EAGLE User Chat (English) Pads
  • Replies 13 replies
  • Subscribers 181 subscribers
  • Views 1491 views
Pads
Hi again,
Sorry for the newbie question but I'm really at my wit's end.
I would like to change the diameter of the pads to the passive components on
the already routed board image but the CHANGE command won't let me, even if
the Pads layer is active. All I get is a rude noise, even while the status
bar tells me to left-click on the component I want to change.
Also, it would make my life a lot easier if I could duplicate a section of
the board elsewhere on the same board without having to do it in the
schematic editor. Imagine 2 channels of a stereo system placed side by side
with interconnecting circuitry routed manually. This would look neater, not
to mention making trouble-shooting a lot easier on the actual physical
hardware.
Any help would be gratefully appreciated.
Martin
    On 10/18/2009 11:40 AM, martin grove wrote:
    Hi again,
    hardware.
    Martin
    Yeah, that got me too when I first started with Eagle. To change the
    pads, you have to open the library and edit the package for that part in
    the library.
    1. To figure out what library the part is in, click Info (the i button)
    and then click the part. It will tell you the Library name and the
    package name in that library.
    2. Find the Library in the Control Panel under Libraries, then
    double-click the library name (not a component or the package) to open
    the Library.
    3. Now click Library->Package from the Library's menubar. Select the
    package name you got from step 1. Now use Change->Drill or
    Change->Diameter or Change->Shape on the pads.
    4. Once done, save the library, and go back to the board window. Now
    click Library on the board's menubar, and then click update all. Viola!
    I recommend you start creating your own libraries of updated parts. This
    will prevent you from overwriting your changes when you update eagle.
    Once you have created a new lib file, you can open the lib and then copy
    parts from eagle's lib to the open one, which simplifies the whole process.
    As for the 2nd part: you can, but it's not intuitive. First, finish with
    your schematic and board. THen copy the board file, and open the copied
    file in eagle. Now do a group and cut and paste to copy the entire
    layout to another section of the board. Now manually run needed tracks
    between the two.
    Travis
    Thak you very much! Both work very well.
    I also found this:
    http://gaussmarkov.net/eagle/padsize.html
    It also works across the board.
    M
    "Travis G" <fightspammers@gmail.com> wrote in message
    news:hbgm8e$ueq$1@cheetah.cadsoft.de...
    Hi again,
    on
    if
    status
    of
    side
    not
    hardware.
    Martin
    Yeah, that got me too when I first started with Eagle. To change the pads,
    you have to open the library and edit the package for that part in the
    library.
    and then click the part. It will tell you the Library name and the package
    double-click the library name (not a component or the package) to open the
    Library.
    4. Once done, save the library, and go back to the board window. Now click
    will prevent you from overwriting your changes when you update eagle. Once
    you have created a new lib file, you can open the lib and then copy parts
    file in eagle. Now do a group and cut and paste to copy the entire layout
    to another section of the board. Now manually run needed tracks between
    the two.
    Travis
    Former Member over 16 years ago
    Cadsoft,
    The inability to easily modify pads without digging through libraries in
    this program drives me nuts! I've used several programs that are much
    shorter and easier. It's why I didn't buy the pro version.
    Please fix it!
    Rob
    "martin grove" <margrove.delete.the.obvious@gmail.com> wrote in message
    news:gvSdnTwyy-rQ90HXnZ2dnUVZ8uudnZ2d@pipex.net...
    I also found this:
    M
    Hi again,
    components on
    if
    status
    of
    side
    not
    hardware.
    Martin
    the library.
    the Library.
    process.
    the two.
    Travis
    On 10/20/2009 4:01 PM, Rob wrote:
    Cadsoft,
    Please fix it!
    Rob
    I would have to disagree. I'm actually glad you can't, because it forced
    me to learn to use the libraries... That one little thing pushed me into
    learning how to effectively utilize the libs when I was a new to PCB
    layout image    ...I did buy the Pro license...
    My 2 cents,
    Travis
    Rob schrieb:
    Cadsoft,
    Please fix it!
    Sorry, that's nonsense. Doing PCB layouts is more than sketching
    something with Paint. Please keep the whole PCB production process in
    mind, and understand that (correct) libraries serve you best for
    generating working production data.
    (BTW, that's why I only use my own self-defined libraries...)
    If you don't like it this way, feel free to use any other software.
    Tilmann
    Please fix it!
    Well, the OP does have a bit of a point. There are times when you just
    want to make the pads of this one device just 1 mil smaller, and it's
    not a production board, just a one-off prototype, etc. Having to go into
    your library, make another package variant, call it something meaningful
    so you'll remember what you did and why, go back and update the library,
    then change the package....that's a lot of effort for something that
    sounds like it should be simple.
    I don't believe it is a tool's responsibility to enforce a particular
    workflow so that customers have to do things "the right way". I believe
    a tool should allow customers to work the way they want to work.
    Andrew.
    Travis,
    What you are "learning" is how to work around limitations. . You could just
    as easily be learning how to reduce a single pad.  All programs have
    limitations and little anomolies.
    Tillman,
    It's not just painting. Other programs have the option. EWB,Orcad, etc.You
    are not changing libraries, you are simply modifying a part on a specific
    board.
    I have production runs of pro boards that I have done this on and my board
    house asked me if they could use me as a reference for people who need PCBs
    generated.
    Here's a an example when it is beneficial:
    Let's say we have a DIL16 package on a board and we want to bring a trace
    between two unused pins BUT we want the trace to be wider for current
    reasons than the original pad sizes allow for DRC. If we have the ability to
    reduce the size of just those two unused pads we can bring the trace through
    without shrinking it and can save money by not havingto go to  2oz. copper.
    It's not about using another program (I do by the way use several). It's
    about a good program (Eagle) becoming a better program. It's how a program
    gets better. And by the way, I gave this to Eagle a while ago and they said
    they would incorporate it into future programs but never did. Perhaps it is
    in the books.
    Rob
    "Andrew Sterian" <steriana@gvsu.edu> wrote in message
    news:hbn0kf$tco$1@cheetah.cadsoft.de...
    Please fix it!
    want to make the pads of this one device just 1 mil smaller, and it's not
    a production board, just a one-off prototype, etc. Having to go into your
    library, make another package variant, call it something meaningful so
    you'll remember what you did and why, go back and update the library, then
    change the package....that's a lot of effort for something that sounds
    workflow so that customers have to do things "the right way". I believe a
    Andrew.
    On 10/21/2009 9:35 AM, Rob wrote:
    Travis,
    While I will admit to what Andrew said, I otherwise disagree with your
    point of view here. Learning to edit the lib taught me, at a very early
    stage, that I needed to build my own libs and organize the parts I use
    so my workflow will be optimal. It takes me MUCH less time to generate a
    board and order parts for a production assembly run now that I have my
    own libs with my own often-used parts.
    The option to change pads in the board, I'll grant, could be useful in
    particular cases where you only need 1 or 2 pads changed, and only for
    that board. But I wouldn't want the program to allow it without warning
    users they should edit the library if it's a change they may want for
    other boards.
    So I'd agree to the change, but only if, on a per-board basis, you had
    to agree to a messagebox that told you something similar to:
    "You are about to edit a part's package. This should be done by editing
    the package in the Library, unless this is a change that is specific to
    this board layout and you will never need again. Otherwise, please
    proceed to the library editor to edit this package. Do you still want to
    edit the package?"
    Travis
    I don't see what all the fuss is about. If you can resize the pads across
    the board in the "Restring" option of  DRC, what is so sacrilegeous about
    changing just one pad?
    I think vendors should value input from their customers.
    M
    news:hbn47o$d58$1@cheetah.cadsoft.de...
    Travis,
    just
    stage, that I needed to build my own libs and organize the parts I use so
    board and order parts for a production assembly run now that I have my own
    other boards.
    So I'd agree to the change, but only if, on a per-board basis, you had to
    this board layout and you will never need again. Otherwise, please proceed
    to the library editor to edit this package. Do you still want to edit the
    package?"
    Travis
  • kcadsoft
    kcadsoft over 16 years ago
    Please, guys, let's not let this thread escalate image
    With the new envisioned datastructure of version 6 we plan
    to make it possible to overwrite pad data like shape or diameter
    on a per pad basis in the board. We are also thinking about
    implementing a way of "cutting off" edges from pads, as shown
    in the attached image (which is a fake - this feature is not yet
    implemented ;-).
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
