EAGLE User Support (English) Beer for eagle users
  • Replies 24 replies
  • Views 3295 views
now that I have your attention image ,
I'd like to ask my question one more time:
Pertaining to the Eagle attributes described below, how does one access any
of these attributes? I have tried to understand but I simply don't... There
have been a couple of discussions on this forum about attributes, but I
can't find something that will help me.
If I want to have access to say, PARTNUM, how do I do this? Is it through
the info window of a part? Or is it by modifying a device in the library?
I'd really like to know.
O
    Hi Dave M,
    well you seem to have exactly what I'm looking for. But that seems like a
    really big ulp. I have no idea what language a ulp is made with, but I'd
    just like to have something simple. I mean, because of its size, it is much
    harder and takes more time to debug, so I guess before it's safe to use
    (has NO errors in part numbers, line changes, syntax errors, etc) it will
    take a lot of beta testing.
    I don't need to do this right at the moment, but in the next weeks, I
    guess.
    Thanks for the help nonetheless,
    Owen
    HI Redcutlass,
    I have been learning the ULP language very intensely over the past few
    weeks, I am making great progress with my "Advanced" BOM/MRP system.
    As far as your question goes, you will need to have a ulp to run through
    all the parts in your schematic and then find those that match the DEVICE +
    VALUE, i.e R0805:10K, then add ( if not already there) an attribute for say
    PARTNO, and copy the "partno" in to all those occurrences.
    My system does this, as well as a whole heap of other things.
    It may be a few more weeks before I can release something. So far I am at
    abput 1000 line of code.
    I REALLY do like the ULP Language( a lot !!!), lots of the HARD WORK has
    already been implemented in its built in functions, especially for access
    to parts and string functions.
    thanks
    Dave M
    Well, this time I'm actually going to provide answers instead of
    questions!
    To my surprise addign attributes was much simpler than I thought. Funny
    enough, I discovered this when I wasn't even searching for it. I don't know
    what I was doing but I know I was in the schematic editor and did a
    right-click on a symbol, and saw "Attribute" in the pop-up menu. I thought,
    this is interesting, what if...
    And yes, I clicked on it and up comes the attribute window where you CAN
    actually input your info. Very simple, and effective, I can finally do what
    I want, which was add (company)part numbers, or anything else, to my
    discretion.
    Another member said that yes it's possible, but it was "complicated" with
    numerous clicks and right clicks. I don't think so, I find it's quite easy.
    If only I'd discovered this before I posted, I would have saved LOTs of my
    time.
    does anyone know how to add a common value to the attribute of many
    different parts? Say I have a bunch of 0603 2k2 resistors that I want to be
    called, say 60-0001. Is there a command or ulp that can stuff all my 10
    resistors with this value?
    Thanks again, looks like I left you guys with another question!
    cheers,
    OW
    Wow, I doon't know where to start!
    So many things have been said, some of which I agree with and some that I
    don't, but everything helps me open my mind (except, obviously, raw
    negative comments). I believe Morten Leikvoll set me on the right track, so
    I'll be playing around with that. As for what makes a good engineer, well,
    what's been said I find true, but it is not because someone does not like
    the command line that it makes him a bad engineer. Like I said I use the
    command line and the mouse, I find both have excellent advantages, and I am
    not an engineer, first and foremost. I always take the time, I repeat, to
    search the help file and the forum before I ask questions, believe it or
    not I could not find anything helping me in the previous threads about
    attributes. It is quite possible that I need to be told more specifically,
    with an example, what to do in many cases.
    I guess it all depends on our experience with Eagle, and I have only been
    using it for two years, at a duty cycle of about 50%.
    Oh! I'd love to buy anyone a beer, if they're up in the Ottawa region
    (Canada) because obviously people have asked for their beer! image
    "Owen" <old62buick@yahoo.com> wrote in message
    news:j09ilb$rcb$1@cheetah.cadsoft.de...
    I guess I know now that an attribute field that's added in the part editor
    cannot be filled in by the user at schematic placement, which sucks for
    anything like resistors, capacitors and inductors.
    Im not sure if you misunderstood that.. Attributes can be DEFINED and EDITED
    anywhere (of course they can only be given a common value at device editor).
    The cleanest way is to DEFINE them at part editor and change value (if you
    want non default) at sch level.
    On 07/22/2011 08:09 AM, davem wrote:
    Olin wrote on Fri, 22 July 2011 21:33
    >> The command line (this is not just about Eagle) is far more productive
    >> than a clickety-click interface once you take the trouble to learn it.
    NO ITS NOT!!!!!!!
    Thats just YOUR OPNION! how can anyone say that half a dozen keystrokes is
    MORE Productive than just ONE BLOODY MOUSE CLICK!
    Olin may at times be brash and unrefined in his politics (i.e. pissing
    people off), but he does know eagle, and he knows it very well...
    okay... he's /often/ brash.  I generally read his posts for the tips and
    techniques that are often contained therein.  I disregard whatever
    harshness may be present because I know everyone else is doing so as
    well.  Well, almost everyone.
    I may find myself in rare company here, but I have to agree with Olin
    with one caveat.  Instead of just "the command line" being more
    productive, I would posit that the "keyboard" interface is more
    productive than the mouse alone.  With one hand on the keyboard, and one
    on the mouse, a draw net command can be started in two keystrokes
    (Alt-D, N) which is significantly faster than locating the draw icon,
    moving the mouse to it, clicking, then moving the mouse back.  It's also
    significantly faster than typing "DRAW (enter)" in the command line -
    especially with one hand.  Starting a route on a board is similarly
    simple - Alt-E, R.  Ratsnets is F3.
    Quite frankly, I like the way Cadsoft has designed the user interface.
    It has features providing both clickers and typers methods of getting
    work done efficiently.
    One last thought... We're all here to share ideas - that's the bottom
    line.  I'm not here to make others feel good about themselves, nor am I
    here to cast stones or question the abilities of others.  While I'm
    comfortable identifying myself as an engineer, I don't need to post a
    full biography in order to convince others of that.
    I also know that no matter how good I am at engineering, there are
    certainly others in the world who are better than I, and I will not
    hesitate to seek their advice.  And gentlemen, that's how I become a
    /better/ engineer.
    So... Owen,  Where do I get my beer?  I'm looking forward to a stout
    German brew.
    Enjoy life,
        - Chuck
    Olin wrote on Fri, 22 July 2011 08:32
    davem wrote on Fri, 22 July 2011 08:08
    productive than a clickety-click interface once you take the trouble
    to learn it.
    NO ITS NOT!!!!!!!
    You have to learn it before you can make such a proclamation.
    OK, can we end this squabble please?
    Olin is up front and some people don't like that.  But he has loads of
    experience and one would do well to consider his technical input.  His
    point about needing to know your tools is a good one even if his way of
    saying it was offensive to anyone.
    Another point to consider is that most people who respond here are doing it
    on their own time for free.  Any user who consistently shows an
    unwillingness to learn or look for answers themselves will get fewer and
    fewer responses from the old timers around here.
    So the general (unspoken) rule is that you try to find the answer yourself.
    Then come here and ask a specific question.
    CadSoft will respond to everyone but they don't have the bandwidth the
    community has.  So if you want a fast answer from the community you'd do
    well to consider this input.
    The PDF manual has already been mentioned.  Searching through it can be a
    useful exercise.  You can also search through all the past forum posts at
    www.eaglecentral.ca/forums.  That search isn't limited to a particular
    forum (unless you want it to be) so even if a post is in the wrong forum
    the search will find it.  And it will find common terms for things that
    EAGLE has funny names for (e.g. annular ring vs restring).
    Of course newbies may not know where to even start which is fine.  But the
    old-timers around here will expect that they start to learn and ask better
    and better questions.
    That's just my observation over the last decade.  I'm not speaking
    officially for anyone.
    Cheers,
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    productive than a clickety-click interface once you take the trouble to
    learn it.
    NO ITS NOT!!!!!!!
    Quote:
    Good engineers learn to use the tools at their disposal.
    guess I am a BAD Engineer then!, Now , where's that sliderule of mine..
    its ok I found it, It was next to my Abacus.
    NO ITS NOT!!!!!!!
    Based on your theory the next IPHONE will have command line interface
    instead of its touch buttons!
    Boy Olin, Will you just give UP!
    Dave M
    Redcutlass wrote on Thu, 21 July 2011 19:28
    ... I do not have time to go through pages and pages of documentation
    You don't have time not to.
