I used to create FPGA schematic manually but my last project has a 1500pins
FPGA and I would like to automate things to avoid errors and also save some
time.
I am a beginner in ULP scripts so I would appreciate some advice.
I didn't find any way to automate passing from FPGA pinout in (Quartus .qsf
file for example) to board schematic.
I have this procedure in mind:
- create FPGA symbol/package with "make-symbol-device-package-bsdl.ulp"
(already done)
- add a FPGA part on a schematic sheet
Then an ulp script has to:
- Parse Altera pinout file (qsf) to extract signal and pin names
- For each fpga symbol pin mentioned in the FPGA pinout file:
=> Trace and connect a wire to the fpga symbol pin
=> Label this wire with the signal name from .qsf file and display the
name
Example:
set_location_assignment PIN_A7 -to sensor_clk (from fpga pinout file)
This statement leads to the creation a wire named "sensor_clk" connected to
fpga pin A7.
Is it possible to do something like that?
I really didn't know how to start. I gave a look at "cmd-net-list2sch.ulp"
script but I can't make it work for a bga component.
Thanks in advance for helping.
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
