Technical Library
  • Technical Library
Technical Library
Documents Cypress: CY8CKIT-025 PSoC Precision Analog Temperature Sensor Expansion Board
  • Author Author: atomar
  • Date Created: 15 May 2013 4:24 AM Date Created
  • Last Updated Last Updated: 11 Feb 2014 2:59 AM
  • Views 1843 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Overview
The CY8CKIT-025CY8CKIT-025 PSoCRegistered Precision Analog Temperature Sensor Expansion Board Kit (EBK) includes 4 temperature sensors and examples projects to make temperature sensing and control design quick and easy. This kit enables the designer to measure temperature accurately to a resolution of 0.1º C.
The kit supports temperature measurement using four temperature sensors:
  • Thermocouple
  • Thermistor
  • Resistive Temperature Detector (RTD)
  • Diode
The CY8CKIT-025CY8CKIT-025 EBK is designed for use with the CY8CKIT-030CY8CKIT-030 PSoC 3 Development Kit and the CY8CKIT-001CY8CKIT-001 PSoC Development Kit (all sold separately). Combining CY8CKIT-025 EBK with a development kit provides a complete single chip temperature sensing and control solution.
Cypress’s PSoC programmable system-on-chip architecture gives you the freedom to not only imagine revolutionary new products, but the capability to also get those products to market faster than anyone else. PSoC Creator is a state-of-the-art, easy-to-use IDE that introduces a game-changing hardware and software co-design environment based on classical schematic entry – a revolutionary embedded design.
Key Applications: Consumer, Industrial and Medical Applications
imageMore Cypress Development KitsimageCypress Overview
imageKnode Development Kits & Platform Roomimageelement14 Knode
Development Tools
Software Development Tools:
Tool   TypeSupplierMPNSupported   FamilyDescription
IDECypressPSoC DesignerPSoC 1
PSoC Designer IDE accelerates system bring-up and time-to-market. Develop the applications using a library of pre-characterized analog and digital peripherals in a drag-and-drop design environment. Then, customize the design leveraging the dynamically generated API libraries of code.  Finally, debug and test the designs with the integrated debug environment including in-circuit emulation and standard software debug features. PSoC Designer supports the entire library of PSoC 1 devices.
Programmer SoftwareCypressPSoC ProgrammerAll PSoC
The PSoC Programmer software tool supports all Cypress PSoC programming hardware and PSoC devices. PSoC Programmer is a simple GUI that connects to programming hardware to program and configure PSoC devices. From the GUI users will be able to select the target device, configure programming selections and execute a number of programming actions such as Program, Read, Verify and Erase. PSoC Programmer is a required installation for both PSoC Creator and PSoC Designer.
IDECypressPSoC CreateorPSoC 3 / PSoC 4 / PSoC 5 / PSoC 5LP
PSoCRegistered CreatorTm is a state-of-the-art software development IDE combined with a revolutionary graphical design editor to form a uniquely powerful hardware/software co-design environment. This co-design approach frees embedded designers from hardware re-spins and software hacks. It also enables immediate testing of new ideas, rapid response to hardware changes, and error-free software interaction with on-chip peripherals.  Learn More
IDEARMKeil C51All 8051 Core
The Keil C51 development tools for the 8051 Microcontroller Architecture support every level of software developer from the professional applications engineer to the student just learning about embedded software development. Learn More
IDEARMKeil MDK-ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9Tm
The MDK-ARM is a complete software development environment for CortexTm-M, Cortex-R4, ARM7Tm and   ARM9Tm processor-based devices. MDK-ARM is specifically designed for microcontroller applications, it is easy to learn   and use, yet powerful enough for the most demanding embedded applications.Learn   More
RTOSSeggerembOSARM CortexTm-M
embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of   embedded real-time applications. It is a zero interrupt latency, high-performance RTOS that has been optimized for   minimum memory consumption in both RAM and ROM, as well as high speed and versatility.  Learn More
Hardware Development Tools:
Emulator / DebuggerCypressCY3215-DKCY3215-DKPSoC 1PSoC 1 In-Circuit Emulation Development Kit
Emulator / Debugger / ProgrammerCypressCY8CKIT-002CY8CKIT-002PSoC 1 / PSoC 3 / PSoC 5MiniProg3 Program and Debug Kit is an all-in-one programmer for PSoC 1, PSoC 3 and PSoC 5 architectures and debug tool for PSoC 3 and PSoC 5 architectures
ProgrammerCypressCY3217CY3217PSoC 1 (CY25/26xxx devices)
Miniprog1 programmer
Emulator / Debugger / ProgrammerARMULINK2ULINK2All 8051 Core/ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideCypress: User Guide for CY8CKIT-025 PSoC Analog Temperature Sensor Expansion Board
User GuideCypress: Quick Start Guide for CY8CKIT-025 PSoC Analog Temperature Sensor Expansion Board
Revision Note
Cypress: Release Note for CY8CKIT-025
Application NoteCypress: AN60590 - Application Note for Temperature Measurement Using Diode(PSoC 3 and PSoC 5)
Application NoteCypress: AN66477 - Application Note for Temperature Measurement with Thermistor(PSoC 3 and PSoC 5)
Application NoteCypress: AN75511 - Application Note for Temperature Measurement with a Thermocouple (PSoCRegistered 3 / PSoC 5LP)
Application NoteCypress: AN65977 - Application Note for Creating an Interface to a TMP05/TMP06 Digital Temperature Sensor (PSoCRegistered 3 and PSoC 5LP )
Application NoteCypress: AN70698 - Application Note for Temperature Measurement with an RTD(PSoCRegistered 3 and PSoC 5LP)
Design Elements
TypeDescription
SchematicsCypress: Schematic for CY8CKIT-025 PSoC Precision Analog Temperature Sensor Expansion Board
BOMCypress: BOM for CY8CKIT-025 PSoC Precision Analog Temperature Sensor Expansion Board
LayoutCypress: Layout for CY8CKIT-025 PSoC Precision Analog Temperature Sensor Expansion Board
Application LibraryCypress: Application Library for CY8CKIT-025 PSoC Precision Analog Temperature Sensor Expansion Board
Back to top
Video
Video1Video2
This video is unavailable.
Back to top
Kit Features
Features of CY8CKIT-025CY8CKIT-025:
  • The kit enables the designer to measure temperature accurately to a resolution of 0.1º C.
  • The kit supports temperature measurement using four temperature sensors:
    • Thermocouple
      • Thermocouples measure temperatures in a wide range, from –250 °C to 2300 °C. However, the voltage change is not linear and takes more CPU cycles for temperature computation. Thermocouples require another temperature sensor, such as the thermistor, diode, or RTD, to measure the cold junction temperature. The DS600DS600 IC or the thermistor can be used for cold junction compensation of the thermocouple. A thermistor, diode, or RTD cannot measure temperatures greater than 850 °C. Thermocouples have a very good response time
    • Thermistor
      • Thermistors have a highly nonlinear curve and take more CPU cycles for temperature computation. They measure temperature in the range –100 °C to 200 °C. Thermistors have a good response time and they are less expensive when compared to RTDs and thermocouples.
      • RTDs have a linear and repeatable resistance variation with temperature, making it easier to compute temperature accurately. They measure temperature from –200 °C to 850 °C. RTDs are expensive due to their linearity and accuracy. RTDs have a lower response time compared to a thermistor or thermocouple.
    • Diode
      • Diodes are the cheapest sensors for temperature measurement. They measure temperature in the range –50 °C to 150 °C. Accurate temperature measurement is difficult with a diode.
  • Cypress’s PSoC programmable system-on-chip architecture gives you the freedom to not only imagine revolutionary new products, but the capability to also get those products to market faster than anyone else.
Temperature Sensor Comparison:
ParameterRTDThermocoupleThermistorDiode
Temperature range (°C)
–200 to +850–250 to +2350–100 to +300–50 to +150
Sensitivity at 25 °C0.387 Ω/°C40 μV/°C (K-type)416 Ω/°C250 μV /°C
AccuracyHighMedium to HighMediumLow
LinearityGoodFairPoorGood
Typical distance of sensing
Surface mount for onboard temperature
3- and 4-wire up to a few hundred meters
<100 meters
temperature Leaded for <1 meter
On-board temperature
Resource requirement
Excitation current,amplifier,
ADC, reference resistor
Amplifier, ADC, voltagereference, and another
temperature sensor for cold junction
Excitation current,
Excitation current,
amplifier, ADC
Response timeSlowFastFastSlow
Computational complexity
(best possible accuracy)
HighVery highVery highMedium
Back to top
Kit Contents
The Cypress CY8CKIT-025CY8CKIT-025 Temperature Sensor Expansion Board supplied with below contents:
  • CY8CKIT-025CY8CKIT-025 PSoC Precision Analog Temperature Sensor Board
  • Two CY8CKIT-012CY8CKIT-012 Prototype Boards
  • Omega Thermocouple K-Type 5srtc-gg-20-36
  • Two 2N39042N3904 NPN Transistors
  • Two Prototype Headers for CY8CKIT-012 Prototype Board
  • Quick Start Guide
  • Resource CD
  • Wires
  • Mini Philips Cross Screw Driver (Black)
Back to top
  • cy8ckit-012
  • 2n3904
  • ds600
  • cy8ckit-001
  • cy8ckit-030
  • cy8ckit-025
  • cypress
  • temperature_sensor
  • psoc
