EAGLE Support (Deutsch) Error when using UltraLib to exporting Library to Eagle 6.5.0
  • Subscribers 187 subscribers
  • Views 849 views
  • eagle
  • librarian
  • ultra
I am using eagleCAD for the first time (normally use Target 3001).
When I download libraries using Ultra Librarian 5.3.409, and export the .bxl to Eagle compatible .src and run the script to create a new library, the following error occurs:
Line 176:
Layer 93:Pins not available!
Line 449:
Line 772:
What does this mean? Should I replace layer 93 with another layer (eg 101) in script file? Please find the script file for ADS8331 attached as example.
2014-05-18_18-08-14_Library.scr.zip
    autodeskguest over 12 years ago
    On 19/05/2014 4:33 a.m., Sheheryar Qazi wrote:
    Line 176:
    Line 449:
    Line 772:
    example.
    Um alle Bilder und Anhänge in diesem Beitrag zu sehen, besuchen Sie:
    http://www.element14.com/community/message/113112
    Anhang:
    Hello
    Yes. create a user defined layer in the library and change that 93 to
    the layer number you have created. When the script runs you will see the
    information on that layer is the side view of the chip package and pins
    dimensions. Something Eagle does not bother recording.
    There is a number of other errors where it uses incorrect layers.
    I evaluated Ultra Librarian a month ago and decided the free script
    creator was rubbish. I spent a number of hours to see if I could decode
    the bxl file as being able to do that would have been a way to get
    better results for Eagle,  but had no success. The reader crashed on
    occasions and was generally unpleasant to be around. The semiconductor
    manufactures have got on board but the claim that the file format is not
    proprietary is just plain untrue. Its an Accelerated Design proprietary
    format.
    Good luck
    Warren
  • Richard_H
    Richard_H over 12 years ago
    please change the layer selection here. I did a test with layer 37 instead of 93. The packages will then contain a lot of objects that can be simply deleted after importing it into EAGLE. This seems to be a problem of the source file....
    By the way: Layer 93 is only used in schematics or in symbols but not in the layout or package editor. that's the reason why EAGLE complains.
    HTH
    Richard
