EAGLE User Support (English) Testpoints for ICT testers
  • Replies 26 replies
  • Views 5368 views
Is there a way to systematically insert ICT testpoints onto a PCB layout
without putting a testpoint component on each net on my schematic?
Ideally I'd like to know the percent of nets covered by testpoints and
have someway to highlight or locate nets without a testpoint so I can
either add one or can decide that the particular net isn't worth the
trouble to test.
-Michael
    On 1/15/2011 6:20 PM, Warren Brayshaw wrote:
    Hi Michael
    Sounds as if you are doing it the way I suggested and don't have any ideas
    to refine it any further. Since my initial response I have determined that
    circles around the junction dots work best,in my opinion, (see attached).
    You need to get the width of  the circle wire to something you like.
    Regards
    Warren
    Yes, I built my symbol with a circle as well.  Think I used a 5 mil wire
    width (0.127 mm) and it looked fairly decent.
    I still say the best solution for this is for CadSoft to create a
    testpoint object in the layout tool that, like you suggested, works like
    a via without a drill.  Then you could write a ULP to add unplaced
    testpoints to the layout that the PCB designer could then place and
    route.  Your ULP might optionally load a list of net names that are to
    have test points added (there are third party tools that will analyze a
    netlist and generate a list of needed testpoints).  If you wanted to get
    really sophisticated your ULP could read your netlist and import the
    BSDL files for whatever JTAG devices you have on the board and it would
    skip placing testpoints for anything you can cover with a JTAG scan
    chain.  BSDL is just a subset of VHDL so it can be pretty readily
    parsed.  You'd probably also like the ability to attach a "no_test"
    attribute on any nets that for instance, carried high speed signals
    where a hanging testpoint might act as a stub and generate reflections
    so the ULP would skip placing testpoints on those as well.  This is all
    sort of blue sky thinking but if Eagle would support such a testpoint
    object you could do all sorts of cool things.
    Someone mentioned the possibility of having a ULP autoplace the
    testpoints and route them.  Some might be interested in that, but
    personally I'd be happy with just unplaced testpoints at the bottom of
    the layout.  I think a human can do a better job of looking at the trade
    offs deciding the best place to drop the testpoint and route it.
    Anyway, thanks for your help.  This is now a part of my layout process.
    -Michael
    "Michael Sansom"  wrote
    Warren,
    Thanks for your suggestion.  It has proven to be the most workable near
    term solution for placing ICT test points on schematics.  I built a
    schematic symbol much like you suggested.  I used the point type symbol
    pin, I assumed that you did the same. Putting it on a separate layer
    really makes it workable.  The only (small) fly in the ointment is the
    connection dot that Eagle places when you drop the symbol on a net.  As
    you pointed out, it's completely invisible if you drop it on existing
    connection dots and turn the test point layer off.  I suppose that Eagle
    is generating a short (or even null) wire segment and joining it to the
    wire you dropped it on and generating the connection dot in the process.
      Do you know of any way to modify this behavior of Eagle while still
    getting the net connection to the test point?
    Thanks again for the suggestion.
    -Michael
    Hi Michael
    Regards
    Warren
    M_]C_X `02D9)1@`!`0```0`!``#_VP!#``P)"0L)" P+"@L.#0P/$Q\4$Q$1
    M$R8;'1<?2@PRPH+"LR.$@],C5$-BLL/E4_1$I,4%%0,#Q87E=.7DA/4$W_
    MVP!#`0T.#A,0$R44%"5-,RPS34U-34U-34U-34U-34U-34U-34U-34U-34U-
    M34U-34U-34U-34U-34U-34U-34U-34W_P `1" #H`(H#`2(``A$!`Q$!_\0`
    M'P```04!`0$!`0$```````````$"`P0%!@<("0H+_\0`M1 ``@$#`P($`P4%
    M! 0```%]`0(#``01!1(A,4$&$U%A!R)Q%#!D:$((TQP152T? D,V)R@@D*
    M%A7J#A(6&AXB)BI3E)66EYB9FJCI6FIZBIJKSM6VM[BYNL#Q,7&
    MQ\C)RM+3U-76U]C9VN'BX3EYN?HZ>KQ\O/T]?;W/GZ_\0`'P$``P$!`0$!
    M`0$!`0````````$"`P0%!@<("0H+_\0`M1$``@$"! 0#! <%! 0``0)W``$"
    M`Q$$!2$Q!A)!40=A<1,B,H$(%$*1H;'!"2,S4O 58G+1"A8D-.$E\1<8&1HF
    M)R@IC4V-S@Y.D-$149'2$E4U155E=865IC9&5F9VAI:G-T=79W>'EZ@H.$
    MA8:'B(FDI.4E9:7F)F:HJ.DI::GJFJLK.TM;:WN+FZPL/$Q<;'R,G*TM/4
    MU=;7V-G:XN/DY>;GZ.GJ\O/T]?;W^/GZ_]H`# ,!``(1`Q$`/P#U6J&H?\?F
    ME?\`7RW_`)DJ_5#4/\`C\TK_KY;_P!$R5,MB9;%^BBBJ"BBB@`HHHH`***
    M* "BBHR9K>RN)D`1QLX!Z9`S0!/14$\S12VR*!B60HV?38QX_$"H[>ZDGN
    MIHVCV1JB.F?O$$L,D=ON].OKZ `MT444`%%%% !5#4//S2OOEO_1,E'DZK
    M_P`_ME_X"/\`_'*XKQ59>(9-7ME\UYXY&7[/]G!1%B45#:K,EI`MTZO<"-1(R]&;')'3O4U:FZ"BBB@ HHIJLKHKHP
    M96&00<@B@!U%-#Q8P)4X8`]#C//X$4Z@`J&ZA^TVLT&[;YJ,F[&<9&,UR]
    MMJGB?5G4?[.72%M[6[DMA]H$H8[3UX..A%6O^*T_P"H!_Y&J>8V=)K=HV/
    MN9YX&GCAC6)RXV2%R3M*XY48^]G/M3(TO1>O,\-N%=$0@3,2`"QS]SG[W3VK
    MXK3J ?1J/T_P"H!_Y&HYA>S\T=)17-_P#%:?\`4 \C4?\5IU`/\`
    MR-1S![/S1TE%S\T=)5#4//S2OOEO
    M_1,E']CVW_/6]_\``V;_`.JE?:5;K=Z:!)=X:X(.;R4_P#*0\?-QT[?UI2
    MO8YI.5MC<HJA_8]M_P`];W_P-F_^+H_L>V_YZWO_`(&S?_%T]2KR[$.M:TFC
    MQ1_N_-EDR0"=JHQN9FP< 9'8DD@`$FJ6C>X-6N4B")LE'[J6%V=2V"Q5MR
    M5.T9&1@X/.016;XG\+><S7-LM[,DD!AF"7#22(%8.KK,"W0@KN[@@$BJGA
    MKP8;*ZB(FNS9Q8<S.TD#2L%9`%CW90#<Q)/7@ 8R3>O;3^OZV+][LK6WO_7Y
    M?\#NM4>UD67?Y;##!%$@]1@ GGIQ^E9J2S'2+6&$31,B(DS- ^5&WG`X)Y
    M`&5Z9SQUJ:;2K-(BTLU\JC'2GSUX P2<]N]5)+2P2T@N VILLX!4#4)@0-
    MI;G,@ X![U.H1M]HT]/R+;;Y2QHK$)MC,88=<[#RO)(Y],]ZMUC6NF6=W")5
    M?454G SJ4K9]P5D(_P#U5/\`V':?\]=0_P#!A/\`_%T:CM'O_7WF;X0_YCW_
    M`&%[C_V6N@FF6! [`D%U3CU9@!^IKG/!D8BCUN-2Q5-5G4%F+'C;U)Y)]S70
    M7<3P;4(W!U<9Z$JP;'MG&,TH[%UOC8R:^BAF,*[287:JKG<3NP!_WP>N![
    MTCWVQ(R;:?S'?RQ'A<YP6ZYQC :B>VN96EEDC@WNJ)Y7F-C"EB"'P"#EL
    M]/X??(CDL;EX(02&*3>8$-PXVKM(P),;CR<_CCI5&1-_:(,@B6VG:;YMT8V9
    M7&WJ2V.C+T)ZTXZE`OE;PZ^8'_AS@J0"IQWR<#U/3J,UXK.[@F2:-(6.'!1Y
    MFXSLQ\Y4EON=_4#HFM[.2:*1BO"R[@#TN&P/4#!&?TH L6UPEU#YL88N
    M9<,,'@D'C\*FJ"UA:")D8@DR2/QZ,Y(_0U/0!0_MBV_YY7O_`(!3?_$52OM5
    MMVN]-(CN\+<$G-G/64@X7GKV_I6Y5#4//S2OOEO_1,E1]C.2E;</[8
    MMO\`GE>_^ 4W_P`11_;%M_SRO?\`P"F_^(J_13U*M+N<?XB\426S$6:WL45O
    M&)IW%HREMS;44%T.W^(DE3]T`'FL[POXQ>ZN(UV7K6DK;3%*KSO"Q5G!60)E
    MQ\K##9(P""1D#K-:T5-8BC_>>5'D D;D93C<KD9!P.X((!!!%4M&\*0:3<
    MI'39$/W44,BAL%2S;G8L=IP,G R>,DFKU[Z?U_6_\`P;][NK>G]?G_`,&_
    M-K4,<1:."\=,*;.< \T9_E6=!J@2R@AELI7:W";-UE<D,0,9SY7RGOT/I[
    MUTE%3J$;?:,6UU>",S22PWH>9]Y5;"X(7Y0N,^6,_=ST[U8_MRT_YY:A_P""
    M?\`(K2HHU'>/;^ON.8\&2"6/6Y%#!7U6=@&4J>=O4'D'V-=!=3-!$KJ 29
    M(TY]&< H:PO"',>_["]Q_[+703PK/$48D<@@CJ"#D'\"!2CL76^-E2YO)X
    MKB2.(.JHA8%=Q<$X'+?='`]>HZB2_F6"$JZ%VF\MF$#D@;2W,>=P/ [G
    MCGO5D6.-S&YG,S8_>Y4$`9P,`;2.3U'?V&$.G@JN)YA*)/-,HV[BVW;R,8Z<
    M=.U49%>*\NYYDAC>%3AR7>%N<;,?(6!7[_?T!Z&G+=7,[PQ1-#&Q$N]F0L"4
    M<+P-PQG.>IJ3S@)!*MS.LWS;I!LRV=O4%<=%7H!TIQTRV?RO-C$WEA) &!
    M+$$L1CKD=O4T`2VDS3P;G W!V0XZ$JQ7/MG&<5/35541410JJ, `8 %.H *H
    M:A_Q^:5_U\M_Z)DJ_61JU]:6U]IBW%U#$RSER'D"DY4@SSVSQGUJ9.R(F[
    M4UZ**HL***`"BH+MH$M9&NF"P`9?)X(]/?/3'?I6,[VPB62 P"%I1YL$4J
    MK&B[7QO(..3C/8X`YQR =!16?I*A8IPCJ\/F_NVC`"8VKG:!QC=N_7.3FM"@
    M#F_"'_,>_P"PON-N,YQS
    MTZ<]HR+%%1PSI.A:,G@X(92I!]P>1_]>I "BBB@ KAO%GAF[U+6H)[>=-M
    MSB(*Y^1@K-Q@<A?S)KJO[<TK_H)V7_`'_3_&J5]K&F/=Z:RZC:,$N"S$3J
    M=H\J09//J0/QK*IRS5FS"JH3C9LGM=!M[:T@@:>[8QQJA9;J5 <#&0H?`^@J
    M;Q!.R_P"_Z?XT?VYI7_03LO\`OG^-/W/(I>S
    M78/['MO^>M[_`.!LW_Q=']CVW_/6]_\``V;_`.+K"\0>,;6Q'EV-[:N5C,LT
    MBR!BJY"JJ_P[B3GG. I.T]#2\,^-H;XQ&\U*'9,Q4Q3E!)"VW<,N-JLN%?\`
    MA!!('(YJK0\B^6GY'33Z59QP/)-?&@+,1?3\ T
    MA'0BI_[#M/\`GKJ'_@PG_P#BZ9%KNAPQA(]6T\*/GE#]23GD]/_P"$AT7_
    M`*"G_\`@2G-'NFG[SS,KP9&(H];C4L5359U!9BQXV]2>2?<UT%W"T\&U"-
    MP=7&>AL&Q[9QC-<_P"#)$FCUN2)U>-]5G964Y# [<$'NZ.<RK"Y@4-+C"@
    M],I]O6B.P5OC90D@N&N4O3#RK+Y5@6VA7'4X&?WG(SCCJ:EF\^403_`&=@
    M8I2WE;EWD;&7UQG>O3WXJ*'4)'N(HA)!<(SA3-$,]USMZGD;1WZ-TJ62YF
    M(NA'Y2F*4O?[JKL5BS<CU/3V]S5&1:A=Y$21&+GA6()Q[XX_4_TJ2LV&]F
    MG(AB>%I"6*SA28V4!<D#//;>O8G/:I>\DEFBC8+RLNX@=2CA<CT!R3C]:
    MU%9DEU=F#SHG@4>>8=K1EO^6NP'.X=L5HKN"*'(8Y(& 3]* '50U#_`(_-
    M*_Z6_\`1,E7ZH:DLWF6,T-N\_DSEV1"H.#&ZY8@=6'>IEL3+8OT50_M"Y_
    MZ!%[_P!]P_\`QRCT+G_`!%[_WW#_\`'.9!S(H(=!.K*LL!C$X3RI%?Y1
    M&6!VE@"000&!Y&<Y!!-5/#GA4Z-(C/Y2QQ?<17:1F8M#LY"C(#2# 4##<Y
    M(%;/]H7/_0(O?^X?_CE']H7/_0(O?\`ON'_`..49;VU]!\ZWMKZ%^H+J[A
    MLH3+.X5-V?
    M;&<^U.Q=;XV-%DSN\EQ&F8*%>)=FS;G!&2>?F/L1QCKERVTL_K^"B
    MQDC$;PS)EWY9TW=[;FXR,<CCGIZ]:BO($6W"I/.2D\:<3ME0S*""0<G@YY
    MR1GCM3<R&'[49I3*+KRP-V%"=LQM'!X[D$_2@"U]B_T58?,Y\T2LV.IW[S
    M@=AG/T]ZMUFZ_>3V&B7EQ:Q2/*D+E63;[(4D,=Q&0".V3[&CT[O_H":A_W
    MW!_\=I74&U<TJ**9(4444`%%%%`!13)94AC+R'"CVS] !W/M3(;F.XW;"P
    M*]5="A'O@@''7GV-`$U%1PSQ7"%X7#IG&Y>0?H>_X5)0!S?A#_F/?]A>X_\`
    M9:Z2N;\(?\Q[_L+W'_LM=)4QV-:WQLC:"%X?):)&BP!L@K@=.;]EM_(\CR
    M(O)_YY[!MZYZ=.M3451D5VL1XTC:U@9$SM4QC"YZX':G?9;?S_/\BSO^>F
    MP;NF.O7I4U% !1110 4444 %%%% !116'H^CZ9+HMA))IUH[M;QLS- I))49
    M).EMWLB6W>R-B>800O4=]HSMC4LQ]@*RY$:[B:3,ZLSYX6)E/EC=A5#\
    MP!.3QDC/'(6I9M#TORCMT>QE/&%," $Y[\=._P#C6;-8Z5;G9)H.E^;O"<1J M5Y5B!G9G=\OW1-K,N!R1@8YR.@X ^M6JQ
    M;/1M'N8B[ZIJ,&P5%NI(^H9`0?PZ8]:L?\`"/:_P! C3__``&3_"C4=H]_
    MZ\S?"'_`#'OPO<?RUT,ID$9,2JS]@S;1>#_N;\&1I#'K<<2D::K.JJ
    MHP% VX '85T]*.Q=;XV9L=_<R06T@MH0;DCRQYQZ%2W/R\<#WZU.]Q<1I&'A
    MB\Z5]B)25Z$Y)VY' /8]JKR:?(;"P@,<$YM]N])#\K80KZ'N<]ED@FELA$
    M;>V4JPQ"6W1LHQP?EX]L#J!]HR"XNKJWM9)C:Q$QS./.."`,_*=O/X@<C\
    M:MQ&0Q@RJJOW"MN'YX'\JI"QD_LZ[MP(HC,K!(T/R1Y7&!P.,\].YK0H`***
    M* *\]UY,L<2P2S.ZLP";> ,9ZD?WA4D,C2H2\+PG.-KE2?KP365%!]KU.25D
    MN$B)<AOGB/W81['L?RK9H **** ,SQ!J,NE:<7MNJ-%MP'!(Y8#L1ZU@^$
    M?$5U>6!M3I[S?9%1%:!E'RXP-P=AS\O4?D._7NB2QM'(JNC JRL,@@]016=X
    M>@B@TP\F)(]\$;OL4#<Q49)]3[UE,G--/0QE&3J)IZ6$N;^^:W<0:7>I*1
    MA6S V/?!E%58KK5(H=BZ7=*5.5VK#@]<[LSDG.<YR#GUK>JO>>68@)/-R6^5
    M8G*LS>@P1_AW/2M+>9O'3?4SK:\O8?,:31[YY)7WN5,"C. .!YI[`=ZG_M.[
    M_P"@)J'_`'W!_P#':M6=NUO$0[LS,VX@NSA?8%N<<?GGITJQ18?,NWYG,>#&
    M+QZV[(T;-JLY-C_=X."1GZ&M]G>VMFDC3>Y54>[,%'<>OJ/J*P_"'_,>
    M_P"PO<?^RUT$ZQ-$3-@1J0Y). -IR#GV(I1V+K?&S,6\NS.EHX,3LZCS'5=V
    MTJYZ`D93KTY[ZGVNZ B2/>TBW/ENLRH&9?++D94XSZ'CMGN3;Q8WA\Q94D
    MD('CEYR`3@$'@X=.Q/:@BQM54R2HGER9W22\[RN.23R=I[]L51D5(U
    M!XHKIXX@7QL5<\+%P=P.,%F]_P`JOV4KRV^9#N97=,XZ[6*@GWXJ#[+82HUU
    M&P5"6<RQ3%!SC<<J1_=&?I5R)(8PD8PH]\_4D]S[T /HHHH`*** "BBB@#
    M(\3PW-QX>O8K-7:9E&%0\D;AN'OQGCOTK!\%V.LQ::TOVA(;>7!ACGC:3CDD
    MJ R[0<_CU],]?=74-E;27%S(L4,8RS-VK,\,ZA:WVBVL=M,LCV\,<<J\@JP4
    M=C//3@UC**=1-LPE"JIMZV+0ZN1\M]8@ILW/_M6J[PZG(D<[:EII2/\`
    M>_V-\#@C.?.Z8)K2N?,#><K-'QN55$\],#DCU'IUXK4E]LD%O9;?R]
    MQ>%_W9"XSMV_/Z8'KG(ZC6QT1?L31JTT8DBU/39$/1ELW(/X^=3_(UK_H(
    M:?\`^ 3_`/QVIM/#E9Y)`<R2;MQ0IN51D*>5Z8Y],]#5RBP=_TD<QX,#B/
    M6Q*RM(-5GW,J[03\N2!DX'MDUN:CQ9ES]V-TD8BJX8G\@:QO"'_`#'OPO<
    M?RUT$\RP1%V!/(``ZDDX _$D4H[%UOC9C.?MUY KRP3()4*SVZX8)*0,Y(
    M)! ./?IS1%<;9A=E82M[MD?*N1!C(SV)Z>Q%:+:BD1B%Q#- 9)!&H<`\D'
    M'()';'Y9XYI9;]8W*%(XE\K:NWD[-_<CC%49&7>R6TEGJ3R3ILD+F$%QME
    M(B49'][!'Y^X&-R6.:,21.LB'HRG(/XU7%\"I MYS&VF(*"0<`\G.T<$'K
    M^O%3P3+/$'4$<D$'J"#@C\"#0!)1110`4444`%%%% %#6M-_M?2I['S?)\W;
    M\^W=C# ],CTK#\+^&8;34N9BX=[N-),1RO"%!7('RL,]3R?R'?<UK4O[(T
    MJ>^\KSO*V_)NVYRP'7!]:P?"GB:.YTM+:>"82VBK'F&%Y RXP#\H.#QW_#T&
    M,N3VBON<\_9U7-O;OU-FYTJW2W=E-_(P'RHM]."Q[#(;CGO^=5186R.\=P
    M;Y9E"E4BU*X??NS@#+#GY3[ <YZXM7.M1I;N8(;II<84/93XS[X0FJ<.M&&)
    M@+*Y,A;))MKDESW)/D]>G&,8], 5HN7H=-.]O<_ L6NDVES:PS9J":BOM_
    MM&<XR,X^_4W]AVG_`#UU#_P83_\`Q=5=/U>*"RAAG@O T2! 4L;A@0`!GF,8
    ME6O[<M/>6H?"?_XBCW33]YYF5X,C$4>MQJ6*IJLZ@LQ8\;>I/)/N:Z"[
    MA:>#:A&X.KC/0E6#8]LXQFN?\&2"6/6Y%#!7U6=@&4J>=O4'D'V-;][*\5LQ
    MC.UV98U;&=I9@H..^,YQ[41V"M\;<>G2MCS8\L/\T33/,,;'!.6]=XX]J%
    MLF%MZ.DS"Y,J^8Q7Y/V $X/(]>*B-Y<+/%%;RO-\7<L\6QRI5R1RJC^'
    MCWSDXJ3[7)=2(;ADBDN`JNJC.PP[^X/>J,A[07H60QB$-/)OE E9=H"A<V
    MWOMZX&.WK5Z ,L**T:1D#&R,Y4#MC@=O:J:-<,+B(SMM@?!E"@R$;%; `&,_
    M,>W08QDY%BRE>6V5G.X[F&<8) 8@$CL<`9'&#G@=* +%%%% !1110 4444 0
    MW5K#>VTEO<QK+#(,,K=ZSO#=E;6FB636\"1O-!&\C <N2,Y)ZGDGZ5KUG: Q
    M?P]I;$8)M(CC/^P*FWO7)Y?>YK&C1115%!1110!S?A#_`)CW_87N/_9:Z">%
    M9XBC$CD$$=00<@_@0Y&P/B#1;G5$@T#[9%<WTMPDOVR./L1C@Y[#/XU>_M
    MKQ)_TG_`)48_P#"H3LCHJ4W5TU]Z_S-E+!1,DTDLLLJL"';:. & ' `Q\[
    M>_-,_LR)2QADEA8SF?*D'#%=IZ@\<FLGVO$G_0J?5&/_"CVO$G_0J?5&
    M/_"GS(CV4O[U_F;(L=JDI<SK*S;FD!7< <C&WH!V[>YS/!"L$0123R22>I
    M).2?Q)-<_P#VUXD_Z%3_`,J,?%']M>)/A4_P#*C'_A1S(/92\OO7^9TE%<
    MW_;7B3_H5/\`RHQ_X4?VUXD_Z%3_`,J,?%',@]E+R]?YG244451D%%%9^J
    MB&XM7LWNKFWDD .ZT)\Y0#G(P"0.,9QWQ0-;ZFA6;X>_Y%S2O^O2'_T`5C+X
    M)4\3ZXQE#&/;?9#8ZX.KV_AF.TLH(I_$&MI+&%A>.VN&!]@8J@"YVX
    MZ>U3=WV-N6'+;F_ .2Q29H]1U&]\P@$7LI8QD9Z @%<Y_'BM:J1BT
    MD] HHHH$%%%%`!1110`4444`%%%%`!1110`5GW!,5Y,[&=%DB15>&(N059B>
    M@..HZCO110!$EO+<R6_VDRGY)2)"H!'[Q"A/& <`'!';D=:C4SQS^=<PN-MZ
    M23&A;*^3M# #)P3]<9Q110!>LLL]U+M94EE#)N4J2-BCH>1R#UJW110`4444
    3`%%%% !1110`4444`%%%% '_V0``
    end
    Warren,
    -Michael
    On 12/31/2010 2:01 AM, Tilmann Reh wrote:
    Warren Brayshaw schrieb:
    >> There have been a lot of discussion on  the placement of pads and the
    >> validity of testing regimes but very little on the second part of the
    >> question.
    >> As I understand it, most of the points contacted during testing are regular
    >> pads.
    To my knowledge, this is not true. Especially in high volume ICT,
    testpoints always are separate SMD pads. This makes sure that these
    areas are always free for the test needles and have a clean, smooth
    surface. When using pads as test points, it is very difficult to get
    reproducible contact - and the needles wear out much faster due to
    horizontal forces.
    >> So, how do you analyse the layout to determine if nets have  test points or
    >> pads acting as testpoints or nothing suitable?
    If there were special ICTP objects (as suggested), it would be no
    problem to generate a list of covered and uncovered signals, including
    statistics, with a small ULP.
    Tilmann
    You can use regular SMT pads, but in general you shouldn't use vias (or
    at least the contract manufactures I use will not use them).
    Tilmann is right, in general you want to use a dedicated test pad that
    is separate from both your vias and your SMT pads.  The reasons are as
    follows:
    1.) CMs have problems with the ICT test probes sticking in the holes of
    vias.  In some cases this will result in the board getting hung up on
    the ICT test fixture when the fixture tries to open.  In my experience
    very few CMs will want to try this for this reason.
    2.) Some CMs will let you use SMT pads but they don't like it since they
    don't know the height of the solder "bump" precisely so they have some
    issues setting the ICT pin height.  They really don't like building a
    fixture that has a mix of dedicated ICT pads (which are unsoldered) and
    SMT pads with solder (or at least in my experience).  However, if your
    board is such that you can get good coverage from just the SMT pads this
    is an option.
    3.) Complicating point 2 is the fact that in general you want your ICT
    fixture probes to only interface with one side of the board (this is a
    cost and complexity issue, you can test on both sides if you're
    motivated).  If you've got a board with components on one side only,
    generally you're going to find that you want the ICT test points on the
    side opposite the components.  This also tends to take testing against
    your topside SMT pads off the table.  For a design with components on
    the top side only, you'll tend to be driven to putting all your ICT pads
    on the bottom side.
    -Michael
    On 12/30/2010 8:08 AM, Olin Lathrop wrote:
    Wow, that was a amazing bit of sideways logic. I was reacting to your
    rediculous assertion that you always need to give a tester access to all
    nets. It only takes a single counter example to disprove that, and I
    supplied several such counter examples.
    Your response is to act as if I said you are always limited to doing things
    as in the counter examples, which is completely illogical.
    Of course there are many methods to test a board. The point is that you
    don't always need to have access to every net, not that you should never
    have access to any net.
    Sorry, been traveling for some time, back in the office now.
    If I used sideways logic then you are just as guilty of it.  I gave you
    several counter examples where your methodology would not work and
    several points on how your way can in some cases cause you to spend
    recurring costs on the BOM, yet you choose to ignore those as well.  So,
    perhaps we are both guilty of sideways logic.
    I have never claimed that I want access to every net on a board in all
    cases.  Sometimes I might (particularly if it's a board with no
    microcontroller or reprogrammable logic, which I certainly admit is
    rather rare).  In fact, in general I want to use a combination of
    methodologies to do automated testing of boards.  Ideally, I'd use JTAG,
    ICT test points, and yes your method as well where appropriate
    (meaning where possible and where it does not incur recurring BOM cost).
      A mix of methods will give me the most thorough and cost effective
    means to test a populated board.
    In summary I still propose that CadSoft should consider a means to add
    test points during layout without adding them explicitly to the
    schematic, (much like the way we add vias).  This is supported in many
    of the major CAD systems that Eagle competes with and follows the
    methodology and division of labor used by many enterprises.
    question.
    pads.
    horizontal forces.
    Tilmann
    "Michael Sansom"  wrote .
    ......Ideally I'd like to know the percent of nets covered by testpoints
    and
    trouble to test.
    question.
    pads. Eagle does not have a way of flagging these pads with a test point
    attribute. Hopefully this will arrive when 'pad stacks' are implemented.
    It maybe reasonable to give a library part an 'ICT-testpoint' attribute.
    This would imply that any time it is used all its pins were useful for
    machine probing. The format of the text value within  the attribute could
    even exclude or include particular pins. Only this would not be acceptable
    for parts under heatsinks, for example. To counter this an attribute applied
    to the part on the board of  'Don't probe' could be used. Now a ULP could
    provide a listing of nets to points, close to what you were asking.
    I imagine something could be done with another ULP that copies these points
    designated as testpoints, and that includes vias, to a user defined layer or
    the tTest and bTest layers. A bright colour here may assist in confirming
    testpoint locations before generating a file for the fixture maker.
    Just some thoughts
    Warren
    Michael Sansom wrote on Wed, 29 December 2010 21:28
    So the functionality of Eagle is perfect, ad unguem factus.  No changes
    necessary.  Carve it in stone, it's done.
    If you want to take that stance I think I'm not the one that sounds
    silly.
    No, I said your request is silly, not that all are.
    The issues with your request are:
    You are fixated on having a test point on every net, and therefore don't
    want the test points to appear in the schematic and clutter it up.
    You want to make circuit changes (test points are components, so adding
    them is making a circuit change) without changing the schematic or it being
    shown there.
    Eagle can already do what you want anyway.  You could write a ULP that runs
    over every net in the schematic and adds a test point to it.  The test
    points would be a real part you define in the library, so would appear in
    the board editor and need to be placed along with all the other parts.  If
    you don't want them to appear on the schematic, have the ULP add pages to
    the end of the schematic that show only the test points connected to nets
    by name.  If you really really don't want people to see these test points
    in the schematic, don't export those pages when you make the PDF file.  I
    really don't see the big deal with this method.  All this fuss is because
    you don't want a extra page or two at the end of the schematic with test
    points on it!?
    Quote:
    But care to explain to me how you test the output of a microcontroller
    that doesn't terminate on another JTAG device without adding
    additional hardware or taking up additional pin resources on the micro?
    I already did several times, but to reiterate, you have various options.
    Of course you can put a test point on the output of the subcircuit driven
    by that micro pin.  Sometimes that output will be a board output you
    already have access to.  Sometimes you do have extra pins on the micro and
    you can feed some signals back.  Each case is different.  The point is you
    don't always need a test point on every net to accomplish the task.
    Quote:
    Let's say that I have a port pin on a microcontroller which I've hooked
    to the internal PWM.  I want to filter the output and run it to a
    connector that goes off board.  So, the output of the micro goes to an
    op-amp and associated passive components which implement a 2nd order
    Butterworth LPF.  The output of that active LPF goes to a connector and
    drives some externally connected device (maybe even someone else's
    product).  Sure, I could take the output of the LPF and run it to an
    A/D
    pin on my micro, but I've got to use precious port pins on my micro and
    if I've got many signals like this I'll either run out of port pins or
    A/D pins. If I run out of pins I can go to a bigger, higher pin count
    micro or I can start dropping analog mux chips around the board.  Each
    generates recurring cost on the product.
    Who said the only choice was to run the output of the LPF back to the
    micro?  Obviously it isn't.  Sometimes a pin is available and that's a good
    choice.  In this case the signal goes off board, so of course the tester
    will have access to it.  It could hook up to the intended board connector,
    or you could place a pogo pin pad close to the connector, depending on how
    mechanically awkward it is to connect to the real connector.
    Again, the point was you don't need access to every single net.  This
    example actually makes that point very well.  The micro's PWM output drives
    the filter, and you can verify the filter to acceptable confidence just be
    looking at its output with a known input pattern.  The filter in your
    example has several internal nets.  Most failures are going to manifest
    themselves as incorrect output given a well designed input pattern, thereby
    not requiring each component in the filter to be tested individually.  This
    is also a good case where using the micro as part of the test process is
    probably useful.  You can use the micro's own PWM generator to produce the
    test signals for the LPF.
    Just because I said you don't always need to test every net, you are
    arguing against my statement because sometimes you do have to test some
    nets.  That is a logical fallacy since it doesn't counter my statement at
    all.
    Quote:
    OTOH - I can drop ICT test points around my op-amp and the passive
    components.  Using the JTAG on the micro I can wiggle that port pin and
    watch the effects on the nets connected to it.  I can also directly
    measure the resistors, capacitors, and inductors values and confirm
    I've
    loaded the right components and that indeed they did get soldered to
    the
    board.  If my board isn't super tight, this cost me exactly nothing.
    That is wrong.  Of course it costs something.  Testing every net in the
    filter causes high cost in the tester, engineering time to design and debug
    the test procedure, and incremental production time to perform the test.
    The first two are fixed costs and amortized over all units.  If your
    volumes are high, the cost may be low per unit, but certainly not free.
    The third is incremental cost per unit, and adds directly to the production
    cost.  Production time is not free.
    So now let me explain some logic because you seem to have a problem in that
    area.  I can forsee you countering this with "but my volumes are so high,
    and the cost of sending bad LPFs out there is much more than the extra
    production time", or some such irrelevant statement.  The paragraph is a
    rebuttal to your silly statement that what you describe "cost you exactly
    nothing", not that the LPF can't or shouldn't be tested, or whatever.  I
    have shown three ways the cost is more than zero, thereby disproving your
    assertion.  If you want to rebut, you need to show how all three points are
    invalid.
    Quote:
    I understand completely the approach you propose.
    Clearly not, since I haven't proposed anything.  I have only provided
    counter examples to your claim that you need access to all nets.
    Quote:
    I've used it.  It
    works well in some cases.  But it can easily require you to bump into a
    higher pin count microcontroller or start dropping analog muxes or
    digital gates on your design.  I'm not prepared to expend recurring
    costs like that.
    Of course.  Looping signals back to the micro to facilitate testing isn't
    always the optimum tradeoff, and I never said it was.  I'm not the one who
    thinks one plan (bringing out all nets to a tester) is the right approach
    for all boards.  In cases where you have unused pins on the micro, using
    them for testing is something to consider.
    Quote:
    Yes, the sometimes the smallest micros don't do JTAG.  But, since JTAG
    has become the de facto standard for connecting a debugger to a
    microcontroller it's pretty rare.
    Then you're not up on what microcontroller products there are.  Some do
    have JTAG, but many many, in fact the majority don't, especially when you
    look at units shipped.  Take the leading microcontroller supplier,
    Microchip, for example.  How many PICs have JTAG?  None of the 10, 12, and
    16 family I think.  Maybe some large 18s do, but most don't.  Some of the
    16 bitters, particularly in the larger packages do, like the 24, 30, and 33
    families, but many also don't.  It may be that most of the 32 family do.
    In any case, the point is that many many digital parts, including the vast
    majority of microcontrollers, don't support JTAG.  JTAG can be useful when
    present, but you can't claim a universal test strategy that relies on JTAG
    always being there because it isn't.
    Quote:
    JTAG + ICT is a very powerful way to insure that your boards are
    properly loaded and soldered.
    Of course JTAG can be useful and appropriate for testing some designs, but
    the point is ...?
    Quote:
    Almost certainly not unless field
    reliability is
    very very important and doubling the cost makes it worth it.
    In my (and many other products) it is worth it.
    OK, sometimes it is worth it (as I said), but again, your point is ...?
    Quote:
    Besides, a properly
    implemented JTAG + ICT test procedure cost little to implement on the
    product and it is much cheaper than doing any hands-on functional
    testing.
    Which would actually be relevant if I had somehow proposed the only
    alternative to testing every single net is to do manual hands-on testing.
    Quote:
    Sure, no absolutes.  But if all I was worried about was untested bypass
    caps I wouldn't even think about ICT or JTAG.
    Because I mentioned a hard to test case (bypass caps), this was somehow
    taken to be a argument against JTAG or any other in-circuit testing!!?
    Quote:
    You could also
    have the micro produce a known pattern on that pin and check for
    the
    expected result elswhere, perhaps even at output of the whole
    board.
    Sometimes with a little cleverness, it's not hard to verify most of
    the
    in-between components if the micro wiggles it's pin the right way
    and you
    analyse the output signal the right way.
    Agree or not, it's very common.  How would you propose to test such a
    situation without adding additional cost to the product?
    You could have the micro produce a known pattern on that pin and check for
    the expected result elsewhere, perhaps even at output of the whole board.
    Quote:
    Ah, but with ICT test points its not a black box block.  I can drop
    test
    points on "internal" nets and check them as well.  I can even measure
    R,
    C, and L values and see if someone loaded the wrong reel on the pick
    and
    place machine (it does happen).
    Being able to test all internal nets doesn't mean it couldn't be tested
    effectively enough as a black box.
    (now before you go off and knee jerk with a orthagonal argument, note that
    this doesn't say all subsystems can be tested as black boxes, or that they
    always should be if they can, only that it is possible and sometimes
    appropriate and effective to do so, and that therefore there are
    alternatives to always testing every net)
    Quote:
    For example, consider a switching power supply producing 3.3V from
    10-30
    volts in. That's hardly a far fetched case. The tester can often
    verify
    the power supply to acceptable confidence by varying the input
    voltage and
    measuring its current, and measuring the output voltage and being
    able to
    switch some additional loads onto it perhaps. If everything is
    right with
    a few test cases, you know the inductor, switch, catch diode,
    feedback, and
    control circuit are all working correctly without having to look at
    the
    various internal nets of the power supply.
    If I have a switching power supply on my design (which I do) and the
    output voltage doesn't leave the board, I've either got to drop some
    ICT
    test points on the board and measure the supply voltage at ICT, drop
    test points on the board and have a human measure it by hand with a
    voltmeter ($$$) or rely on your self testing scheme.
    This reinforces my pointer very well.  You don't need access to the power
    supply's internal nets to be able to test it to acceptable confidence in
    many cases.
    Quote:
    In fact, I think your
    example is a fine demonstration of why you might need ICT.
    Right, but since nobody was saying you should leave your board untested or
    do it by hand or something, I don't see what your point is.
    On 12/29/2010 5:32 PM, Olin Lathrop wrote:
    Michael Sansom wrote on Wed, 29 December 2010 11:44
    >> You're asking the world to conform to your concept of the work flow.
    Actually you're the one asking for a change. Most here seem to be OK with
    how Eagle handles this. Your request seems a bit silly.
    Sounds like the start of a pissing match to me.  Ok, I'm game.  So the
    If you want to take that stance I think I'm not the one that sounds silly.
    Quote:
    >> > For example, many points connected to a microcontroller don't need
    >> > to be
    >> > connected directly to the tester. Usually you set up a
    >> > communication link
    >> > to the microcontroller and have it report on the state of signals
    >> > or drive
    >> > them as required. With a little cleverness, you can infer the
    >> > operation of
    >> > components between the external connections and the micro too
    >> > sometimes.
    >> Simply not true.
    That's a bold statement, considering I've done exactly what I describe
    above a number of times. Did you actually read what I wrote? Note the
    part about the tester communicating with the on-board processor.
    Quote:
    >> How will you determine if a microcontroller's pins are soldered to the
    >> PCB if you don't have an in-circuit test point.
    As I already said, and you apparently missed, the tester communicates with
    the micro. This doesn't work in all cases, of course, but is quite useful
    when a communications port from the micro is already brought out, or you
    can easily run the UART lines, for example, to test points. You can also
    run a few unused pins to test points and create any kind of bit banged
    communication interface you want.
    Put another way, the on-board processor becomes part of the tester
    temporarily during test. It's often in the ideal position to exercise
    surrounding hardware and measure the result. Sometimes you feed back
    signals into otherwise unused pins just for this purpose.
    So if a processor pin connection is open, something will fail. If its a
    communication pin, communication to the tester controller will fail. If
    its a different pin, the processor won't measure something as expected or
    the rest of the circuit won't produce something as expected.
    This doesn't work for all nets, of course, but it can greatly cut down on
    what the tester has to connect to and test itself.
    Did you read what I wrote.  I allowed that you can test connectivity
    between two JTAG devices if you implement a scan chain (which I do).
    product).  Sure, I could take the output of the LPF and run it to an A/D
    measure the resistors, capacitors, and inductors values and confirm I've
    loaded the right components and that indeed they did get soldered to the
    Test points are free (as long as you are not area constrained, besides I
    put my test points on the bottom).  All I have to do is pay to build the
    ICT fixture but I'm building thousands per month so I'd much rather
    pay for a single one time up front cost.
    I understand completely the approach you propose.  I've used it.  It
    costs like that.
    Quote:
    >> Normally, the way that is tested is you will connect the
    >> microcontroller and any other JTAG compliant devices to a JTAG scan
    >> chain.
    Sometimes. Lots of micros don't have JTAG though. JTAG eats up a rather
    large number of pins, so generally only large micros have JTAG.
    JTAG is five pins.  However, in general most of those five pins are
    available for other uses on microcontrollers when not in test mode.  It
    can place some additional constraints on how you use those pins, but I
    don't usually find that burdensome.
    Quote:
    >> But what about signals that don't terminate on another JTAG device?
    There's a bigger world than JTAG out there. All you need is to somehow
    detect something changes in a way that is very unlikely to happen other
    than by the intended method working properly.
    properly loaded and soldered.  If you are building very uncomplicated
    designs then perhaps it isn't needed, but I don't think you can just
    ignore it.  It is used quite a bit in the industry.
    There are no absolutes. Everything is a probability game, even with
    JTAG. To catch lower and lower probability failures requires ever
    increasing
    complexity and effort. At some point you make the decision it's not worth
    persuing the remaining possible failures. If you're going to produce
    10,000 units each costing $100 to produce, how much is it worth to catch a
    1:1,000,000 failure? Certainly at least $1/unit, but what about
    $10/unit? Probably not. $100/unit? Almost certainly not unless field
    reliability is
    In my (and many other products) it is worth it.  Besides, a properly
    testing.  If your product is such that you can essentially ship it
    without doing any testing then great, you don't need it.  I'm not in
    that camp.  For me, a combination of JTAG + ICT actually makes my
    product cheaper to produce.  That's kinda the whole point.
    And then there are some parts that are really hard to test for even if you
    have access to all the signals. For example, what if a bypass cap
    somewhere wasn't soldered right and one side was actually open. The other
    bypass caps and bulk capacitance mask the single open cap when the power
    net is probed as a whole, even if you do try to measure the capacitance on
    the line (which is rarely done). You'd need circuitry in the tester
    something like a transmission line analyser and a test point very close to
    the cap to be able to detect this. Do you do this on every board for every
    bypass cap. I didn't think so. No matter how sophisticated (and therefore
    expesive) you make the tester, there will always be some failures it can't
    detect. As I said, it's a probability game. There are no absolutes.
    Quote:
    >> Say a signal originating on a microcontroller port pin that ultimately
    >> connects to some analog circuit. How are you going to test
    >> connectivity without a test point? Normally you would use the JTAG port
    >> to command the port pin to go high and low then use your ICT tester to
    >> observe the result.
    I don't agree that's the "normal" way, but it's one way. You could also
    have the micro produce a known pattern on that pin and check for the
    expected result elswhere, perhaps even at output of the whole board.
    Sometimes with a little cleverness, it's not hard to verify most of the
    in-between components if the micro wiggles it's pin the right way and you
    situation without adding additional cost to the product?  The port
    pins on my micro are full.  Am I going to pay more to drop a higher pin
    count part on the board so I can test it your way?
    I wasn't referring to delicate signals by "blindly" but rather that every
    single net needs to be tested. I haven't seen a design yet where that
    makes sense. In your system there is absolutely no way to infer the
    correct operation of some block by seeing the correct outputs given some
    specific inputs? That would be a first.
    Ah, but with ICT test points its not a black box block.  I can drop test
    points on "internal" nets and check them as well.  I can even measure R,
    C, and L values and see if someone loaded the wrong reel on the pick and
    Actually, if you think about it you're already doing that anyway. Chips
    are laregly black boxes with many internal nets. You don't need to, and
    certainly wouldn't want to look at the state of every one of those internal
    nets. You give the chip some specific inputs and verify that the outputs
    are as expected.
    The silicon vendor has already tested that black box.  Unless I damage
    it it should be good.  I do however need to verify that it got soldered
    on the board properly.  You'll get no argument from me that you can't
    test everything, but if your only plan is to test components on your
    board by essentially feeding signals back around to your micro you'll
    have fairly poor coverage unless your designs are small.  Mine aren't.
    You can consider your board the same way. You usually don't need to see
    every internal signal if the right output is produced from a specific set
    of well chosen inputs.
    For example, consider a switching power supply producing 3.3V from 10-30
    volts in. That's hardly a far fetched case. The tester can often verify
    the power supply to acceptable confidence by varying the input voltage and
    measuring its current, and measuring the output voltage and being able to
    switch some additional loads onto it perhaps. If everything is right with
    a few test cases, you know the inductor, switch, catch diode, feedback, and
    control circuit are all working correctly without having to look at the
    output voltage doesn't leave the board, I've either got to drop some ICT
    voltmeter ($$$) or rely on your self testing scheme.  The problem is,
    your micro will run just fine if the supply voltage is +2.7V or +4.0V.
    In fact, it will run just fine (for a while) if the supply voltage on
    the micro is 20% higher than the absolute maximum on the micro (but of
    course service life will be compromised).  To make that scenario happen
    all I've got to do is misload one resistor in the switcher's feedback
    loop.  Frankly, I'd like to catch that at ICT.  In fact, I think your
    work flow.
    to be
    communication link
    or drive
    operation of
    sometimes.
    Simply not true.
    soldered to the PCB if you don't have an in-circuit test point.
    microcontroller
    and any other JTAG compliant devices to a JTAG scan chain.
    device?
    There are no absolutes.  Everything is a probability game, even with JTAG.
    To catch lower and lower probability failures requires ever increasing
    1:1,000,000 failure?  Certainly at least $1/unit, but what about $10/unit?
    Probably not.  $100/unit?  Almost certainly not unless field reliability is
    For example, let's say you have a anlog input that goes thru some filters
    and then into a A/D input of the on-board micro.  You probably don't need
    to probe every net in the filters.  Many, if not all, of the filter
    circuitry can be verified by driving the board input with certain signals
    and having the micro report what it sees, or even having code in the micro
    that analyses the pattern and reports good/bad directly.
    ultimately connects to some analog circuit.  How are you going to test
    observe the result.
    What makes sense has a lot to do with the specifics of that one design, how
    much it costs, what the cost of a failure is, how many you intend to
    produce, etc, etc, etc.
    Quote:
    The point is, you don't want to blindly connect a pogo pin pad (or
    whatever
    you use to connect to the tester) to every net. That would add
    needless
    complexity to the board, the tester, and the test process.
    Maybe you don't want to do that, but I and many other companies do
    exactly that, except we don't do it blindly.  On signals that are low
    speed, you can pretty much put a test point wherever you want.
    However,
    I agree that on high speed signals you either want to place the test
    point at a specific place or skip the test point altogether.
    are as expected.
