EAGLE User Chat (English) Power plane questions
  • Subscribers 179 subscribers
  • Views 596 views
EAGLE users,
Working on my first four layer board and have a few questions about the
power plane polygons.
The Vdd & DGND planes overlap each other, with one being slightly
smaller (for visibility), and are both in slightly from the board edge
to prevent shorts when panelized.
Question 1:
There are now a few rectangular areas inside those polygons where I'd
like have neither plane plated-- "voids" in those areas as it were.  How
is that done?  Not sure where that kind of editing is covered in the
manual, or where to find an example.
Question 2:
I have several through vias that tap off either Vdd or DGND to provide
power for a top or bottom trace (or both) as needed.  What I'm not
seeing are the "thermal" connect areas.  Pretty sure the connection is
being made since vias high light correctly when selected.  But given the
expense of 4 layer board, I'd like to be sure it's correct!
Thanks in advance for your help.
Just as a FYI, I've also noticed displaying/hiding the fills doesn't
seem to work (or work consistently) with such overlapping polygons.  For
now, if it does show up when not needed, exiting & restarting EAGLE
hides the  fill.  Also in working on a test area, I see the fill does
not show up unless there is a through hole part inside the area.
    On 2008/May/01 12:49 PM, in article fvcsc1$tn1$1@cheetah.cadsoft.de, "KR"
    <k.rusnok@maccor.com> wrote:
    For
    hides the  fill.
    Hello KR,
    If you want to "hide" the fill of a polygon then you need to use the ripup
    command.  This actually removes the copper pour and just leaves the outline.
    There is no way to hide just polygons (I have made this suggestion before,
    maybe in the next version).
    Further to this, there is an option to process polygons with the ratsnest.
    If you turn this off then the polygons won't be poured when you run the
    ratsnest.  Of course, they won't be connected either so the remaining
    airwires will be counted incorrectly.  But this is handy in some situations.
    Cheers,
    James.
    James Morrison
    http://www.eagletoolkit.com
    Online EAGLE Dealer for US and Canada
    EAGLE Design Expert
    EAGLE Enterprise Toolkit
    KR wrote:
    Question 1:
    like have neither plane plated-- "voids" in those areas as it were. How is
    the manual, or where to find an example.
    There was a recent question about this same topic, by someone who wanted a
    single void area in the middle of a polygon.  I suggested that two
    overlapping polygons can be used to leave a void area between them (think
    two U-shaped polygons with the legs facing and overlapping each other).
    Someone else suggested a single polygon could be drawn, although it seems to
    be tricky to do without getting DRC complaints.
    Bert Menkveld
    James,
    Thanks for your feedback.
    I understand what you are saying with ripup & ratsnest commands.  Before
    putting in the full power planes, I tried some small, non overlapping,
    test power plane polygons. Individually, the ripup & ratsnest commands
    worked correctly.  The code apparently gets confused with overlapping
    polygons.  Exiting and restarting EAGLE is the only way I found to
    remove BOTH fills.  As previously mentioned, while a little
    inconvenient, it's not a big deal, as I don't need to clear the fills
    very often.
    Right now, creating voids inside the existing polygons and not being
    able to verify the thermal connections are the greater concerns.
    Ken
    For
    hides the  fill.
    Hello KR,
    Cheers,
    James.
    Bert,
    Thanks for your comments.
    Drawing new polygons around the void area:
    That's sort of what I thought would be a good workaround.  Yes, it's
    more work and not as intuitive, but the bottom line for all of us is
    getting the layout DONE!
    Perhaps on a future release, polygons will have a "fill or void" option.
    Ken
    Bert Menkveld wrote:
    KR wrote:
    Question 1:
    Bert Menkveld
    autodeskguest over 17 years ago in reply to autodeskguest
    It is quite easy to create a void in a polygon, I do it often
    Use the SPLIT command to change the polygon outline, drive it to the
    void area you want, use it to draw the perimeter of the void, nearly
    until you close it (one grid pitch before).Then make it go back to the
    edge of the board. After that change to a smaller grid and move one edge
    of the remaining void channel so that it nearly overlaps the other, and
    it's done. Don't overlap exactly the segments, the polygon would be illegal.
    With the same method you can create any kind of void in a polygon, a
    wire-like void allows power / signal ground separation with only a small
    bridge for connection
    Christian Magne
    KR wrote:
    Bert,
    Ken
    KR wrote:
    Question 1:
    How is that done?  Not sure where that kind of editing is covered in
    wanted a single void area in the middle of a polygon.  I suggested
    that two overlapping polygons can be used to leave a void area between
    them (think two U-shaped polygons with the legs facing and overlapping
    each other). Someone else suggested a single polygon could be drawn,
    although it seems to be tricky to do without getting DRC complaints.
    Bert Menkveld
