EAGLE User Support (English) Library management commands
  • Replies 7 replies
  • Views 1361 views
  • copy
  • rename
  • library_editor
  • delete
larsen
larsen over 14 years ago
I am evaluating the tool but after a short while of use I am having serious problems managing my self-made library.
How do I - inside a library:
Delete, Rename or Copy a: symbol, device or package?
It is _so_ easy to create new items (this has a prominent place in the select dialog), but it is difficult to rename or get rid of them again.
The remove/ rename command seems not to function or more likely I dont use it properly yet I follow the manual page 271. It fails saying that it cant find the item, yet it is there for sure.
Without this maintenace functionalty my library rapidly becomes messy and cloged up.
Hope for some hints.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Am 15.02.2012 17:57, schrieb Andreas Weidner:
    Am 11.02.2012 07:10, schrieb Mike Fields:
    >> if I open my library, click package and select the one I want to rename,
    >> this brings it up in the library editor window. Then, if I click Library
    >> on the menu, the menu that comes up has a number of options. Two of them
    >> are "Remove" and "Rename".
    Thanks for that information. I would NEVER, EVER have used these menu
    items, because I always thought they would remove or rename the LIBRARY.
    CadSoft: This is another example of insufficient menu item text. The
    menu item 'Library - Rename' SEEMS to mean 'rename library', because
    that's EXACTLY what it tells the user. What it really MEANS is 'rename
    device' or 'rename symbol' or 'rename package', so PLEASE put the
    additional word into the menu to clear things up.
    I've used EAGLE for 20 years and didn't know that this function was
    there due to this unclear menu wording. What a shame to both CadSoft and
    me...
    Andreas Weidner
    Same goes for me. Learned something too image
    Joern Paschedag
    Il 11/02/2012 07:10, Mike Fields ha scritto:
    You don't say if you are using version 5.x or 6 - at least in version 5.12,
    are "Remove" and "Rename".  I have used both previously and they worked for
    me.  Have not tried it in 6 yet (still learning it myself - I have enough
    bugs without running into Eagle bugs  :lol:
    I add here a question related to this topic.
    Is there a way to remove or move between libraries multiple components?
    I complain the lack of a interactive tree-view of the library(-ies)
    contents.
    It would be very handy to select multiple items and remove all together.
    Or move them to another library.
    Some time ago I spent several hours to remove one-by-one about one
    hundred of devices, symbols and packages while a multiple selection
    would have taken a couple of seconds.
    Please, consider to improve the library management. You should know that
    an electronic designer spends half time on the circuit and the other
    half on the libraries!
    Marco
    For what it's worth, this is a reason I periodically copy my library to a
    00_mylib_test.lbr - it is a junk library that I can experiment with and not
    shoot myself in the foot (at my advanced age, I have learned that is not a
    good thing).  There are enough things in Eagle (like not using "wire" to
    wire a schematic ! to make me careful what I do.  Great program, but
    somewhat less than "intuitively obvious" image  )
    mikey
    me...
    Andreas Weidner
  • larsen
    0 larsen over 14 years ago in reply to e14 Contributor
    Thanks for the two answers to my question. They were very helpful. I use the latest version 6 fresh from the download site.
    The reason I failed to get it to work is that the name extensions .pac or sym are required.
    So the manual is wrong on page 271 where it says
                   "REMOVE DIL16;"
    It should read
                   "REMOVE DIL16.pac;"
    Hope next version of EagleCad will have a simpler  interface for library managment.
    What I dont like by command line is that I have to remember the correct spelling of the objects- in practice I need the library browser open for peeking into the correct spelling. For the symbols however it is a bit more difficult as they are only listed in: libray editor -> symbol->pull down menu.
    Am 11.02.2012 01:27, schrieb henning larsen:
    It is so easy to create new items (this has a prominent place in the select dialog), but it is difficult to rename or get rid of them again.
    You just enter a command at the command line.
    Rem(ove) part_name.dev or .pac or .sym to indicate to remove a package,
    or a device or a symbol.
    Nearly the same goes for rename somethimg:
    Ren(name) part_name.dev or .pac or .sym (1 Space) new part_name.
    Example: ren 1234.dev abcd(you don't need .dev a 2nd time here)
    This will rename the 1234.dev to abcd.dev
    ren test.sym nowiknowit
    This will change the testsymbol to nowiknowit.sym
    Joern Paschedag
    mikey
