    • Avnet Boards Community
EAGLE User Support (English) Testpoints for ICT testers
  • Replies 26 replies
  • Subscribers 173 subscribers
  • Views 3405 views
Is there a way to systematically insert ICT testpoints onto a PCB layout
without putting a testpoint component on each net on my schematic?
Ideally I'd like to know the percent of nets covered by testpoints and
have someway to highlight or locate nets without a testpoint so I can
either add one or can decide that the particular net isn't worth the
trouble to test.
-Michael
    Former Member over 14 years ago in reply to Former Member
    Warren Brayshaw schrieb:
    There have been a lot of discussion on  the placement of pads and the
    validity of testing regimes but very little on the second part of the
    question.
    As I understand it, most of the points contacted during testing are regular
    pads.
    To my knowledge, this is not true. Especially in high volume ICT,
    testpoints always are separate SMD pads. This makes sure that these
    areas are always free for the test needles and have a clean, smooth
    surface. When using pads as test points, it is very difficult to get
    reproducible contact - and the needles wear out much faster due to
    horizontal forces.
    So, how do you analyse the layout to determine if nets have  test points or
    pads acting as testpoints or nothing suitable?
    If there were special ICTP objects (as suggested), it would be no
    problem to generate a list of covered and uncovered signals, including
    statistics, with a small ULP.
    Tilmann
    On 12/30/2010 8:08 AM, Olin Lathrop wrote:
    Wow, that was a amazing bit of sideways logic. I was reacting to your
    rediculous assertion that you always need to give a tester access to all
    nets. It only takes a single counter example to disprove that, and I
    supplied several such counter examples.
    Your response is to act as if I said you are always limited to doing things
    as in the counter examples, which is completely illogical.
    Of course there are many methods to test a board. The point is that you
    don't always need to have access to every net, not that you should never
    have access to any net.
    Sorry, been traveling for some time, back in the office now.
    If I used sideways logic then you are just as guilty of it.  I gave you
    several counter examples where your methodology would not work and
    several points on how your way can in some cases cause you to spend
    recurring costs on the BOM, yet you choose to ignore those as well.  So,
    perhaps we are both guilty of sideways logic.
    I have never claimed that I want access to every net on a board in all
    cases.  Sometimes I might (particularly if it's a board with no
    microcontroller or reprogrammable logic, which I certainly admit is
    rather rare).  In fact, in general I want to use a combination of
    methodologies to do automated testing of boards.  Ideally, I'd use JTAG,
    ICT test points, and yes your method as well where appropriate
    (meaning where possible and where it does not incur recurring BOM cost).
      A mix of methods will give me the most thorough and cost effective
    means to test a populated board.
    In summary I still propose that CadSoft should consider a means to add
    test points during layout without adding them explicitly to the
    schematic, (much like the way we add vias).  This is supported in many
    of the major CAD systems that Eagle competes with and follows the
    methodology and division of labor used by many enterprises.
    >> question.
    >> pads.
    horizontal forces.
    Tilmann
    You can use regular SMT pads, but in general you shouldn't use vias (or
    at least the contract manufactures I use will not use them).
    Tilmann is right, in general you want to use a dedicated test pad that
    is separate from both your vias and your SMT pads.  The reasons are as
    follows:
    1.) CMs have problems with the ICT test probes sticking in the holes of
    vias.  In some cases this will result in the board getting hung up on
    the ICT test fixture when the fixture tries to open.  In my experience
    very few CMs will want to try this for this reason.
    2.) Some CMs will let you use SMT pads but they don't like it since they
    don't know the height of the solder "bump" precisely so they have some
    issues setting the ICT pin height.  They really don't like building a
    fixture that has a mix of dedicated ICT pads (which are unsoldered) and
    SMT pads with solder (or at least in my experience).  However, if your
    board is such that you can get good coverage from just the SMT pads this
    is an option.
    3.) Complicating point 2 is the fact that in general you want your ICT
    fixture probes to only interface with one side of the board (this is a
    cost and complexity issue, you can test on both sides if you're
    motivated).  If you've got a board with components on one side only,
    generally you're going to find that you want the ICT test points on the
    side opposite the components.  This also tends to take testing against
    your topside SMT pads off the table.  For a design with components on
    the top side only, you'll tend to be driven to putting all your ICT pads
    on the bottom side.
    -Michael
    Warren,
    Thanks for your suggestion.  It has proven to be the most workable near
    term solution for placing ICT test points on schematics.  I built a
    schematic symbol much like you suggested.  I used the point type symbol
    pin, I assumed that you did the same. Putting it on a separate layer
    really makes it workable.  The only (small) fly in the ointment is the
    connection dot that Eagle places when you drop the symbol on a net.  As
    you pointed out, it's completely invisible if you drop it on existing
    connection dots and turn the test point layer off.  I suppose that Eagle
    is generating a short (or even null) wire segment and joining it to the
    wire you dropped it on and generating the connection dot in the process.
      Do you know of any way to modify this behavior of Eagle while still
    getting the net connection to the test point?
    Thanks again for the suggestion.
    -Michael
    "Michael Sansom"  wrote
    Warren,
    -Michael
    Hi Michael
    Sounds as if you are doing it the way I suggested and don't have any ideas
    to refine it any further. Since my initial response I have determined that
    circles around the junction dots work best,in my opinion, (see attached).
    You need to get the width of  the circle wire to something you like.
    Regards
    Warren
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#``P)"0L)" P+"@L.#0P/$Q\4$Q$1
    M$R8;'1<?2@PRPH+"LR.$@],C5$-BLL/E4_1$I,4%%0,#Q87E=.7DA/4$W_
    MVP!#`0T.#A,0$R44%"5-,RPS34U-34U-34U-34U-34U-34U-34U-34U-34U-
    M34U-34U-34U-34U-34U-34U-34U-34W_P `1" #H`(H#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1 ``@$#`P($`P4%
    M! 0```%]`0(#``01!1(A,4$&$U%A!R)Q%#!D:$((TQP152T? D,V)R@@D*
    M%A7J#A(6&AXB)BI3E)66EYB9FJCI6FIZBIJKSM6VM[BYNL#Q,7&
    MQ\C)RM+3U-76U]C9VN'BX3EYN?HZ>KQ\O/T]?;W/GZ_\0`'P$``P$!`0$!
    M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"! 0#! <%! 0``0)W``$"
    M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O 58G+1"A8D-.$E\1<8&1HF
    M)R@IC4V-S@Y.D-$149'2$E4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`# ,!``(1`Q$`/P#U6J&H?\?F
    ME?\`7RW_`)DJ_5#4/\`C\TK_KY;_P!$R5,MB9;%^BBBJ"BBB@`HHHH`***
    M* "BBHR9K>RN)D`1QLX!Z9`S0!/14$\S12VR*!B60HV?38QX_$"H[>ZDGN
    MIHVCV1JB.F?O$$L,D=ON].OKZ `MT444`%%%% !5#4//S2OOEO_1,E'DZK
    M_P`_ME_X"/\`_'*XKQ59>(9-7ME\UYXY&7[/]G!1%B45#:K,EI`MTZO<"-1(R]&;')'3O4U:FZ"BBB@ HHIJLKHKHP
    M96&00<@B@!U%-#Q8P)4X8`]#C//X$4Z@`J&ZA^TVLT&[;YJ,F[&<9&,UR]
    MMJGB?5G4?[.72%M[6[DMA]H$H8[3UX..A%6O^*T_P"H!_Y&J>8V=)K=HV/
    MN9YX&GCAC6)RXV2%R3M*XY48^]G/M3(TO1>O,\-N%=$0@3,2`"QS]SG[W3VK
    MXK3J ?1J/T_P"H!_Y&HYA>S\T=)17-_P#%:?\`4 \C4?\5IU`/\`
    MR-1S![/S1TE%S\T=)5#4//S2OOEO
    M_1,E']CVW_/6]_\``V;_`.JE?:5;K=Z:!)=X:X(.;R4_P#*0\?-QT[?UI2
    MO8YI.5MC<HJA_8]M_P`];W_P-F_^+H_L>V_YZWO_`(&S?_%T]2KR[$.M:TFC
    MQ1_N_-EDR0"=JHQN9FP< 9'8DD@`$FJ6C>X-6N4B")LE'[J6%V=2V"Q5MR
    M5.T9&1@X/.016;XG\+><S7-LM[,DD!AF"7#22(%8.KK,"W0@KN[@@$BJGA
    MKP8;*ZB(FNS9Q8<S.TD#2L%9`%CW90#<Q)/7@ 8R3>O;3^OZV+][LK6WO_7Y
    M?\#NM4>UD67?Y;##!%$@]1@ GGIQ^E9J2S'2+6&$31,B(DS- ^5&WG`X)Y
    M`&5Z9SQUJ:;2K-(BTLU\JC'2GSUX P2<]N]5)+2P2T@N VILLX!4#4)@0-
    MI;G,@ X![U.H1M]HT]/R+;;Y2QHK$)MC,88=<[#RO)(Y],]ZMUC6NF6=W")5
    M?454G SJ4K9]P5D(_P#U5/\`V':?\]=0_P#!A/\`_%T:CM'O_7WF;X0_YCW_
    M`&%[C_V6N@FF6! [`D%U3CU9@!^IKG/!D8BCUN-2Q5-5G4%F+'C;U)Y)]S70
    M7<3P;4(W!U<9Z$JP;'MG&,TH[%UOC8R:^BAF,*[287:JKG<3NP!_WP>N![
    MTCWVQ(R;:?S'?RQ'A<YP6ZYQC :B>VN96EEDC@WNJ)Y7F-C"EB"'P"#EL
    M]/X??(CDL;EX(02&*3>8$-PXVKM(P),;CR<_CCI5&1-_:(,@B6VG:;YMT8V9
    M7&WJ2V.C+T)ZTXZE`OE;PZ^8'_AS@J0"IQWR<#U/3J,UXK.[@F2:-(6.'!1Y
    MFXSLQ\Y4EON=_4#HFM[.2:*1BO"R[@#TN&P/4#!&?TH L6UPEU#YL88N
    M9<,,'@D'C\*FJ"UA:")D8@DR2/QZ,Y(_0U/0!0_MBV_YY7O_`(!3?_$52OM5
    MMVN]-(CN\+<$G-G/64@X7GKV_I6Y5#4//S2OOEO_1,E1]C.2E;</[8
    MMO\`GE>_^ 4W_P`11_;%M_SRO?\`P"F_^(J_13U*M+N<?XB\426S$6:WL45O
    M&)IW%HREMS;44%T.W^(DE3]T`'FL[POXQ>ZN(UV7K6DK;3%*KSO"Q5G!60)E
    MQ\K##9(P""1D#K-:T5-8BC_>>5'D D;D93C<KD9!P.X((!!!%4M&\*0:3<
    MI'39$/W44,BAL%2S;G8L=IP,G R>,DFKU[Z?U_6_\`P;][NK>G]?G_`,&_
    M-K4,<1:."\=,*;.< \T9_E6=!J@2R@AELI7:W";-UE<D,0,9SY7RGOT/I[
    MUTE%3J$;?:,6UU>",S22PWH>9]Y5;"X(7Y0N,^6,_=ST[U8_MRT_YY:A_P""
    M?\`(K2HHU'>/;^ON.8\&2"6/6Y%#!7U6=@&4J>=O4'D'V-=!=3-!$KJ 29
    M(TY]&< H:PO"',>_["]Q_[+703PK/$48D<@@CJ"#D'\"!2CL76^-E2YO)X
    MKB2.(.JHA8%=Q<$X'+?='`]>HZB2_F6"$JZ%VF\MF$#D@;2W,>=P/ [G
    MCGO5D6.-S&YG,S8_>Y4$`9P,`;2.3U'?V&$.G@JN)YA*)/-,HV[BVW;R,8Z<
    M=.U49%>*\NYYDAC>%3AR7>%N<;,?(6!7[_?T!Z&G+=7,[PQ1-#&Q$N]F0L"4
    M<+P-PQG.>IJ3S@)!*MS.LWS;I!LRV=O4%<=%7H!TIQTRV?RO-C$WEA) &!
    M+$$L1CKD=O4T`2VDS3P;G W!V0XZ$JQ7/MG&<5/35541410JJ, `8 %.H *H
    M:A_Q^:5_U\M_Z)DJ_61JU]:6U]IBW%U#$RSER'D"DY4@SSVSQGUJ9.R(F[
    M4UZ**HL***`"BH+MH$M9&NF"P`9?)X(]/?/3'?I6,[VPB62 P"%I1YL$4J
    MK&B[7QO(..3C/8X`YQR =!16?I*A8IPCJ\/F_NVC`"8VKG:!QC=N_7.3FM"@
    M#F_"'_,>_P"PON-N,YQS
    MTZ<]HR+%%1PSI.A:,G@X(92I!]P>1_]>I "BBB@ KAO%GAF[U+6H)[>=-M
    MSB(*Y^1@K-Q@<A?S)KJO[<TK_H)V7_`'_3_&J5]K&F/=Z:RZC:,$N"S$3J
    M=H\J09//J0/QK*IRS5FS"JH3C9LGM=!M[:T@@:>[8QQJA9;J5 <#&0H?`^@J
    M;Q!.R_P"_Z?XT?VYI7_03LO\`OG^-/W/(I>S
    M78/['MO^>M[_`.!LW_Q=']CVW_/6]_\``V;_`.+K"\0>,;6Q'EV-[:N5C,LT
    MBR!BJY"JJ_P[B3GG. I.T]#2\,^-H;XQ&\U*'9,Q4Q3E!)"VW<,N-JLN%?\`
    MA!!('(YJK0\B^6GY'33Z59QP/)-?&@+,1?3\ T
    MA'0BI_[#M/\`GKJ'_@PG_P#BZ9%KNAPQA(]6T\*/GE#]23GD]/_P"$AT7_
    M`*"G_\`@2G-'NFG[SS,KP9&(H];C4L5359U!9BQXV]2>2?<UT%W"T\&U"-
    MP=7&>AL&Q[9QC-<_P"#)$FCUN2)U>-]5G964Y# [<$'NZ.<RK"Y@4-+C"@
    M],I]O6B.P5OC90D@N&N4O3#RK+Y5@6VA7'4X&?WG(SCCJ:EF\^403_`&=@
    M8I2WE;EWD;&7UQG>O3WXJ*'4)'N(HA)!<(SA3-$,]USMZGD;1WZ-TJ62YF
    M(NA'Y2F*4O?[JKL5BS<CU/3V]S5&1:A=Y$21&+GA6()Q[XX_4_TJ2LV&]F
    MG(AB>%I"6*SA28V4!<D#//;>O8G/:I>\DEFBC8+RLNX@=2CA<CT!R3C]:
    MU%9DEU=F#SHG@4>>8=K1EO^6NP'.X=L5HKN"*'(8Y(& 3]* '50U#_`(_-
    M*_Z6_\`1,E7ZH:DLWF6,T-N\_DSEV1"H.#&ZY8@=6'>IEL3+8OT50_M"Y_
    MZ!%[_P!]P_\`QRCT+G_`!%[_WW#_\`'.9!S(H(=!.K*LL!C$X3RI%?Y1
    M&6!VE@"000&!Y&<Y!!-5/#GA4Z-(C/Y2QQ?<17:1F8M#LY"C(#2# 4##<Y
    M(%;/]H7/_0(O?^X?_CE']H7/_0(O?\`ON'_`..49;VU]!\ZWMKZ%^H+J[A
    MLH3+.X5-V?
    M;&<^U.Q=;XV-%DSN\EQ&F8*%>)=FS;G!&2>?F/L1QCKERVTL_K^"B
    MQDC$;PS)EWY9TW=[;FXR,<CCGIZ]:BO($6W"I/.2D\:<3ME0S*""0<G@YY
    MR1GCM3<R&'[49I3*+KRP-V%"=LQM'!X[D$_2@"U]B_T58?,Y\T2LV.IW[S
    M@=AG/T]ZMUFZ_>3V&B7EQ:Q2/*D+E63;[(4D,=Q&0".V3[&CT[O_H":A_W
    MW!_\=I74&U<TJ**9(4444`%%%%`!13)94AC+R'"CVS] !W/M3(;F.XW;"P
    M*]5="A'O@@''7GV-`$U%1PSQ7"%X7#IG&Y>0?H>_X5)0!S?A#_F/?]A>X_\`
    M9:Z2N;\(?\Q[_L+W'_LM=)4QV-:WQLC:"%X?):)&BP!L@K@=.;]EM_(\CR
    M(O)_YY[!MZYZ=.M3451D5VL1XTC:U@9$SM4QC"YZX':G?9;?S_/\BSO^>F
    MP;NF.O7I4U% !1110 4444 %%%% !116'H^CZ9+HMA))IUH[M;QLS- I))49
    M).EMWLB6W>R-B>800O4=]HSMC4LQ]@*RY$:[B:3,ZLSYX6)E/EC=A5#\
    MP!.3QDC/'(6I9M#TORCMT>QE/&%," $Y[\=._P#C6;-8Z5;G9)H.E^;O"<1J M5Y5B!G9G=\OW1-K,N!R1@8YR.@X ^M6JQ
    M;/1M'N8B[ZIJ,&P5%NI(^H9`0?PZ8]:L?\`"/:_P! C3__``&3_"C4=H]_
    MZ\S?"'_`#'OPO<?RUT,ID$9,2JS]@S;1>#_N;\&1I#'K<<2D::K.JJ
    MHP% VX '85T]*.Q=;XV9L=_<R06T@MH0;DCRQYQZ%2W/R\<#WZU.]Q<1I&'A
    MB\Z5]B)25Z$Y)VY' /8]JKR:?(;"P@,<$YM]N])#\K80KZ'N<]ED@FELA$
    M;>V4JPQ"6W1LHQP?EX]L#J!]HR"XNKJWM9)C:Q$QS./.."`,_*=O/X@<C\
    M:MQ&0Q@RJJOW"MN'YX'\JI"QD_LZ[MP(HC,K!(T/R1Y7&!P.,\].YK0H`***
    M* *\]UY,L<2P2S.ZLP";> ,9ZD?WA4D,C2H2\+PG.-KE2?KP365%!]KU.25D
    MN$B)<AOGB/W81['L?RK9H **** ,SQ!J,NE:<7MNJ-%MP'!(Y8#L1ZU@^$
    M?$5U>6!M3I[S?9%1%:!E'RXP-P=AS\O4?D._7NB2QM'(JNC JRL,@@]016=X
    M>@B@TP\F)(]\$;OL4#<Q49)]3[UE,G--/0QE&3J)IZ6$N;^^:W<0:7>I*1
    MA6S V/?!E%58KK5(H=BZ7=*5.5VK#@]<[LSDG.<YR#GUK>JO>>68@)/-R6^5
    M8G*LS>@P1_AW/2M+>9O'3?4SK:\O8?,:31[YY)7WN5,"C. .!YI[`=ZG_M.[
    M_P"@)J'_`'W!_P#':M6=NUO$0[LS,VX@NSA?8%N<<?GGITJQ18?,NWYG,>#&
    M+QZV[(T;-JLY-C_=X."1GZ&M]G>VMFDC3>Y54>[,%'<>OJ/J*P_"'_,>
    M_P"PO<?^RUT$ZQ-$3-@1J0Y). -IR#GV(I1V+K?&S,6\NS.EHX,3LZCS'5=V
    MTJYZ`D93KTY[ZGVNZ B2/>TBW/ENLRH&9?++D94XSZ'CMGN3;Q8WA\Q94D
    MD('CEYR`3@$'@X=.Q/:@BQM54R2HGER9W22\[RN.23R=I[]L51D5(U
    M!XHKIXX@7QL5<\+%P=P.,%F]_P`JOV4KRV^9#N97=,XZ[6*@GWXJ#[+82HUU
    M&P5"6<RQ3%!SC<<J1_=&?I5R)(8PD8PH]\_4D]S[T /HHHH`*** "BBB@#
    M(\3PW-QX>O8K-7:9E&%0\D;AN'OQGCOTK!\%V.LQ::TOVA(;>7!ACGC:3CDD
    MJ R[0<_CU],]?=74-E;27%S(L4,8RS-VK,\,ZA:WVBVL=M,LCV\,<<J\@JP4
    M=C//3@UC**=1-LPE"JIMZV+0ZN1\M]8@ILW/_M6J[PZG(D<[:EII2/\`
    M>_V-\#@C.?.Z8)K2N?,#><K-'QN55$\],#DCU'IUXK4E]LD%O9;?R]
    MQ>%_W9"XSMV_/Z8'KG(ZC6QT1?L31JTT8DBU/39$/1ELW(/X^=3_(UK_H(
    M:?\`^ 3_`/QVIM/#E9Y)`<R2;MQ0IN51D*>5Z8Y],]#5RBP=_TD<QX,#B/
    M6Q*RM(-5GW,J[03\N2!DX'MDUN:CQ9ES]V-TD8BJX8G\@:QO"'_`#'OPO<
    M?RUT$\RP1%V!/(``ZDDX _$D4H[%UOC9C.?MUY KRP3()4*SVZX8)*0,Y(
    M)! ./?IS1%<;9A=E82M[MD?*N1!C(SV)Z>Q%:+:BD1B%Q#- 9)!&H<`\D'
    M'()';'Y9XYI9;]8W*%(XE\K:NWD[-_<CC%49&7>R6TEGJ3R3ILD+F$%QME
    M(B49'][!'Y^X&-R6.:,21.LB'HRG(/XU7%\"I MYS&VF(*"0<`\G.T<$'K
    M^O%3P3+/$'4$<D$'J"#@C\"#0!)1110`4444`%%%% %#6M-_M?2I['S?)\W;
    M\^W=C# ],CTK#\+^&8;34N9BX=[N-),1RO"%!7('RL,]3R?R'?<UK4O[(T
    MJ>^\KSO*V_)NVYRP'7!]:P?"GB:.YTM+:>"82VBK'F&%Y RXP#\H.#QW_#T&
    M,N3VBON<\_9U7-O;OU-FYTJW2W=E-_(P'RHM]."Q[#(;CGO^=5186R.\=P
    M;Y9E"E4BU*X??NS@#+#GY3[ <YZXM7.M1I;N8(;II<84/93XS[X0FJ<.M&&)
    M@+*Y,A;))MKDESW)/D]>G&,8], 5HN7H=-.]O<_ L6NDVES:PS9J":BOM_
    MM&<XR,X^_4W]AVG_`#UU#_P83_\`Q=5=/U>*"RAAG@O T2! 4L;A@0`!GF,8
    ME6O[<M/>6H?"?_XBCW33]YYF5X,C$4>MQJ6*IJLZ@LQ8\;>I/)/N:Z"[
    MA:>#:A&X.KC/0E6#8]LXQFN?\&2"6/6Y%#!7U6=@&4J>=O4'D'V-;][*\5LQ
    MC.UV98U;&=I9@H..^,YQ[41V"M\;<>G2MCS8\L/\T33/,,;'!.6]=XX]J%
    MLF%MZ.DS"Y,J^8Q7Y/V $X/(]>*B-Y<+/%%;RO-\7<L\6QRI5R1RJC^'
    MCWSDXJ3[7)=2(;ADBDN`JNJC.PP[^X/>J,A[07H60QB$-/)OE E9=H"A<V
    MWOMZX&.WK5Z ,L**T:1D#&R,Y4#MC@=O:J:-<,+B(SMM@?!E"@R$;%; `&,_
    M,>W08QDY%BRE>6V5G.X[F&<8) 8@$CL<`9'&#G@=* +%%%% !1110 4444 0
    MW5K#>VTEO<QK+#(,,K=ZSO#=E;6FB636\"1O-!&\C <N2,Y)ZGDGZ5KUG: Q
    M?P]I;$8)M(CC/^P*FWO7)Y?>YK&C1115%!1110!S?A#_`)CW_87N/_9:Z">%
    M9XBC$CD$$=00<@_@0Y&P/B#1;G5$@T#[9%<WTMPDOVR./L1C@Y[#/XU>_M
    MKQ)_TG_`)48_P#"H3LCHJ4W5TU]Z_S-E+!1,DTDLLLJL"';:. & ' `Q\[
    M>_-,_LR)2QADEA8SF?*D'#%=IZ@\<FLGVO$G_0J?5&/_"CVO$G_0J?5&
    M/_"GS(CV4O[U_F;(L=JDI<SK*S;FD!7< <C&WH!V[>YS/!"L$0123R22>I
    M).2?Q)-<_P#VUXD_Z%3_`,J,?%']M>)/A4_P#*C'_A1S(/92\OO7^9TE%<
    MW_;7B3_H5/\`RHQ_X4?VUXD_Z%3_`,J,?%',@]E+R]?YG244451D%%%9^J
    MB&XM7LWNKFWDD .ZT)\Y0#G(P"0.,9QWQ0-;ZFA6;X>_Y%S2O^O2'_T`5C+X
    M)4\3ZXQE#&/;?9#8ZX.KV_AF.TLH(I_$&MI+&%A>.VN&!]@8J@"YVX
    MZ>U3=WV-N6'+;F_ .2Q29H]1U&]\P@$7LI8QD9Z @%<Y_'BM:J1BT
    MD] HHHH$%%%%`!1110`4444`%%%%`!1110`5GW!,5Y,[&=%DB15>&(N059B>
    M@..HZCO110!$EO+<R6_VDRGY)2)"H!'[Q"A/& <`'!';D=:C4SQS^=<PN-MZ
    M23&A;*^3M# #)P3]<9Q110!>LLL]U+M94EE#)N4J2-BCH>1R#UJW110`4444
    3`%%%% !1110`4444`%%%% '_V0``
    end
    On 1/15/2011 6:20 PM, Warren Brayshaw wrote:
    Hi Michael
    Regards
    Warren
    Yes, I built my symbol with a circle as well.  Think I used a 5 mil wire
    width (0.127 mm) and it looked fairly decent.
    I still say the best solution for this is for CadSoft to create a
    testpoint object in the layout tool that, like you suggested, works like
    a via without a drill.  Then you could write a ULP to add unplaced
    testpoints to the layout that the PCB designer could then place and
    route.  Your ULP might optionally load a list of net names that are to
    have test points added (there are third party tools that will analyze a
    netlist and generate a list of needed testpoints).  If you wanted to get
    really sophisticated your ULP could read your netlist and import the
    BSDL files for whatever JTAG devices you have on the board and it would
    skip placing testpoints for anything you can cover with a JTAG scan
    chain.  BSDL is just a subset of VHDL so it can be pretty readily
    parsed.  You'd probably also like the ability to attach a "no_test"
    attribute on any nets that for instance, carried high speed signals
    where a hanging testpoint might act as a stub and generate reflections
    so the ULP would skip placing testpoints on those as well.  This is all
    sort of blue sky thinking but if Eagle would support such a testpoint
    object you could do all sorts of cool things.
    Someone mentioned the possibility of having a ULP autoplace the
    testpoints and route them.  Some might be interested in that, but
    personally I'd be happy with just unplaced testpoints at the bottom of
    the layout.  I think a human can do a better job of looking at the trade
    offs deciding the best place to drop the testpoint and route it.
    Anyway, thanks for your help.  This is now a part of my layout process.
    -Michael
