EAGLE User Chat (English) Eagle v8 licensing...
  • Replies 415 replies
  • Subscribers 218 subscribers
  • Views 29817 views
  • eagle
  • license
  • freeware
  • 8.0
technolomaniac
technolomaniac over 8 years ago
Hi All --
Moving this to a separate thread so it doesn't get lost in the ether.  Here's my two cents on licensing and I'd love your feedback:
Firstly, the Autodesk licensing model is subscription and the EAGLE paid license will require that you install the SW and then generate an account to retrieve your license entitlement.  Once you have this, you are good to go and the SW will run as expected.  If you lose your network connection, the SW has a 14-day heartbeat that will enable you to work offline for 14 days.  I know that some folks would prefer to never have to connect, but this is required to support a monthly subscription model that can be selectively enabled and disabled when you use the SW (so you only pay when you use it).  The total cost of ownership for those folks using it less than a few weeks a year will thus be substantially lower and still enables you to access the full software for less money.  <Insert revolt here>  image
WRT to "what happens if autodesk decides to one day just shut off the license server?" ...ok, sure, that's possible, but so is a reality TV star becoming President of the..cough...nevermind, bad example.
Point is, that's a pretty remote possibility (think: time travel and alien invasions) and it wouldn't benefit us *at all* to upset the users we just spent real money hoping to bring into autodesk and earn their business.  As the guy with both development and P&L for the product, I can tell you that it's counterintuitive and wouldn't benefit us at all.  We know this.  We make SW used by governments, movie studios, game developers, MEs, Civil Engineers, machinists, etc. and you can bet that shutting down a license server is not to our benefit in any of these categories.  To demonstrate this behavior in one category, without a path for user SW and data, calls into question ALL of our tools' viability under this model.  Not helpful.
Now...a question was raised about "but what if I drop my subscription and I want my data".  Awesome, the data is yours and lives on your machine.  And for SW that stores data in the cloud (we have some of these) we always provide a path to your data.  If this again fails with one product, it puts all of the others up for discussion.  Again, not helpful.  (Read:  strategy = doomed).
"So what about needing an entitlement for the freeware to open the data I created in another version (a *paid* version) and reading it?  What if I want access and I dont want the 14-day time out?"
So here's the deal...We can do better here.  So we will.  Here's my commitment to the group here for freeware that ensures you always have a license that you can fall back on without need of internet connection *except when you first install it* (which after all, you would have had to get it in the first place):  in version 8.1 or 8.0.1 or whathaveyou (let's call it 'a future release'), if you install the SW and authenticate once, we'll remove the timer req.  So what I'm saying another way is, the freeware will require you to login the first time to get your license, but if you log out beyond that, you're good.  You got your entitlement and you can use it freely without connection.
Caveat:  to install an update, you will need to login.  The update server (which issues the new version...e.g. 8.1 or 8.2. or 8.0.1, etc.) requires that you login and get the update, but beyond that, logout.  Thus if you want to go off-grid in a mountain cabin somewhere, get your license at Starbucks (blagh! I understand they have 'free' wifi, but no frappucinos!  ...that stuff is bad for you) then get your license and go on your merry way up to the snow drenched peaks.  When you hear from the other mountaineers or your local yodeler that a new version of EAGLE is available...download, login, get your license, get your 'decaf double-pump vanilla non-fat latte macchiato' and head back up the slopes.
Point being, we can do the freeware better.  So we will.
Hope this is clear.  Let us know if you have questions!
Best regards,
Matt Berggren
Director - Autodesk
@technolomaniac
hackaday.io/matt
  • COMPACT
    COMPACT over 8 years ago in reply to autodeskguest +4
    Not to worry, it's back to the Drawing board for me.
    shabaz over 8 years ago +3
    Hi Matt, When will the EAGLE Maker version (or another solution for hobbiests) be v8-ready? I see the subscription for 'EAGLE Standard' and 'EAGLE Premium' are now available on the website, but not EAGLE…
  • albertovignati
    albertovignati over 8 years ago in reply to techsupport +3
    Il 21/02/2017 22:54, Ed Robledo ha scritto: The customers are the sole driving force to the improvements to EAGLE. Some of these 'wants' take time to be done right, that's the reason they were not done…
  • rachaelp
    rachaelp over 8 years ago in reply to Joop14
    Joop_ wrote on Mon, 20 February 2017 11:50
    rachaelp wrote on Mon, 20 February 2017 09:01
    I don't see EAGLE v8 really falls into this category though as you
    don't store your data in the cloud and it's always readable even with a
    v8 freeware license it's just not editable. Combine this with being
    able to export to v7 (if the file format actually changes as currently
    they are the same) and I don't see there being a huge risk of losing
    access to my data.
    Makes no difference. Your locally stored data is completely useless
    (from a business point of view) when you can't edit or modify an 8 layer
    board.
    But you will be able to, in a perpetual licensed v7 version. Currently v8
    files open fine in v7 and they're going to implement an exporter to v7 so
    if this ceases to be the case the freeware version will be able to open it
    and allow export to v7. Assuming (yep I can see the million replies to this
    already) they give the v7 license entitlement for v8 subscriptions as
    indicated by Matt in another post then this shouldn't cause any issues.
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    autodeskguest over 8 years ago in reply to rachaelp
    On 20.02.2017 13:00, Rachael wrote:
    Currently v8
    This will break as soon as they implement any new objects or properties
    in a later version. Anything that V7 doesn't know of, it can't handle.
    Klaus
  • rachaelp
    rachaelp over 8 years ago in reply to autodeskguest
    Klaus Schmidinger wrote on Mon, 20 February 2017 12:40
    Currently v8
    to v7 so
    open it
    properties
    Klaus
    Yes agreed it would likely break v7 if trying to open a v8 file with new
    objects, but this is mitigated by the export to v7 option they have said
    they will provide.
    Maybe instead they could release a v7.8 with an enhanced import feature
    which could download v8 file personalities so that it can always open up a
    v8 file directly rather than relying on an export?
    I don't know, I'm not giving up on EAGLE as for me the new issues with
    licensing can be worked around such that the potential implications aren't
    more severe than having to throw away years of experience, libraries,
    utilities etc. Others clearly have a differing view but I think switching
    to something else is more risk than any perceived future risk with the
    licensing issue, it is for me at least for now.
    Best Regards,
    Rachael
  • geralds
    geralds over 8 years ago in reply to rachaelp
    Hi Rachael,
    sorry, no, absolutely no.
    I d not like go back if i have reached the top quality. That's negative logical.
    rachaelp wrote:
    Hi Gerald,
    Gerald Schwarz wrote:
    The problem is that after expiring the license period the license quality will falling back to the free version.
    Yes this will happen with the v8 version when the license expires but you can always go back to v6/v7.
    One question: are you an employee in AutoDesk because you argument this? Because i have read this so... "three times" also in other forums.
    I cannot go backwards. Minimum that the "file backwards compatibility" not really works. I don't believe that, absolutely not.
    Sorry for this question. image
    V7 would not have the functions that then V8 will have. Also software functions will be not compatible.
    And most important, i pay for the V8 and then?... Sorry, with this argument I fall a little bit into angry. Paying double, tripple..??? sorry, grrrrrr......
    Matt Berggren wrote:
    10). We'll look to build an exporter to the legacy version 6 format and ensure, for the first time, backwards compatibility.
    I know it's not as good as the option to have a perpetual v8 license but I don't think they are going to change their minds on this and for me being able to fall back to v7 is workable.
    Best Regards,
    Gerald
  • rachaelp
    rachaelp over 8 years ago in reply to geralds
    Hi Gerald,
    No. I am NOT an Autodesk employee, just an EAGLE user like you. I'm not 100% happy with the subscription model but I can live with it and I have no real choice anyway. For me I don't think it costs any more and I can mitigate the issues of not being able to edit designs if I were to go to v8 and then end my subscription as it should be possible fall back to v7 and make any edits there. Yes you wouldn't have the latest router but you'd still have all the capabilities of v7 so for most changes this would be just fine. If you aren't happy with the v8 licensing model then just stick with v7, it is perpetual and quite a capable tool and sticking with it is far easier than migrating to something else if it is currently working ok for you. There are still people working happily on v4/v5 licenses after all!
    As I have said in may other threads, whilst this licensing change with no perpetual option isn't ideal, for me it's less of an issue than throwing out everything I currently have and starting again from scratch with a new toolset and creating new libraries, methods of working etc.... etc.... etc.... I'm willing to wait an see what happens. Hopefully they may give more concessions on the licensing (maybe this is just wishful thinking?), lets see what the new router brings and what other features are coming and judge how things are in 6-12 months time when we've had a chance to see how EAGLE develops. This is my view anyway. I may be being overly optimistic that things will turn out alright in the end but I'm prepared to wait and see.
    Best Regards,
    Rachael
    Jan Cumps over 8 years ago in reply to rachaelp
    And that 'll be very likely what most professional licencees will do. Any retraining/retooling is more expensive (be it hours or money) than the license hit.
    Hi Rachel,
    you're paying your fee right now in the hope, that there's something
    worth it in 6..12 month. What if not?
    Yes, I too created a ton of parts in the past 20 years. This is why I'm
    still using EAGLE, and my license is still valid. However, I'm not going
    to ride that dead horse until the universe collapses. Also, I can't see
    why re-creating libraries is such a big problem. Yes, it definitely
    causes a lot additional work. But you're creating the parts as you need
    them, as you did in the past, one after each other and not all at once.
    Then, you don't have to create all the parts a second time. Or do you
    still use parts added, say, 15 years ago in new designs?
    Fortunately, we have all the time we need to evaluate and familiarize in
    different packages.
    Rene
  • rachaelp
    rk wrote on Mon, 20 February 2017 14:11
    Hi Rachel,
    Nope, I'm not upgrading to v8 until I have seen the stability issues that
    they introduced completely fixed and I have evaluated the new router (in
    the freeware version) to ensure it works well. Until then I have my v7 Pro
    license which I am happy with.
    I'm
    going
    No, neither am I, if we don't get the stability back and we don't start to
    see really impressive new features then I will be disappointed and will
    re-evaluate my design tools at this point. But I am happy with v7 for now
    and could carry on for quite a while with that if needed so I am going to
    wait and see.
    Also, I can't see why re-creating libraries is such a big problem. Yes,
    it definitely
    need
    once.
    you
    It's rare to use a part from 15 years ago but occasionally it's needed if
    you have to go back to something legacy. Creating parts is always a lot
    quicker when you have an existing parts library to base things upon.
    There's much more chance you already have the footprint available and often
    there will be a similar part to adapt your symbol(s) for a new part from
    and if you are reusing proven library data then less chance of errors being
    introduced.
    Starting completely from scratch is definitely a lot more work and
    factoring in how much an hour of your time costs to your company then
    recreating libraries, tools, processes, etc from scratch can add up quickly
    and dwarf the cost of buying a different toolset.
    in
    different packages.
    Rene
    Agreed, there's time to see how things pan out. I'm optimistic things will
    work out ok in the end image
    Best Regards,
    Rachael
    they will provide.
    The XML file structure of V7 represents everything that the V7 executable
    can handle. Once a later version introduces new stuff in the XML data,
    there is no way V7 could possibly understand and handle that - not even if
    they provide an "export to V7 option". There would always be something
    missing or misinterpreted. Unless, of course, there's some sort of wizardry
    involved... ;-).
    Klaus
  • rachaelp
    Klaus Schmidinger wrote on Mon, 20 February 2017 14:49
    with new
    have said
    they will provide.
    executable
    if
    wizardry
    involved... ;).
    Klaus
    Clearly any export to v7 would have to omit or recreate in a compatible way
    anything that v7 wouldn't natively understand.... image
    I think the idea being that v7 contains all the features necessary to
    accurately render a board. Any new objects in the v8 file would be likely
    related to the new features required for designing the PCB but not for
    rendering it in a form which can then be subsequently edited by v7.
    Best Regards,
    Rachael
