EAGLE User Chat (English) Preferred power supply connections?
  • Replies 13 replies
  • Views 1982 views
The schematic I am "capturing" are based on public domain circuits for
audio processing modules in a modular analog synthesizer. There are some
standard power connection schemes which I intend to follow consisting of
+/- 15 Vdc and ground. Typically, the +/- supplies go through a ferrite
bead and a couple of filtering capacitors before hitting the PCB's power
nets.
What is the best way to make a power net for the PCB components bcause it
is separated from the power input jack by the ferrite bead? If I connect
the connector pins to the supply +15 and -15 nets, I can't use them on the
PCB. So, what is the best net to use to PCB components to the other side of
the ferrite beads? Should use one of the other available supply nets or
make a unique power net?
I have played with different ways to do it, and they seem to work, but as
I'm new at this capture stuff, I'd like to know if there are standard or
preferred ways to accomplish this.
This image kind of shows what I mean.
David
    i recall that Klaus said it will be coming, probably in the next v5
    release, maybe already there. i think he said it will be a eaglerc option.
    Gary Gofstein wrote on Thu, 25 February 2010 20:56
    Surprisingly nobody has mentioned EAGLE's gotcha with respect to power
    supplies. EAGLE parts have named power supply pins that automatically
    connect to the net of the same name. Furthermore, on many parts these
    pins are hidden until you use the INVOKE command to bring them into the
    schematic.
    It becomes a problem when you try to use an opamp with say pin 4
    defined
    as -15V in the part. Add this part into your schematic and that
    (invisible) pin is automatically connect to the net named -15V. If your
    -15V net is called VEE or VSS, no connection. Guess what happens when
    one part has a pin named VCC and another part has a pin named +15V and
    you need to connect both to the same +12V power supply rail...
    Good point Gary.  That certainly is part of the discussion.
    Quote:
    I don't like these implicit nets at all and I do not use them, but they
    are found all the time in the EAGLE library parts. I believe the newer
    versions of EAGLE may have an option to disable this behavior. ( I
    still
    use v4 ).
    Do you have any more info for turning this off?  I'd love to do that as it
    always scares me even with my own libraries.  My rule of thumb is if you
    can't tell exactly how the circuit should be connected from a printed
    schematic then your schematic is incomplete.
    I took a brief look and couldn't find how to turn this "feature" off.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Yes, this is a nasty hidden gotcha.  I do what Gary does, which is never to
    use implicit power connections, at least not on purpose.  Unfortunately
    they can still bite you if you forget a connection.  It also helps to never
    use the Eagle supplied libraries.
    Gary Gofstein wrote on Thu, 25 February 2010 18:56
    schematic.
    defined
    still
    use v4 ). Look in the EAGLE help for SUPPLY and POWER directions for
    pins to understand this a little better.
    I do use power supply symbols and I also frequently label the nets like
    Olin does. I document all power supply connections in the schematic
    along with their bypass caps, and never use the implicit ones.
    Excellent point. I hadn't given that much thought.
    David
    schematic.
    It becomes a problem when you try to use an opamp with say pin 4 defined
    versions of EAGLE may have an option to disable this behavior. ( I still
    Olin wrote on Thu, 25 February 2010 12:49
    dingebre wrote on Thu, 25 February 2010 11:42
    Hi Olin, you're reading too much into the "design". This is not a
    real schematic.
    I'm only illustrating the power connections.
    It is still a good idea to keep in mind that neatness counts,
    especially when you are presenting to others.  Some may look past that,
    but why allow it to be a issue when it would only have taken a extra
    minute to make things more readable?
    Quote:
    I only ask a little patience. I'm very new to using Eagle and want
    to learn good habits. Would you maybe take a second look? I'd like some
    advice about how to handle the power nets on the "real" circuits I'd
    like to work on.
    I don't use specific parts at all to label power nets.  I don't treat
    power nets any different from other nets that are drawn in separate
    pieces, although I've seen others use explicit power symbols commonly.
    In Eagle, nets in the schematic are automatically connected if they have
    the same name.  To show airwires in a Eagle schematic, I name the nets
    and then use DRAW LABEL to show the net name in the schematic.  It's
    important to use DRAW LABEL instead of TEXT because DRAW LABEL shows the
    true net name as Eagle understands it.  If you change the net name, the
    text drawn with DRAW LABEL will automatically change.
    For power nets I use names like "5V", "-12V", "BATT", or whatever I
    think will be most descriptive in context of that schematic.  I also like
    to show power connections on top, ground on the bottom, with signal from
    left to right to the extent this can be reasonably done.  Keep in mind
    that the schematic is not only to define the machine readable connections
    to Eagle, but it is also the primary documentation of your circuit to
    humans.  As such, neatness and clarity are very important
    considerations.
    Quote:
    Should I do it kind of like in that illustration? Use the supply
    library  +/- 15 for the plug and then a generic supply symbol to
    connect the +/- supplies on the components? Or is there a better way?
    You'll probably find as many opinions as people.  There are several
    reasonably "right" ways.  I've tried to explain what I do, but I
    recognize there are other ways that others prefer.  As long as Eagle
    understands the connections, there aren't hidden gotchas for making
    changes, and your circuit is easy to understand from the schematic, then
    it's a acceptable method.
    You can take a look at
    http://www.embedinc.com/products/usbprog/eusb3.pdf as a example of how I
    do things.  The first page is the main power supply.  Note all the named
    wires ending at the right side because the logical flow is out from the
    power supply.  You can see various other places in the schematic that
    connect to these power rails, usually coming in from the top or left as a
    simple visual reference that the power is coming in instead of being
    produced there.  Note that no explicit power symbols were used, just
    named nets with carefully placed labels.
    Thanks Olin! I am used to a different commercial application which makes
    things like this so difficult. Right now, the hardest part of my learning
    curve is accepting how much simpler and more logical Eagle is compared to
    what I have been using. I keep expecting Eagle to be much more cryptic...
    Thanks for taking the time to share your thoughts. They are really helping
    me get in the "Eagle" mindset. Next time I put up project, I'll clean it
    up.
    David
    autodeskguest over 16 years ago in reply to e14 Contributor
    Hi Olin, you're reading too much into the "design". This is not a real
    schematic.
    It is still a good idea to keep in mind that neatness counts, especially
    when you are presenting to others.  Some may look past that, but why allow
    it to be a issue when it would only have taken a extra minute to make
    Quote:
    I only ask a little patience. I'm very new to using Eagle and want to
    advice about how to handle the power nets on the "real" circuits I'd like
    to work on.
    I don't use specific parts at all to label power nets.  I don't treat power
    nets any different from other nets that are drawn in separate pieces,
    although I've seen others use explicit power symbols commonly.  In Eagle,
    nets in the schematic are automatically connected if they have the same
    name.  To show airwires in a Eagle schematic, I name the nets and then use
    DRAW LABEL to show the net name in the schematic.  It's important to use
    DRAW LABEL instead of TEXT because DRAW LABEL shows the true net name as
    Eagle understands it.  If you change the net name, the text drawn with DRAW
    For power nets I use names like "5V", "-12V", "BATT", or whatever I think
    will be most descriptive in context of that schematic.  I also like to show
    power connections on top, ground on the bottom, with signal from left to
    right to the extent this can be reasonably done.  Keep in mind that the
    schematic is not only to define the machine readable connections to Eagle,
    but it is also the primary documentation of your circuit to humans.  As
    such, neatness and clarity are very important considerations.
    library  +/- 15 for the plug and then a generic supply symbol to connect
    reasonably "right" ways.  I've tried to explain what I do, but I recognize
    there are other ways that others prefer.  As long as Eagle understands the
    connections, there aren't hidden gotchas for making changes, and your
    circuit is easy to understand from the schematic, then it's a acceptable
    method.
    You can take a look at http://www.embedinc.com/products/usbprog/eusb3.pdf
    as a example of how I do things.  The first page is the main power supply.
    Note all the named wires ending at the right side because the logical flow
    is out from the power supply.  You can see various other places in the
    schematic that connect to these power rails, usually coming in from the top
    or left as a simple visual reference that the power is coming in instead of
    being produced there.  Note that no explicit power symbols were used, just
    e14 Contributor over 16 years ago in reply to autodeskguest
    James Morrison wrote on Thu, 25 February 2010 09:52
    dingebre wrote on Wed, 24 February 2010 21:57
    for audio processing modules in a modular analog synthesizer. There are
    some standard power connection schemes which I intend to follow
    consisting of +/- 15 Vdc and ground. Typically, the +/- supplies go
    through a ferrite bead and a couple of filtering capacitors before
    hitting the PCB's power nets.
    bcause it is separated from the power input jack by the ferrite bead?
    If I connect the connector pins to the supply +15 and -15 nets, I can't
    use them on the PCB. So, what is the best net to use to PCB components
    to the other side of the ferrite beads? Should use one of the other
    available supply nets or make a unique power net?
    but as I'm new at this capture stuff, I'd like to know if there are
    standard or preferred ways to accomplish this.
    Hi David,
    There are a few ways to do it.  First, every signal name in EAGLE is
    global.  So if you simply name a net to a signal name it will be
    connected to any other net with the same name whether it looks like it or
    not.  So watch yourself there.
    So you have a pin connected to a ferrite that goes to a plane then you
    can do a few things:
    1)  name (and label) the net between the pin and the ferrite.  That can
    be helpful.
    2)  create a custom supply symbol that indicates  it's function.  This
    can work too and can help with readability if that net goes somewhere
    else (like a raw power bus).
    My rule is that I should be able to tell 100% what is happening in the
    schematic when I print it out.  If you have to use EAGLE itself (by using
    the info command for instance) to figure out what is going on then the
    I also have a preference for labels over spaghetti nets that are hard
    to follow when printed out.  Hope that helps.
    Cheers,
    James.
    Yes, it helps a lot. Thanks James. In the software I have been using
    (competing commercial application), it was a real chore to do this kind of
    connection and I was a litte nervous as it seems so easy to do in Eagle image
    I wanted to make sure I wasn't missing something.
    David
    nets.
    it is separated from the power input jack by the ferrite bead? If I
    connect the connector pins to the supply +15 and -15 nets, I can't use
    them on the PCB. So, what is the best net to use to PCB components to the
    other side of the ferrite beads? Should use one of the other available
    as I'm new at this capture stuff, I'd like to know if there are standard
    Hi David,
    global.  So if you simply name a net to a signal name it will be connected
    to any other net with the same name whether it looks like it or not.  So
    So you have a pin connected to a ferrite that goes to a plane then you can
    do a few things:
    1)  name (and label) the net between the pin and the ferrite.  That can be
    helpful.
    2)  create a custom supply symbol that indicates  it's function.  This can
    work too and can help with readability if that net goes somewhere else
    I also have a preference for labels over spaghetti nets that are hard to
    Cheers,
    James.
    Terri Miller wrote on Thu, 25 February 2010 09:48
    "Olin Lathrop" <eagle@embedinc.com[/email]> wrote in message
    news:hm60oi$830$1@cheetah.cadsoft.de...[/email]
    No, it shows a mess.  There is rotated text all over the place,
    labels
    overlapping other labels and parts, and missing values.  If you
    don't care
    about your design, there is no reason I should either.
    Olin,
    This kind of response is completely inappropriate.  If you don't care
    then
    don't bother responding.  Why even waste your time?
    Unbelievable.
    I agree Terry.  I've sent a PM to Olin about this.  You're not the only one
    to complain.
    James.
