EAGLE User Support (English) Arbitrary Pad Shapes
  • Replies 7 replies
  • Views 1222 views
I have a FET with the pad layout shown in the attached drawing.  I've tried
a few things but can't get past the "Package ... contains an invalid
polygon."
First I tried having 4 pads all connected with a polygon in the shape of an
"H".  That didn't work.
Next I tried a single pad with the "H" creating the other 3 pads with the
polygon.  That did't work.  In addition, if I make the polygon width too
large, it doesn't fit, too small, Eagle complains, and anything in the
middle leaves the corners of the other 3 pads rounded.
Next I tried a single pad but creating the pad with wires.  This doesn't
work either and I have the same problem with the rounded corners.
Finally I tried a single pad and making the "H" with overlapping rectangles
on the top side.  And guess what?  That didn't work either.
What is even more confusing is for the last 2 attempts there aren't even
any polygons in the package (and I have only this one library turned on so
there aren't any other conflicting packages).
I'm baffled as to how to do this.  Any ideas?
Dave
    Christian,
    Thanks for the suggestion.  I keep learning more and more about Eagle.
    Pretty soon I'll be a Novice.  image
    Tried that, still had unexpected unrouted wires.
    I'm going to go back to my working version and go for fab on a proto board,
    then try to fix this in the next rev.
    Thanks again to all.
    Dave
    "Dave Wills" <dave@davewillsinc.com> a écrit dans le message de news:
    jshbea$7ur$1@cheetah.cadsoft.de...
    >I tried the polygon again and went around almost the same circle as last
    time I did.  After autorouting, there was an overlap error at one of the
    notches in the "H".  The router had placed a via overlapping the two
    extensions of the H created by the polygon, but not over the pad itself.
    This would prevent me from soldering the component.
    Try to draw a "H" polygon in the layer 43 "VIA Restrict"
    So back to the library and put in a Restrict on the pads.  And then the
    router couldn't route a half dozen traces.
    At this point, I don't konw if I want to continue down this path or go back
    to my original working method of manually chaning trace width to eliminate
    clearance errors.
    Dave
    Jorge Garcia wrote on Wed, 27 June 2012 14:19
    On 6/27/2012 2:07 PM, Dave Wills wrote:
    <snip>
    Hi Dave,
    The key to making the Arbitrary pad shapes is that the pad must be
    completely enclosed by the polygon and any wires used to define the
    arbitrary pad shape must run through the center of said pad in order to
    be recognized.
    A better way is to create a single small pad in the center of the giant
    pad and then form the giant pad using a single polygon in the library.
    All you have to do is figure out where the corners of the PAD are
    located and making the polygon will be easy since you can input
    specific
    points in the command line.
    hth,
    Jorge Garcia
    Cadsoft Support
    <snip>
    I'm going to answer for you here, but in the future if you wish to
    present a different problem it's preferable to start a new thread. It
    makes it easier when users search the forum for answers to questions.
    The manual states that Overlap errors occur when copper objects of
    disimilar classes come into contact with each other. Can you confirm
    that all of the items belong to the GND net by typing show GND in the
    command line?
    hth,
    Jorge Garcia
    Hi Jorge,
    WRT polygons, I think this gets me back to the problems I reported to
    start.  Polygons have width and the width will have to be less than the pad
    size in order to include the fingers of the "H" (or overlap).  So unless
    the polygon has near zero width, the fingers will have rounded corners.
    I'll try again to see what I come up with.  Regardless, I think I end up
    with errors/warnings that can't be resolved, just approved.
    WRT the GND net, yes, if I show GND, the vias, the exposed pad and the GND
    layer all show up.  The name of the pin on the package is EXP and it is
    connected to GND with a wire.  The net list shows that pin of the IC
    connected to GND.
    Dave
    OK, I think I fixed this on my 6th attempt.
    What I did was to make the 4 outer rectangles 4 different pads, then make
    an inner pad which abuts the 4 outer pads.  Then for that device, I connect
    all 5 pads to the same pin of the symbol.
    This seems to work OK but I'm confused by some things.  First, is there any
    way to connect those 5 pads within the library part so that the autorouter
    doesn't connect them?  The reason is all 5 pads carry high current
    (discussion in another post I made) and so traces on that net class are
    wider than a single pin.  Letting the autorouter connect the pins external
    to the library means the wider traces have clearance errors unless I
    manually make the ones that have clearance errors smaller.  (This is why I
    tried the first 5 attempts at creating the part which didn't work.)
    Hi Dave,
    be recognized.
    located and making the polygon will be easy since you can input specific
    hth,
    Jorge Garcia
    Cadsoft Support
    The other question is unrelated.  I have a QFN24 SMD device with an exposed
    pad underneath.  The exposed pad pin is connected to GND on the schematic.
    To make sure I get sufficient thermal and current transfer with the exposed
    pad, I add some vias to my GND layer on the pad.  But DRC gives me overlap
    errors.  The exposed pad is connected to GND and the NAME on the vias is
    GND.  Why would I get overlap errors?
    command line?
    hth,
    Jorge Garcia
    Thanks a ton.
    Dave
    Thanks a ton.
    Dave
    And I just tried creating 6 pads, overlapping the left 4 with a polygon,
    then connecting the pads with wires.
    That didn't work.
    d
