and looking forward to seeing it more in depth!
    shabaz over 3 years ago in reply to koudelad
    Very nice sensor selection! It seems an ideal candidate for the BeagleConnect Freedom + BeaglePlay combination.
  • qba667
    qba667 over 3 years ago
    Having on bard sub-1GHz module together with 2.4 GHz protocols Zigbee, Thread, Ethernet, 5Ghz WiFi and power over RJ 11 make it perfect for my current project.
    Project: Open Source Smart Home Control with Human Machine Interface
    The project aims to provide ready to use platform for home automatization with integrated wireless solution.
    Integrating devices using well know protocols as Zigbee Thread and Amazon Sidewalk (Amazon Echo devices, Ring Security Cams end others) into single platform.
    Power full embedded platform allows hosting of all services on device instead of using cloud providers without additional hardware.
    Operating system: Debian
    Pre-installed software:
    • Home Assistant - brilliant HMI
    • Node Red for configuration of advanced flows
    • Zigbee2mqtt for integration of Zigbee devices
    • Eclipse Mosquitto - as MQTT Hub
    • Eclipse Ditto - for digital twin representation
    General challenges:
    • Integrate Zigbee2mqtt with BeagleConnect
    • Matter integration
    • Add support for OpenTherm protocol
    Challenges for CC1352P7 BeagleConnect:
    • include support of Elero/Somfy protocols for windows curtains - working prototype on other TI chip
    • include support Bresser Weather Stations
    Challenges for HMI:
    • selection of display and digitizer
    I will be glad to run the project on the BeaglePlay  instead of the RPI 4 with wireless adapters.
  • axeljust
    axeljust over 3 years ago
    Would love to see if it's powerful enough to run Home assistant natively!
  • e14phil
    • Vote Up +6 Vote Down
  • darksidedevel
    darksidedevel over 3 years ago in reply to qba667
    Cool, I was thinking about similar solution!
