EAGLE User Support (English) I'm confused about adding NETS
  • Replies 10 replies
  • Views 935 views
I'm confused, should I be using the Wire command to connect components in the schematic or using the Net command. One tutorial says use wire, another says use net. I tried a small schematic using both and then converted the schematic to a board and all wire showed up. I guess I don't understand the difference. Any help would sure be appreciated because I think i am trying to make this more difficult that it should be.
Jeff
  • Richard_H
    0 Richard_H over 14 years ago in reply to e14 Contributor
    Am 12.10.2011 21:06, schrieb Ing. J.M. Rafetseder:
    hi,
    now the server is ok, i checked it. no password required
    r
    Thanks for the info. There is really lot of information about
    EAGLE.... Well done, thank you!
    Richard Hammerl
    0 e14 Contributor over 14 years ago in reply to Richard_H
    hi,
    r
    over the day it didn't work (server breakdown?) but now it works again. I'm
    sorry you cannot open the folders, they are at the moment only for teachers
    & students (login required). I'll talk to the webmaster maybe he can make a
    change.
    r
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    On 10/11/2011 08:29 AM, Olin Lathrop wrote:
    Element 14 User wrote on Mon, 10 October 2011 20:58
    Always use NET to make schematic connections.
    The command names in Eagle are perfectly logical.  WIRE is used to draw
    lines except when they respresent wires, then you use NET.
    touche! That's good, Olin.
    Jeff, Also be advised that CUT doesn't cut - it copies.
    I'm also learning - I understand the explanation and agree that for
    electrical connections NET is more convenient with "Auto End" and "dot on
    junctions" but at the end of the project is there does not appear to be any
    electrical difference in fact if I draw a new wire by itself then another
    wire to connect into an existing NET it gives the option of using the new
    Net$ name or adopt the name of the N$n to which we are connecting.
    So in summary it would appear that if I had earlier in a project used wire
    then I don't need to go back & redraw as long as the N$n ar correctly
    connected.
    Well that it how I see it and welcome comment.
    This was an excellent question to be raised in the first place.
    Regards
    Ray B
  • Richard_H
    Am 11.10.2011 14:11, schrieb Ing. J.M. Rafetseder:
    THX, image
    You have to learn this when teaching eagle in a technical school in
    austria ( if you are interested in other documents: www.htlwien10.at
    schüler -> unterrichtsmaterial -> eagle -> dokumentation)
    r
    Hi R,
    wanted to check the lin kwww.htlwien10.at , but it does not work.....
    Richard Hammerl
    THX, image
    You have to learn this when teaching eagle in a technical school in austria
    ( if you are interested in other documents: www.htlwien10.at  schüler ->
    r
    Am 11.10.2011 10:04, schrieb Ing. J.M. Rafetseder:
    Net is for the electrical connection of parts, Wire is intended to draw
    graphical stuff like borders for a partial circuit etc. The name is
    ambiguous, also the layer 91 used for it.
    The behavior is different from Net, so try the following:
    open a sch
    add 3 resistors (see screenshot "wire-tool")
    use the Wire-button & connect R1, R2 & R3.
    You will see:
    no auto-junction, no auto-end of the wire, only 2x click will end the wire.
    Now use the Net-button & try the same (see screenshot "net-tool")
    You will see:
    auto-end of the net & auto-junction
    HTH
    r
    Excellent explanation. Cadsoft should use it in the tutorial, with your
    permission of course image
    Joern Paschedag
    open a sch
    You will see:
    You will see:
    HTH
    r
