Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: EKT-LM4F232 USB+CAN Evaluation Kit for TM4C123GH6PGE MCU
  • Author Author: atomar
  • Date Created: 20 Aug 2013 9:53 AM Date Created
  • Last Updated Last Updated: 22 Nov 2013 7:03 AM
  • Views 1661 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The TivaTm C Series LM4F232 USB+CAN Development Kit (EK-LM4F232EK-LM4F232) is a compact and versatile evaluation platform for the Tiva C series TM4C123GH6PGETM4C123GH6PGE ARMRegistered CortexTm-M4F-based microcontroller. The evaluation kit design highlights the TM4C123GH6PGE microcontroller integrated USB 2.0 On-the-Go/Host/Device interface, CAN, analog, and low-power capabilities.
The evaluation kit features the TM4C123GH6PGETM4C123GH6PGE microcontroller, a color OLED display, USB OTG connector, a microSD card slot, a coin cell battery for use with the Tiva C Series low-power Hibernate mode, a temperature sensor, a three-axis accelerometer for motion detection, and easy access through holes to all of the available device signals. The kit also includes extensive source code examples, allowing you to start building C code applications quickly.
The software provided with the EK-LM4F232EK-LM4F232 provides access to all of the peripheral devices supplied in the design. The StellarisWareRegistered Peripheral Driver Library is used to operate the on-chip peripherals. The software includes a set of example applications that use the StellarisWareRegistered Peripheral Driver Library. These applications demonstrate the capabilities of the TM4C123GH6PGETM4C123GH6PGE microcontroller, as well as provide a starting point for the development of the final application for use on the EK-LM4F232 evaluation board. The EK-LM4F232 Evaluation Kit CD also contains a Windows quickstart companion for the Data Logger quickstart application. The companion application provides a strip-chart display for up to 10 channels of data from the EK-LM4F232 evaluation board.
Texas Instruments TivaTm C Series microcontrollers provide designers a high-performance ARMRegistered CortexTm-M-based architecture with a broad set of integration capabilities and a strong ecosystem of software and development tools. Targeting performance and flexibility, the TivaTm C Series architecture offers a 80 MHz Cortex-M with FPU, a variety of integrated memories and multiple programmable GPIO. TivaTm C Series devices offer consumers compelling cost-effective solutions by integrating application-specific peripherals and providing a comprehensive library of software tools which minimize board costs and design-cycle time. Offering quicker time-to-market and cost savings, the TivaTm C Series microcontrollers are the leading choice in high-performance 32-bit applications.
Ordering Information:
MPNDescription
EKK-LM4F232EKK-LM4F232EKK-LM4F232 Evaluation Kit with Keil Tools
EKI-LM4F232EKI-LM4F232EKI-LM4F232 Evaluation Kit with IAR Tools
EKC-LM4F232EKC-LM4F232EKC-LM4F232 Evaluation Kit with CodeSourcery Tools
EKS-LM4F232EKS-LM4F232EKS-LM4F232 Evaluation Kit with Code Composer Studio
EKT-LM4F232EKT-LM4F232EKT-LM4F232 Evaluation Kit with Code Red Tools
Key Applications: Low power, hand-held smart devices, Gaming equipment, Home and commercial site monitoring and control, Motion control, Medical instrumentation, Test and measurement equipment, Factory automation, Fire and security, Smart Energy/Smart Grid solutions, Intelligent lighting control, Transportation
imageTexas Instruments Development KitsimageTexas Instruments Development Tools
Development Tools
Software Development Tools:
Tool   TypeSupplierMPNSupported   FamilyDescription
IDETexas InstrumentsCode Composer Studio (CCStudio)TI ARM MCUsCCStudio is an integrated development environment (IDE) for TI embedded   processor families. CCStudio comprises a suite of tools used to develop and debug embedded applications. It includes   compilers for each of TI's device families, source code editor, project build environment, debugger, profiler, simulators,   real-time operating system and many other features. Learn More
IDEARMKeil MDK-ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9TmThe MDK-ARM is a complete software development environment for CortexTm-M, Cortex-R4, ARM7Tm and ARM9Tm   processor-based devices. MDK-ARM is specifically designed for microcontroller applications, it is easy to learn and use, yet   powerful enough for the most demanding embedded applications. Learn More
RTOSMicriumµC/OS-IIITI ARM MCUsμC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs. Learn More
RTOSSegger
embOS
TI ARM MCUs
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications. Learn More
Hardware Development Tools:
Emulator / Debugger / ProgrammerARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideTexas Instruments: User Manual for EK-LM4F232 Stellaris LM4F232 USB+CAN Evaluation Kit
User GuideTexas Instruments: Quick Start Guide for CodeSourcery Tools (Rev. E)
User GuideTexas Instruments: Quick Start Guide for Stellaris Development and Evaluation Kits for IAR Tools (Rev. D)
User GuideTexas Instruments: Quick Start Guide for Stellaris Development and Evaluation Kits for Keil Tools (Rev. C)
User GuideTexas Instruments: Quick Start Guide for Stellaris Development and Evaluation Kits for Code Composer Studio (Rev. B)
Product BriefTexas Instruments: Product Brief for EK-LM4F232 Stellaris LM4F232 USB+CAN Evaluation Kit
Datasheet
Texas Instruments: Datasheet for Tiva C Series TM4C123GH6PGE Microcontroller (Rev. B)
Selection GuideTexas Instruments: Selection Guide for Tiva C Series ARM Microcontrollers (Rev. A)
Design Elements
TypeDescription
Design TechniquesTexas Instruments: Stellaris LM4F232H5QD Microcontroller Pin List
Simulation ModelTexas Instruments: BSDL Model for TM4C123GH6PG (144-LQFP)
Back to top
Video
Back to top
Kit Features
  • Tiva C Series TM4C123GH6PGETM4C123GH6PGE with 256KB internal Flash
  • 96×64 color OLED display providing useful output and interface options
  • USB Micro-AB for prototyping USB application
  • microSD card slot for data storage
  • 5 user/navigation switches
  • 5-mm screw terminals for attaching external sensors and other analog inputs
  • Precision 3.0-V reference for accurate analog-to-digital conversion
  • Temperature sensor for temperature monitoring
  • 3-axis accelerometer for position sensing
  • All I/O brought out to headers for easy prototyping
  • Five user/navigation buttons (including select/wake) for user input
  • One user LED
  • Debug
    • StellarisRegistered In-Circuit Debug Interface (ICDI)
    • Standard 10-pin JTAG header
  • Shunt resistors to measure current on VBAT and VDD
  • Coin cell backup battery for Hibernate mode
  • Reset button
  • Data logger demo application
    • 6 screw terminals
      • 4 analog inputs (0-20 V)
      • Power
      • Ground
    • 3-axis analog accelerometer
    • 2 Analog temperature sensors
      • External TMP20 temperature sensor
      • Internal microcontroller temperature sensor
    • Microcontroller current shunt amplifier
Back to top
Kit Contents
The Texas Instruments EK-LM4F232EK-LM4F232 USB+CAN Evaluation Kit supplied with below contents:
  • Stellaris EK-LM4F232EK-LM4F232 evaluation board
  • On-board StellarisRegistered In-Circuit Debug Interface (ICDI)
  • Cables
    • USB Mini-B to USB-A plug cable (for debug)
    • USB Micro-A plug to USB-A receptacle cable
    • USB Micro-B plug to USB-A plug cable
  • USB Flash drive
  • 3 V CR2032CR2032 lithium coin cell battery
  • CD containing:
    • StellarisWareRegistered Peripheral Driver Library and example source code
    • StellarisRegistered Firmware Development Package with example source code
    • Quickstart application with source code
      • Windows companion application for quickstart application
    • Complete documentation
    • A supported version of one of the following:
      • KeilTm RealViewRegistered Microcontroller Development Kit (MDK-ARMMDK-ARM)
      • IAR Embedded WorkbenchRegistered development tools
      • Sourcery CodeBench development tools
      • Code Red Technologies development tools
      • Texas Instruments’ Code Composer StudioTm IDE
Back to top
  • tm4c123gh6pge
  • eks-lm4f232
  • eki-lm4f232
  • Cortex-M
  • usb+can
  • texas_instruments
  • ekt-lm4f232
  • ekk-lm4f232
  • lm4f232
  • arm
  • ekc-lm4f232
