EAGLE User Support (English) Use Improvements?
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 569 views
Use Improvements?
New user, so maybe I'm missing something.  But I would like to have these:
On most tools, once you select the tool and use it, a left click on a new item repeats the tool.  Would be nice if Properties worked this way.
For library maintenance, you can't remove a device, package or symbol unless you have that item open.  Would be nice to be able to delete anything without opening it first.
Would be nice to have a "Repeat" button so some operation on one item can be repeated on another.  A simple example is VALUE.
Dave
    Another thought.  In the library editor, if you select a function (such as
    'i'), then change parts, there's no need to de-activate the 'i'.  That just
    causes more work.
    Similarly, when you switch between device, package and symbol, there's no
    need to change the grid.  That too just causes extra work.
    Don't get me wrong.  I'm not complaining.  I'm finding Eagle to be a
    terrific tool!  But I'm the kind of guy who would prefer doing things with
    one key or one click rather than many.
    Dave
    I just tried to remove a device from the library.  I got an error saying it
    could not remove it.  The device did exist as I saw it in the device list.
    I changed to another device and was then able to remove it.  I don't know
    what the restriction is that prevents removal, but there is one.
    Then, I wanted to change a bunch of PWR pins in my library to SUP pins.
    After doing "i" for info, clicking on the pin, clicking on the direction,
    pulling down to SUP, then clicking OK, it would be nice to click on the
    next pin and repeat without having to do all the clicks and mouse moves.
    This is the repeat feature I mentioned before.  The same thing happened
    when I wanted to change the font and ratio of a bunch of text in my
    library.  A repeat command that changes everything the same way as the last
    operation would be nice.  (That's how Ctrl-Y works in Windows.)  But I
    could understand that could be a difficult thing to do.
  • CSWalt
    CSWalt over 14 years ago in reply to e14 Contributor
    On 06/18/2012 02:35 PM, Christian Bohrer wrote:
    "Dave Wills"<noreply-108456@element14.com>  a écrit dans le message de news:
    433705745.23551339799637003.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    >> Thanks Jorge and Lorenz,
    >> On the first item: Here's an example. I have nothing selected in the schematic page. I right
    >> click on any part, then select NAME. The NAME popup appears and I can modify it. I can left click
    >> on any other part and the NAME popup appears for that part. Now I want to change something in
    >> Properties, lets say Net Class. So I right click on a wire, select Properties, select the Net
    >> Class I want and then click OK. To modify the Net Class of the next wire, I need to right click
    >> and Properties again. Since the previous operation was Properties, why can't it just open the
    >> Properties window with a single click? Rather, if I left click the NAME window from before pops
    >> up. This isn't the only example of this, and if you do Properties a lot, it's a lot of clicking
    >> and mouse moves. (Repeat does work on many commands, just not Properties.)
    Select the command first. The command selected will stay active until you STOP it.
    Example: if you select first the button info (Properties), you can open successively  the
    "Properties Box" of each element by a simple click.
    OK, and another thing:
    To modify the netclass many times you simply use CHANGE CLASS (see change submenu).
    Then click all the nets you want to have and that's it !
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Christian Bohrer wrote on Mon, 18 June 2012 05:35
    STOP it.
    Example: if you select first the button [i
    Ah yes.  I hadn't thought of that simple solution.  OTOH, if you click the
    icon, you can left click as many other items you want and still get
    properties.  If you right click then select NAME, you can still get the
    NAME of all the other items.  (It switches from Properties to Name.)  If
    you then right click and select Properties, it only does it once.
    Unexpected behavior.
    Dave
    "Dave Wills" <noreply-108456@element14.com> a écrit dans le message de news:
    On the first item: Here's an example. I have nothing selected in the schematic page. I right click on any part, then select NAME. The NAME popup appears and I can modify it. I can left click on any other part and the NAME popup appears for that part. Now I want to change something in Properties, lets say Net Class. So I right click on a wire, select Properties, select the Net Class I want and then click OK. To modify the Net Class of the next wire, I need to right click and Properties again. Since the previous operation was Properties, why can't it just open the Properties window with a single click?  Rather, if I left click the NAME window from before pops up.  This isn't the only example of this, and if you do Properties a lot, it's a lot of clicking and mouse moves.  (Repeat does work on many commands, just not Properties.)
    On the second item: I just tried this again and was able to remove a part that was not open (package).  I know there are conditions where this isn't true.  When I find them, I'll post again.
    On the third item: Consider the first item.  If I want to do the same operation under Properties a bunch of times, I have to do all the clicks and mouse moves just to get to Properties as above first, then the same operation I did for the previous item.  So for Net Class, if I could left click on what I want then have a "Repeat <previous operation such as Net Class>" button, it would save a ton of time.
    Lorenz, sorry, I don't understand.  I'm an old time UNIX guy, but I'm perfectly happy using IDEs rather than command line.  Can you give me a specific example I can try?
    Dave
    Jorge Garcia wrote:
    >A repeat button is unnecessary since most of EAGLE's commands work this
    >way. If you click on the VALUE icon it will stay active until you press
    >escape or select another command. While the command is active you can
    >just left click on each component and alter it's value one by one.
    elaborating on that: invoking a for instance a change or value command
    via the command line lets you modifiy part attributs by clicking in
    them until you abort the command or enter/select a new one.
    Lorenz
    Dave
    Hi Dave,
    A couple of points need to be corrected.
    In the libraries as long as you have the library open, going Library->
    Remove allows you to remove anything as long as you know it's name; the
    specific package,device, or symbol need not be open. So lets say you
    have device called test you want to delete but you're working on a
    package, you don't have to open the device. Just go Library-> Remove,
    then in the little dialog that pops up type:
    test.dev and press enter
    Thank you for your suggestions and we hope that you continue to enjoy
    working with EAGLE.
    Best Regards,
    Jorge Garcia
    Cadsoft Support
