EAGLE User Chat (English) Copper Pours - Manufacturability of PCB
  • Replies 9 replies
  • Subscribers 180 subscribers
  • Views 942 views
Hi -
I've got a PCB with a fair number of sensitive analog parts on it so I've
flooded a large area of the top layer of the board with a copper ground
plane using the Polygon feature of Eagle.  Another large section of the
board has been left without the top layer copper plane.  All is OK with this
and the PCB is about ready to manufacture.
It occurred to me that this could be problematic in the PCB manufacturing
process.  Having half the board covered with copper where the traces are
isolated by a narrow gap and then the other half with narrow traces and all
the surrounding copper removed could present problems for the etching
process.
On the other hand, removing less copper by leaving large copper pours should
be more environmentally friendly.
Do PCB manufacturers have a preference one way or the other?  (I've checked
a number of PCB vendors websites and haven't really found any information.)
Sincerely,
    John M. Jarvis wrote:
    Hi -
    process.
    This should not affect the etching process. Large copper areas in some
    areas may affect the board and make it warp when you solder it by wave
    or reflow methods. I think with proper preheating it won't be a problem.
    I fill both the top and bottom with ground and power polygons
    Filled with ground highlighted.
    http://arcelectronicsinc.com/testinfo/componentside.png
    Filled with +5 highlighted
    http://arcelectronicsinc.com/testinfo/plus5.png
    Sincerely,
    Paul R.
    Hi -
    I've flooded a large area of the top layer of the board with a copper
    ground plane using the Polygon feature of Eagle.  Another large
    section of the board has been left without the top layer copper
    plane.  All is OK with this and the PCB is about ready to manufacture.
    manufacturing process.  Having half the board covered with copper
    where the traces are isolated by a narrow gap and then the other half
    with narrow traces and all the surrounding copper removed could
    present problems for the etching process.
    should be more environmentally friendly.
    checked a number of PCB vendors websites and haven't really found any
    information.)
    Sincerely,
    Paul R.
    You can check with the PCB manufacture to see if they can add thieving
    to the areas void of copper. This could help with preventing board
    warpage and overetching of the areas with large amounts of copper.
    How did you draw these? I can't do that with EAGLE even though I've been
    using it for years.
    process.
    It's not a problem of the etching process, but more of the galvanics.
    Areas with low copper density will get a too high current density, so
    metal is disposed too quickly (one says they "burn") - looks like small
    flowers preferrably at the edges of the copper structures.
    For good manufacturabilty, you should avoid having too great differences
    in copper density on your boards. Simply add some amount of copper by
    hatched polygons where only a few traces are. Then you won't have any
    problems.
    Tilmann
    Former Member over 17 years ago
    Tilmann explained this very well.  Many manufacturers do add thieving areas
    for designs like this as well.  I will add (from a manufacturing standpoint)
    when using crosshatching be sure that it does not violate the minimum
    trace/space requirements of your fab house.
    Terri
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:g1jnqc$shr$1@cheetah.cadsoft.de...
    this
    all
    process.
    problems.
    Tilmann
    using it for years.
    Here is the unfilled view.
    http://arcelectronicsinc.com/testinfo/eca-320polygons.png
    It requires setting rank on the various polygons when they overlap.
    Paul R.
    "Terri Miller" <tmiller@sunstone.com> wrote in message
    news:g1jq62$5o7$1@cheetah.cadsoft.de...
    areas for designs like this as well.  I will add (from a manufacturing
    standpoint) when using crosshatching be sure that it does not violate the
    minimum trace/space requirements of your fab house.
    Terri
    Thank you all for the helpful information.
  • KE5FX
    KE5FX over 17 years ago
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:g1jtcr$h5p$1@cheetah.cadsoft.de...
    using it for years.
    Paul R.
    Is that the default palette in EAGLE v5?  The color choices look good.
    autodeskguest over 17 years ago in reply to KE5FX
    using it for years.
    Paul R.
    I think it is the default of 4.1x but I may have changed it. I have not
    upgraded to 5.x yet. The new features are nice but not needed/required yet.
    Paul R.
