EAGLE User Support (English) Copy Layout and schematic
  • Replies 8 replies
  • Subscribers 179 subscribers
  • Views 654 views
Hey Guys
Select/Cut/Right Click/paste works like a bomb,
But how do I copy a schematic while keeping the layout structure in tact.
Jannie
  • esilviu
    esilviu over 17 years ago
    you can't!
    there are work-arounds, but directly - you can't
    "Jannie" <me@work.com> wrote in message
    news:fupvev$gsu$1@cheetah.cadsoft.de...
    Hey Guys
    Jannie
  • Morosh
    Morosh over 17 years ago
    Hey Guys
    Jannie
    Hi:
    with "merging.zip", you can do it (but with some operation).
    it's in the ulp download area.
    Maurice
    Hey Guys
    Jannie
    Hi:
    Maurice
    What is your ultimate objective?
  • Morosh
    Morosh over 17 years ago in reply to autodeskguest
    "Ted75zcar" <tbrannan@sporian.com> wrote in message
    news:fuqn0j$jlc$2@cheetah.cadsoft.de...
    Hey Guys
    tact.
    Jannie
    Hi:
    Maurice
    would you explain a little more your question?
    why feel you concerned with my ultimate objective?
    Hey Guys
    tact.
    Jannie
    Hi:
    Maurice
    Are you for instance trying to re-arrange the sheet order in you
    schematic,  or are you trying to do a design re-use (where you copy the
    schematic, and layout at the same time)?
    The solution to your problem relies upon what you are trying to do
  • Morosh
    news:fut3pj$j6e$1@cheetah.cadsoft.de...
    Hey Guys
    tact.
    Jannie
    Hi:
    Maurice
    I don't have any problem at all, I was just trying to help other people.
    with "merging.zip" you can copy/paste schematic/pcb between sheets or
    differents instances of eagle. You can a suffix for parts copied to avoid
    names'conflicts. you can merge different designs.
    But it requires some manual work.
    Maurice
    Hey Guys
    tact.
    Jannie
    Hi:
    Maurice
    Ted, Maurice
    I think one/both of you have mixed up a reply somewhere along the line
    I would assume that original confusion is that Ted's post should have been
    to the OP Jannie, rather than to Maurice, and after that things are a little
    confused.  At least that's how I read things here.
    cheers
    David
    Sorry I have taken so long to respond.
    We have been on leave for a couple of days. What I was trying to do is
    reuse a old design and duplicate it a number of times on a new board.
    For now I will have a look at merging.zip and see if it does the trick.
    Jannie
    Hey Guys
    tact.
    Jannie
    Hi:
    Maurice
    the schematic, and layout at the same time)?
    Ted, Maurice
    been to the OP Jannie, rather than to Maurice, and after that things are
    a little confused.  At least that's how I read things here.
    cheers
    David
