EAGLE User Support (English) Forward and back annotation broken. Help!
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 2168 views
  • back
  • forward
  • annotations
Late last week I downloaded the free version of Eagle 6.5 following Jeremy Blum's tutorial on Eagle.  All went well, I was able to create a schematic and then transfer it to a board and do routing.  Sometime in the last couple days I screwed something up and I have no idea what I did.
If I create any type of schematic and then go to open a new board Eagle gives me the error massage  that the forward and back annotations are not available.  As a test I placed a battery, LED and one resistor in the work area for Eagle and then made the correct connections.  I ran the electric circuit check and all connections were fine. But even with that simple design, clicking on new board gave me that same error and then none of the components were transferred to the board.  I have uninstalled Eagle and reinstalled it with the same results.  I have even gone into the registry and deleted all references to Cadsoft and Eagle.  I also deleted all directories and subfolders use by Eagle, and then did another fresh install.  Same problem. When I create any type of circuit in the schematic and open a new board it gives me a forward and back annotation error and no components on the board.
i'm afraid I have things so screwed up I'll never get Eagle to work again.
Any help would be greatly appreciated!
    autodeskguest over 12 years ago
    Am 04.01.2014 04:52, schrieb Allen Watson:
    Late last week I downloaded the free version of Eagle following Jeremy
    did.
    again.
    http://www.element14.com/community/message/99396
    YOU don't have to create a new board, eagle will do that for you.
    If you have a schematic the only thing you have to do is to  click the
    board symbol. Eagle will ask you if you wanna create the board and you
    just say OK image
    Joern Paschedag
    autodeskguest over 12 years ago in reply to autodeskguest
    did.
    again.
    just say OK image
    Eagle will look for a board with the same name as the schematic and
    check they are consistent (forward \ back annotation).
    It sounds like you maybe using the same name for the schematic or if
    that was previously deleted, the matching (old) board still exists and
    thus does not match the schematic.
    I think Joern meant to say Click the button / icon " Generate/ Switch
    to board" It's the 5th item on the tool bar or can be found in the
    'File' menu.
    All  the best
    Warren
    Former Member over 12 years ago in reply to autodeskguest
    Thanks guys, I will try it first thing in the morning.  If it is that simple I may shoot myself for being so stupid.
    l will let you know.
    Thanks again.
    Thanks guys, I am apparently too stupid to operate Eagle.  The good news is that it worked fine this morning, the bad news is now I have to find my gun ;-)  but since I am 60 it might take a while to find it.
    Glad that fixed the problem.  For us over 60 crowd, it can be tough laying
    out those boards for the octal sockets with our vacuum tubes  image
    mikey
    What I hate is chiseling out the rock base.  :-)
    Glad to see I'm not the only one working on the stone base !!
    mikey
