EAGLE User Support (English) DRC vRestrict not honored in linux 5.1.0
  • Views 483 views
holla2040
holla2040 over 18 years ago
Folks,
The 5.1.0 manual page 145 says "vRestrict regions are not examined by the
DRC".
I'm creating a package with in-board heatsink with a top layer and bottom
layer poly regions connected via pads (TI called this a PowerPAD). I
surround my poly/pad setup with a vRestrict poly. The DRC reports clearance
errors with the "DRC/Misc/Check Restrict" option enabled or disabled.
Is the page 145 description correct and I'm just doing something wrong?
Craig
ps. sorry for the cross-posting, I send the original to the wrong group.
  • holla2040
    holla2040 over 10 years ago in reply to Richard_H
    Richard,
    I'm confused. I asked this question about 8 years ago in 2008. Did you just answer this now, on April 7th? Or is there a problem with the e14 forum?
    Is the answer still valid for the current version of eagle?
    Craig
  • Richard_H
    Richard_H over 18 years ago
    bottom
    clearance
    The manual wants to say that the DRC does not check for vias that
    are placed inside the ViaRestrict area. Placing a via inside the
    area manually won't be indicated by an error message.
    Only the Autorouter will take care of such areas and won't
    place vias inside.
    Richard,
    Thanks for writing. I can't place vias within a package (or at least I don't
    know how to). I think I can do all this on a board because I can assign a
    signal to the top side poly, bottom side poly and the via then they're all
    connected. However I can't figure out how to create these pieces within a
    library package because I can't assign a signal to a poly or use vias. Do
    you see my problem?
    Craig
    You said placing a manually placing a via the area won't generate an error
    message if in vRestrict.
    You misunderstood my words:
    The vRestrict area can be used for the autorouter. If you draw this
    area in the layout, the autorouter is not allowed to set vias inside.
    In case you set vias manually in the layout and there is a vRestrict
    area that covers the vias, the DRC does not complain about the vias
    inside the vRestrict area.
    Concerning package design:
    You are right, there is no via command in the package editor. And it
    is not possible to name, for example, polygons there.
    But in some cases it is neccessary to use a polygon, for example,
    for a special pad shape. In this case you can combine polygon and
    Smds or Pads. But you will get an DRC error in the Layout which you
    can approve then. There is no other solution at the moment.
    Richard Hammerl
  • holla2040
    bottom
    clearance
    place vias inside.
    Richard,
    you see my problem?
    Craig
  • Richard_H
    Folks,
    DRC".
    place vias inside.
    Richard Hammerl
