EAGLE User Chat (English) Disconnecting a part from nets during MOVE
  • Replies 9 replies
  • Views 2425 views
sean444
sean444 over 16 years ago
One of the things I would like to be able to do is move a part around the
schematic without the nets following the part.  Same with MIRROR.
1.  Is there a way to do this?
2.  Is there a way to change the default of always keeping a part connected
to nets?
3.  Is there a way to move a wire end that is connected to a pin so that
the connection is severed?  I don't want to delete the wire.
There have been several times I want to mirror a symetrical part so that
the pins conect to opposing wires.
Thanks for any help offered.
Sean
There are 10 kinds of people that understand binary.
    actually, I lied, I never have the forethought to do what i suggested, i
    do like Olin said: i disconnect the part, fiddle with it and reconnect
    it. i don't even bother to use his grouping method, i just delete the
    net segments and reconnect them.
    autodeskguest over 16 years ago in reply to sean444
    seank wrote on Wed, 16 December 2009 07:23
    That would defeat the true idea of disconnecting the group for the
    purpose of just moving or rotating and then reattaching.
    It may be helpful to disconnect a large part by defining a group as a
    narrow region just outside the part's pins, then delete the group.  This
    should have the effect of deleting the nets immediately connected to the
    part.  You may have to do this once for each side of the part that has
    connected pins.
    Keep in mind that groups aren't restricted to being defined by rectangles.
    You can specify a arbitrary polygon with successive left clicks, then one
    right click to close the polygon and end the group definition.
  • sean444
    sean444 over 16 years ago in reply to autodeskguest
    Thanks Gary,
    In version 5.6, which I am running, if I paste before I delete the
    reference designators get changed.  That would defeat the true idea of
    disconnecting the group for the purpose of just moving or rotating and then
    reattaching.  If I am doing a board revision, I may want to change the look
    of the schematic for my purposes, but not the look/feel of the PCB for
    production purposes.
    Appreciate the help very much.  It is nice to know that this forum actually
    works.
    Sean
    my usual way to move something is to duplicate it with copy, drop it
    where I need it, delete the original, rewire the schematic. if it's only
      a few connections, i move it and clean up the mess.
    as far as changing connections on a header, i suppose you find one
    that's backwards ( now, how many times have i done that?? image )...
    you can do the same thing if the header was defined with the pins at the
    same swap level in the library. in this case it's probably easier and
    safer to copy, delete and reconnect, and probably faster as well.
    making a header pinswappable might lead to an error some day if you're
    careless and swap something you shouldn't... but it might also be a good
    exercise to learn more about EAGLE.
    seank wrote on Tue, 15 December 2009 07:51
    Now the fun of this newbie trying to figure out how to assign this to a
    hotkey.
    That is a dangerous and rare enough operation I wouldn't want it on a hot
    key.
  • sean444
    Olin,
    While that can be done, it requires the user to go back through the
    library....which is tedious.  And depending on how many libraries you have,
    time consuming.
    I did figure a way to do it this morning.  Not too difficult to put as a
    series of commands.
    1.  GROUP what you want to cut.
    2.  CUT the group to put it in the buffer.
    3.  DELETE the group
    4.  PASTE the group
    All the reference designators will remain the same so you can do whatever
    one wants to the group without having nets move around.
    Hope this helps others.  Now the fun of this newbie trying to figure out
    how to assign this to a hotkey.  Any ideas from any guru?
    Sean
    seank wrote on Mon, 14 December 2009 23:26
    In this case, the ability to cut the part and paste it elsewhere so
    that I could rotate/mirror then reattach would be so much easier.
    If that's all you want, just delete the part and add it somewhere else.
    Deleting a part tends to break all connections to it.
  • sean444
    Thanks Gary,
    That works like a champ for the rotate and mirror.  This is a new concept
    for a 10 year veteran of Orcad.
    It does not work so well for say a 20 pin header.  In this case, the
    ability to cut the part and paste it elsewhere so that I could
    Thanks for giving me one more tool of understanding.
    I find it interesting that the CUT command does not cut but copy????
    Does anyone know of a ULP that truly will cut and paste like in windows?
    Sean
    if the pins are at the same swap level, pinswap them and then rotate or
    mirror the component. surprisingly image the passives usually have the
    pins at swap level 1 which makes this possible, but polarized passives
    also have the pins at swap level 1, so watch out !!@!
