Technical Library
  • Technical Library
Technical Library
Documents Texas Instruments: EK-LM3S8962-LM3S8962 Ethernet+CAN Evaluation Kits
  • Author Author: sangeetack
  • Date Created: 30 Nov 2011 5:24 AM Date Created
  • Last Updated Last Updated: 25 Oct 2013 10:36 AM
  • Views 2221 views
Buy Now Development ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Stellaris LM3S8962 Evaluation Board is a compact and versatile evaluation platform for the Stellaris LM3S8962 ARMRegistered CortexTm-M3-based microcontroller. The evaluation kit design highlights the LM3S8962 microcontroller's integrated CAN and 10/100 Ethernet controllers. You can use the EVB either as an evaluation platform or as a low-cost in-circuit debug interface (ICDI). In debug interface mode, the on-board microcontroller is bypassed, allowing connection of the debug signals to an external Stellaris microcontroller target. The kit is also compatible with high-performance external JTAG debuggers.
This evaluation kit enables quick evaluation, prototype development, and creation of application-specific designs for Ethernet and CAN networks. The kit also includes extensive source-code examples, allowing you to start building C code applications quickly. The kit also includes extensive source code examples, allowing you to start building C code applications quickly. Several versions of the Kit are available:
Ordering information:
MPNDescription
EKK-LM3S8962
Stellaris LM3S8962 Evaluation Kit for KeilTm RealViewRegistered MDK-ARM (32 KB code-size limited)
EKI-LM3S8962
Stellaris LM3S8962 Evaluation Kit for IAR Systems Embedded WorkbenchRegistered (32 KB code-size limited)
EKC-LM3S8962
Stellaris LM3S8962 Evaluation Kit for Sourcery CodeBench (30-day limited)
EKT-LM3S8962
Stellaris LM3S8962 Evaluation Kit for Code Red Technologies Red Suite (90-day limited)
EKS-LM3S8962
Stellaris LM3S8962 Evaluation Kit for Code Composer StudioTm IDE (board-locked)
Key Applications: Remote monitoring, Electronic point-of-sale (POS) machines, Test and measurement equipment, Network appliances and switches, Factory automation, HVAC and building control, Gaming equipment, Motion control.
imageTexas Instruments Development KitsimageTexas Instruments Development Tools
Development Tools
Software Development Tools:
IDE
EmbestCoIDEARM CortexTm-MCooCox offer freely available powerful software development tool for ARM  Cortex-M3 & Cortex-M0 based microcontrollers. Coocox Tools  organizes and provides the knowledge required by developers. Learn More
RTOSEmbestCoOSARM CortexTm-MCoOS is a free and open RTOS from CooCox, designed specifically for  Cortex-M processor, supports preemptive priority and round-robin,  Semaphore, Mutex, Flag, Mailbox and Queue for communication &  synchronization, highly scalable, minimum system kernel is only  974Bytes, supports interrupt while task switching, supports stack  overflow detection, supports the platforms of ICCARM, ARMCC, GCC. Learn More
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
IDEARM KeilMDK ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9Tm
The MDK-ARM (Microcontroller Development Kit) is the complete software development environment for ARM7, ARM9, Cortex-M, and Cortex-R4 processor-based devices.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
RTOSMicriumuC/OS IIIColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs.  Learn More
RTOSSeggerembOSColdFire / HC08 / HC12 / ARM / S08 / RS08
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications.  Learn More
Hardware Development Tools:
Tool   TypeSupplierMPNSupported   FamilyDescription
Debugger
EmbestColinkEx ARM CortexTm-MARM Cortex-M MCU JTAG Hardware Debugging Probe which supports in CooCox software and Keil Realview MDK
Emulator / Debugger / ProgrammerARMULINK2 ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKPro ARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-Link ARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARM ARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
DatasheetTexas Instruments: Datasheet for Stellaris LM3S8962 Microcontroller (Rev. F)
WhitepaperTexas Instruments: Whitepaper on Get to Work in 10 Minutes
Application NoteTexas Instruments: AN01247 - Using the Stellaris   Microcontroller Analog-to-Digital Converter
Application NoteTexas Instruments: AN01237 - Programming the On-Chip Flash   Memory in a Stellaris Microcontroller
User GuideTexas Instruments: User Guide for Stellaris LM3S8962 Evaluation Board  (Rev. B)
Product BriefTexas Instruments: Product Brief for Stellaris LM3S8962 Evaluation Kit  (Rev. B)
Design Elements
TypeDescription
BSDLTexas Instruments: BSDL Model for Stellaris LM3S8962 108BGA (Rev. A)
BSDLTexas Instruments: BSDL Model for Stellaris LM3S8962 100LQFP (Rev. A)
Simulation ModelTexas Instruments: IBIS Model for Stellaris LM3S8962 100LQFP
Simulation ModelTexas Instruments: IBIS Model for Stellaris LM3S8962 108BGA
Back to top
Video
This video is unavailable.
Back to top
Kit Features
The main evaluation board (EVB) is the CAN host. A small CAN device board, linked with a ribbon cable, uses a Stellaris LM3S2110-IQC25 microcontroller. The function of each board is fully configurable in software.
You can use the EVB either as an evaluation platform or as a low-cost in-circuit debug interface (ICDI). In debug interface mode, the on-board microcontroller is disabled, allowing connection of the debug signals to an external target. The kit is also compatible with high-performance external JTAG debuggers.
This evaluation kit enables quick evaluation, prototype development, and creation of application-specific designs for Ethernet networks. The kit also includes extensive source-code examples, allowing you to start building C code applications quickly. The evaluation kit includes the following features:
  • Stellaris LM3S8962 microcontroller with fully-integrated 10/100 embedded Ethernet controller and CAN MAC
  • Simple setup: USB cable provides serial communication, debugging, and power
  • OLED graphics display
  • User LED, navigation switches, and select pushbuttons
  • Magnetic speaker
  • MicroSD card slot
  • USB interface for debugging and power supply
  • Standard ARMRegistered 20-pin JTAG debug connector with input and output modes
  • LM3S8962 I/O available on labeled break-out pads
Back to top
Kit Contents
The evaluation kit contains everything you need to develop and run applications for Stellaris microcontrollers including:
  • Stellaris EK- LM3S8962 evaluation board
  • USB cable
  • 20-pin JTAG/SWD target cable
  • 10-pin CAN cable
  • Retracting Ethernet cable
  • CD containing:
    • Complete documentation
    • Evaluation version of the software tools
    • Quickstart guide and source code
    • StellarisWareRegistered Peripheral Driver Library and example source code
Back to top
  • lm3s8962
  • cortex-m3
  • texas_instruments
  • ek-lm3s8962-lm3s8962
  • arm
